  • PCW
  • PCW's Avatar
06 Mar 2026 22:04
Replied by PCW on topic chineese mesa 7i92 custom bit file
Category: Driver Boards
Xilinx Webpack 14.7 runs fine on current Linux versions, no need to bother with Windows at all...
  • andypugh
  • andypugh's Avatar
  • tykhon
  • tykhon
06 Mar 2026 21:51
Replied by tykhon on topic chineese mesa 7i92 custom bit file
Thank you for help. Everything works just fine. Xilinx was a bit tricky to download due to american regulations and policies. Somehow registration form doesn`t work correct. But finally I downloaded it today so this is first and last case.
Talking about original mesa cards, in my country it is almost impossible to get desired board on time. They simply out of stock. So I had to save 15$... I`m sorry.
Xilinx itself appeared an old nightmare for me to install. Heavy virtual machine, only Win7 32bit and 30-year old interface... I would not recommend customizing chineese boards after this experience.
P.S.: hope people who don`t help use Windows :)
  • rock861261
  • rock861261
06 Mar 2026 20:58
El5101 Config was created by rock861261
El5101 Config
Category: EtherCAT
Looking for a lathe encoder hal for for threading and rpm. the files I find say to use the index pin however its not an option for the el5101
  • andypugh
  • andypugh's Avatar
06 Mar 2026 20:45 - 06 Mar 2026 20:45
How to do wiring to generate quadrature encoder signal in Mesa 7i95 board
I assume that LinuxCNC and LabView are not running on the same PC?
Is this conventional LabView or LabView Realtime? (if that even still exists).
(As an irrelevant aside, until last year LabView RT was the only thing that I had actually been paid to program in)
Have you considered not using the NI card for linuxcnc control, but instead communicating with LinuxCNC using linuxcncrsh?
linuxcnc.org/docs/stable/html/man/man1/linuxcncrsh.1.html
  • andypugh
  • andypugh's Avatar
06 Mar 2026 20:30
tpmod not loading on boot up with linux service
It sounds like, for whatever reason, tpmod isn't reporting "hal_ready()"
Though it seems odd in that case that LinuxCNC continues to load.
github.com/LinuxCNC/linuxcnc/blob/2.9/src/emc/tp/tpmod.c#L34
  • andypugh
  • andypugh's Avatar
06 Mar 2026 20:23
Rover 336 retrofit – horizontal drills and tool offsets in LinuxCNC
I would expect the tool table to work for this application. I have suggested it before and nobody has come back to say that it was a terrible idea.
  • andypugh
  • andypugh's Avatar
06 Mar 2026 20:15
Replied by andypugh on topic RPi 4B - No Desktop Icons
Is it possible that you have accidentally switched to a different "workspace"?
  • andypugh
  • andypugh's Avatar
06 Mar 2026 20:14
Replied by andypugh on topic Post process Fusion 360 lathe
Category: Fusion 360
G71 and friends exist mainly as an alternative to CAM, to make hand-coding easier.
I don't know of any CAM system that generates G71 (which isn't to say that there aren't any). But I don't think much would be gained from doing so.
  • kostas
  • kostas's Avatar
06 Mar 2026 20:07
I tried riocore with a Tang nano 9k last year, when I first read about it. I loved the idea and I think you have done a fantastic job so far.
So a big thank you, although I have not done anything productive with LinunxCNC and riocore yet, mainly because I already have some Mesa cards that I use in my machines and not the time that I would like to have to start experimenting with a fun project with riocore. I love the idea that for simple projects I could potentially use riocore with a cheap FPGA board though, so hopefully I'll do this in the near future!
I have a project in mind right now though, that would ideally use a microcontroller for sending commands to the FPGA for driving two motors and I would like to know if I could potentially connect an ESP32-S3 or ESP32-P4 that I already have. I'm only familiar with Arduino framework so far and I tried to dive further in ESP-IDF in the past but that was more hard for my current experience. Do you think it would be possible and fairly simple to communicate an ESP32 board with the Tang nano over SPI, like your LinuxCNC driver does?
Kostas
  • andypugh
  • andypugh's Avatar
06 Mar 2026 20:07
Replied by andypugh on topic heure et date
heure et date
Category: Français
The standard LinuxCNC disk image does not, as far as I know, disable WiFi. You should be able to get the time in the usual way.
  • jblanscett
  • jblanscett
06 Mar 2026 18:47
Replied by jblanscett on topic Trying to set up position control mode
Category: HAL
Okay, we will try to confirm that it is our servopack.
Does anybody have experience with position control mode on the SGDH-10AE or another Yaskawa sigma II series servopack?
  • jtrantow
  • jtrantow
06 Mar 2026 17:57
hm2_modbus pktuart, probably a firmware request?
FYI, when I ran my full configuration the vfd would work correctly at startup but would fail after several commands. Sometimes after homing, sometimes after MDI commands, but seemed to lock up and stop sending commands to the VFD. No errors reported in hm2_modbus and did not recover after set/clr the modbus reset.
I looked at git repo and saw several updates after the 2.9.8 tag. I have not noticed any lockups since installing and running the RIP master. I do get a few dialog errors about PDU too small while running but I don't lose control of VFD.
  • andrax
  • andrax's Avatar
06 Mar 2026 17:29 - 06 Mar 2026 17:32
Setting up the Stepperonline A6 battery encoder cable
Category: EtherCAT
Hello everyone,
As most of you know, Stepperonline A6 servos have 17-bit multiturn encoders.
Encoder cables with battery boxes are also available for these servos. The cables are supplied with batteries.
When these cables are used, the servos become multi-turn absolute value encoders and the reference run is no longer necessary.
Here is a step-by-step guide on how to set up the servos after installing the cables.
1. Switch on the servo.
2. Set parameter C00.07 > 2 (linear mode, absolute position).
3. The servo displays error ER20.8.
4. Set parameter F31.10 > 4.
5. Switch the servo off and on again.
6. Perform a reference run.
7. The .hal and .ini files must be adjusted.
I recommend commenting out the relevant sections.
HAL:
remove or  recommend commenting from all joints:
 => cia-statusword
and remove or  recommend commenting section #CIA Custom Homing
INI:
[EMCMOT]
# HOMEMOD=cia402_homecomp
[JOINT]
HOME_ABSOLUTE_ENCODER     = 2
HOME             = 0
HOME_OFFSET         = 0
HOME_SEQUENCE         = 0
HOME_SEARCH_VEL     = 0
HOME_LATCH_VEL         = 0
HOME_IGNORE_LIMITS    = YES
# only for homing
#HOME                 = 0
#HOME_OFFSET             = 0.0
#HOME_SEQUENCE             = 2
#HOME_SEARCH_VEL        = 1
#HOME_LATCH_VEL            = 1
#HOME_IGNORE_LIMITS        = YES
#CIA402_HOMING_ENABLED         = 1
#CIA402_HOMING_METHOD        = 4
#CIA402_HOMING_SEARCH_VELOCITY    = 300000
#CIA402_HOMING_LATCH_VELOCITY    = 30000
#CIA402_HOMING_ACCELERATION    = 131072
Now, all you have to do is press the home button after switching on the machine, and all axes are immediately referenced.
That's it.
  • JT
  • JT's Avatar
06 Mar 2026 17:00
Displaying 6076 - 6090 out of 12550 results.
Time to create page: 0.590 seconds
