  • PCW
  • PCW's Avatar
27 Apr 2026 16:28
Mesa 6i25 - Mesa 7i76U - Omron MX2 wiring
Category: Basic Configuration
7i76eu_7i76x1_pktv3d.bin
 or
7i76eu_7i76x1_pktv2d.bin
For older LinuxCNC distributions
  • djdelorie
  • djdelorie
27 Apr 2026 14:28
Replied by djdelorie on topic Probe tripped during non-probe move deadlock
I mentioned this here: forum.linuxcnc.org/39-pncconf/58480-conf...g-dual-y-axes#344832
I have "write a better debounce module" on my todo list. No guarantees ;-)
27 Apr 2026 13:47
Replied by tommylight on topic WHB04B-4 nie działa płynnie
Google translation:
"Hello, I have a LinuxCNC 2.9.8 Mesa7i92 board with SSK-MB2. It's a three-axis milling machine with X, Y, and Z axes. NGC programs work fine. I started the WHBO4B-4 with a cable and it doesn't quite work correctly. When I turn the wheel, the axis continues to move when I stop.
Please tell me what I have configured incorrectly."
  • PCW
  • PCW's Avatar
27 Apr 2026 13:40 - 27 Apr 2026 13:41
7i96S card arrived what setup is recomended
Category: Driver Boards
I would  first, disconnect  the encoder, jumper the encoder inputs for TTL mode
and then test the A,B and Index inputs by grounding the A+, B+ and INDEX+ pins
and watching the hal pins for these in halshow. They should change polarity when
grounded vs open.
The 7I96/7I96S encoder inputs are normally fairly rugged but can be damaged by EMI spikes
of greater than 25V. This can happen in a test setup where VFDs or spindle motors couple
the 400V or so square wave drive power into the encoder signals because of insufficient
grounding/shielding.
The Encoder input chip on a 7I96S is a 26LS32 (U12)
  • Surmetall
  • Surmetall's Avatar
27 Apr 2026 13:05
Replied by Surmetall on topic LinuxCnc logo
LinuxCnc logo
Category: Show Your Stuff
Would love to have a logo for linuxcnc-ethercat to match
I made one, and to be honest, I’m actually quite proud of it :D. However, I’m a bit hesitant to publish it. As far as I know, the EtherCAT logo is protected.
  • andrax
  • andrax's Avatar
27 Apr 2026 12:42
Replied by andrax on topic (Solved) G43 not being applied in g-code
Please try to provide a program excerpt. I would like to take a look at it and test it on my system.
  • abs32
  • abs32
  • grandixximo
  • grandixximo's Avatar
27 Apr 2026 12:15
  • xenon-alien
  • xenon-alien's Avatar
27 Apr 2026 12:14
Replied by xenon-alien on topic 7i96S card arrived what setup is recomended
Hello.
One 7i96s card on a lathe lost the encoder signal (it cames from a spindle driver on a differential line - as on 4th page ).
An other 7i96s card  ("from the box") has the same issue with the encoder and has the new W7 jumper for RS-485 - not used yet, just powered on)
I have connected a TTL encoder for test - that is why the jumpers on left hand.
On the table one card works, so i replaced it. But now i have a used (± a year) card, and a new one with no encoder input. We using them for lathe, so we need the encoder input for threading.
Can it be solved somehow? Re-soldering a component?
  • abs32
  • abs32
27 Apr 2026 12:11
How to fix "Queue is not empty after probing"
I guess tomorrow I’ll reboot the machine’s computer to version 2.9.8, reinstall the real-time kernel, and apply all the updates—but won’t that be version 2.9.x? And I’m ready to try running the cycle. If you could provide a link to the 2.9.x build for the real-time kernel (or userspace), I’ll be able to test it.
  • abs32
  • abs32
27 Apr 2026 12:09
The axis desynchronization issue was caused by an error in my INI configuration—the parameters I had set required a frequency higher than 50 kHz. I changed the servo period, and the error disappeared.
“Probe tripped during non-probe move” is resolved by setting delays. In my case, using an electrical capacitor. Over 2 million activations.
This leads to the conclusion that it would be appropriate to implement a Probe delay parameter in the machine settings. “Feedback” delay. That is, when the probe triggers, the machine must immediately recognize this and begin braking, and then even execute the next command (typically, recording and rebound). And the specified parameter in seconds or milliseconds should not react to a change in the probe’s state.
  • grandixximo
27 Apr 2026 12:01 - 27 Apr 2026 12:01
Replied by grandixximo on topic Issue with G38.5
Issue with G38.5
@christer
github.com/LinuxCNC/linuxcnc/pull/3971
could you test this?
  • grandixximo
27 Apr 2026 11:59 - 27 Apr 2026 12:01
  • grandixximo
  • nighteagle
  • nighteagle
27 Apr 2026 11:44
Replied by nighteagle on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello,
have found out the Problem - have flashed another bin gain - now 4 different Versions in the same project.
Have edit the above Post for others looking a way to bring this thing to work.
Displaying 4126 - 4140 out of 12541 results.
Time to create page: 0.354 seconds
