  • tar_san
  • tar_san
29 Dec 2025 10:35
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
I found lot of messages
"Failed to get reference clock time: Input/output error"
in LinuxCNC Console
when I set "refClockSyncCycles="-1" to EtherCat Master configuration.
But if I set refClockSyncCycles="1", I could not see such messages.
I attached
refClockSyncCyclesMinus1.linuxcnc.txt (LinuxCNC Console Log)
refClockSyncCyclesMinus1.dmesg.txt (dmesg Log)
when I execute with  "refClockSyncCycles="-1"
And also, for reference, I attached
refClockSyncCycles1.linuxcnc.txt (LinuxCNC Console Log)
refClockSyncCycles1.dmesg.txt (dmesg Log)
when I execute with  "refClockSyncCycles="1"
  • grandixximo
  • grandixximo's Avatar
29 Dec 2025 09:26 - 29 Dec 2025 10:06
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
I would like to share an S-Curve jerk control I have been working on, actually since I made the OP, I think the code is pretty battle tested, but I based it on an old version, and I would like to port the code to something that the community will be happy with, what should my base code be from which to introduce the jerk control? are you guys ok with master? or 2.9.4?
  • grandixximo
29 Dec 2025 05:23
lemontart - a call for help with s curve, ui's, and all the cool toys
I have a pretty decent S-curve I have been using for sometime, would you be interested in testing it?
  • Thllll
  • Thllll
29 Dec 2025 03:55
Replied by Thllll on topic QT Dragon Unable to Set Tool Height
Category: Qtvcp
Attached ini and hal
  • heaven
  • heaven
29 Dec 2025 02:17
Recommend hardware solution for multi rs485 channel?
The system utilizes three RS485 devices configured in Auto-send mode rather than the standard Query/Response mode to achieve high-speed data transmission. Each device autonomously broadcasts data packets at a 1ms interval. To ensure simultaneous data acquisition and prevent bus contention, right now the solution employs three independent USB-to-RS485 adapters.
I'm looking to move away from USB interfaces due to noise sensitivity and latency concerns at high speeds. I need a more industrial-grade solution that can handle three simultaneous 1ms RS485 streams without data corruption.
  • snowgoer540
  • snowgoer540's Avatar
29 Dec 2025 01:19
Is this QTPlasmac Expected behaviour - Cycle Start and Jog disabled.
Category: Plasmac
Thanks, will give it a try after routing the network line to the new shop, all metal cladding so wifi does not work from the other shop.
I know this is over 4 years ago, but I was doing some housekeeping in the PlasmaC component, and found reference to a post in this thread.
Did you ever make use of the added pins, etc to sort this issue out?
  • FPVUALAB
  • FPVUALAB
29 Dec 2025 00:58
Replied by FPVUALAB on topic Safely Flash a Mesa Board
Category: Driver Boards
Hello. I have a Mesa7i92TH and I need a pinout for a Chinese board (mach3 interface board) 5Axis Breakout Board. 4 encoders and four axes. Why is there no 7i92t_5abob_encd.bin firmware in Mesa Configuration Tool II (I installed it via the terminal)? Maybe I need different firmware? 7i92t_7i85sx2d.bin, but it's not there either)))
Thank you very much for your help.
  • cmorley
  • cmorley
29 Dec 2025 00:52
Replied by cmorley on topic QT Dragon Unable to Set Tool Height
Category: Qtvcp
Can you post your ini file and preference file if possible?
  • FPVUALAB
  • FPVUALAB
29 Dec 2025 00:48
Replied by FPVUALAB on topic Bricked Mesa 7i92T
Bricked Mesa 7i92T
Hello. I need a breakout board for a Chinese circuit board (Mach3 interface board) 5Axis Breakout Board.
  • JT
  • JT's Avatar
28 Dec 2025 23:22
Replied by JT on topic Disable pushbutton
Disable pushbutton
Category: Flex GUI
Let me verify how to do that, it should be simple but I want to test first.
JT
  • MaHa
  • MaHa
28 Dec 2025 23:17
Replied by MaHa on topic Disable pushbutton
Disable pushbutton
Category: Flex GUI
With function mdi and command M66E0L0 the button is disabled while running a program and that doesn't affect its initial functionality. But still hoping there is another way to do that.
  • PCW
  • PCW's Avatar
28 Dec 2025 21:50
LinuxCNC + Mesa 7i43 – Axis A stepper (stepgen), error
Category: HAL
By error I mean:
What does LinuxCNC report?
Can you post the complete hal file?
  • manny
  • manny
28 Dec 2025 21:45
Category: HAL
I meant it as an error — I’m not sure how to configure it, what I’m doing wrong, and why the AXIS_A code is written incorrectly. please
  • Thllll
  • Thllll
28 Dec 2025 21:11
Replied by Thllll on topic Probe Error causes Jog lockout
Category: QtPyVCP
Axis works fine, QT dragon also works fine. Its just Probe Basic
Displaying 9181 - 9195 out of 12675 results.
Time to create page: 0.438 seconds
