  • Esaber
  • Esaber
20 Jul 2025 09:23
Plasmac to Qtplasmac conversion not working
Category: Plasmac
Hi guys. My migrated qtplasmac config (from plasmac) is not working as expected. The conversion ends with auccess but when I launch qtp both estop and power buttons are inactive, i.e clicking them does not do anything. The same buttons work fine in Axis. My setup uses the estop button (F1 keyboard button) in Axis to latch a relay and power on the plasma table central power unit and the F2 keyboard button to enable the Axis interface.  Both axis and qtp contain the same lines for estop-out and machine enable. I set estop mode to 2 (button) but I still get no sign of life when pressing the estop button. I have a physical estop button which is not connected to linuxcnc. It does cut off the plasma machine when activated. I will post the ini file for review.
  • jochen91
  • jochen91
20 Jul 2025 08:38 - 20 Jul 2025 08:47
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
I tried replacing the image links with uploaded files directly but i does not work.
Even files way smaller then 1.6Mb ( 1.1MB) the forum complains its to big. So I'm open for suggestions.
For the Rails: They are from the THK NRS Series. Size 35mm and 44mm overall height (Non standard)
Preload C0
5 x LRX carriages
1 x LR  carriages
Also the bolt pattern is a little bit odd. See Datasheet attached. If, by any change, you have this exact model, I'm definitely open for negotiations ;)
  • zzrzzr
  • zzrzzr
20 Jul 2025 06:06
PlasmaC Voltage Divider was created by zzrzzr
Category: Plasmac
i'm looking for a good plasmacutter that works with plasmac.
What if the plasmacutter doesn't have an internal voltage divider ? Then the THCAD 300 would be good, but its out of stock everywhere. What is the alternative if I want to use THAD 5 oder 10 ?
To buy a Proma voltage-divider or is there another professional-looking alternative ?
And maybe you can recommend a plasmacutter for plasmaC ?
Thanks.
  • tcbmetalworks
  • tcbmetalworks
20 Jul 2025 05:40
Automatic band saw marvel v10a was created by tcbmetalworks
Category: CNC Machines
I recently had a marvel v10a automatic band saw fall into my lap. It's in pretty rough shape and I am considering doing a restoration on it. I was told the electronics are in potentially broken condition. I think it would be a neat project to retrofit the control, and would be useful to be able to upload cut lists to the machine via USB to further automate the cutting process and have a hmi. The machine does not currently auto miter and only allows 1 direction mitering. I think I can modify it to miter both directions, but need to further investigate if i can I will try to add auto miter. This thread will serve as a build log if I make progress on the project. Has anyone seen any examples of retrofits being done on band saws? What would be the best way to go about taking on this project.
  • PCW
  • PCW's Avatar
20 Jul 2025 03:14
How to install kernel patch? (Moschip 9900)
Category: Installing LinuxCNC
You should not need to install any drivers.
Does
lspci -v
Show your card?
  • jor
  • jor's Avatar
20 Jul 2025 02:32
Hello all! I am very new to LinuxCNC and have question about how to install a kernel patch.
I have a PCIe parallel port card with a netmos 9900. The driver that came with does not work, and I found this patch on the kernel site:
git.kernel.org/pub/scm/linux/kernel/git/...6917eeda4284ed220079
In usr/src it shows my current version is 6.1.0-30, which I assume is the latest since I just downloaded it. The patch seems to be 6.08 (?)
My question is, can anyone guide me on how to install this patch? I found some information on patches that had "patch.gz" in the file extension, whereas this one seems to be "tar.gz" and those tutorials don't work.
Otherwise, does anyone know of some kind of guide or video on how to install this particular kind of patch? I apologize for this being such a general question, but I am very new and don't really know how linux kernel works!
Thank you in advance.
  • Benb
  • Benb's Avatar
19 Jul 2025 23:57
Inverting jogging sense of X Axis on a VistaCNC P1A-S pendant
Category: HAL
Try to change both the joint and the axis to the same sign:
net jog.0.cont-minus vc-p1as.jog.0.minus => halui.axis.x.plus halui.joint.0.plus
net jog.0.cont-plus vc-p1as.jog.0.plus => halui.axis.x.minus halui.joint.0.minus
  • Thayloreing
  • Thayloreing
19 Jul 2025 23:03
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello everyone,
I'm trying to use the NVEM V5 board with LinuxCNC, running the Remora RT1052 firmware.
✅ What has already been done:
1. The Remora RT1052 source code was downloaded directly from the official GitHub repository.
2. Inside the remora-rt1052/source/ folder, a new folder named default was created.
3. Inside the default folder, two files were created and configured:
defaultConfig.c
defaultConfig.h
4. These files were manually edited to define fixed pins for the NVEM V5, with the following configuration:
4 axes (X, Y, Z, A)
2 encoders
The remaining I/O as digital inputs and outputs
5. The project was successfully compiled using MCUXpresso IDE, generating a .bin file.
6. The .bin file was flashed correctly to the NVEM V5 using pyOCD, with no errors.
7. On the computer, the network interface was configured with a static IP, and the board responds to ping.
⚠️ What has not been done:
❌ The upload_config.py script was not used (the NVEM V5 does not support it).
❌ No remora.conf file was used.
❌ The HAL pins have not yet been defined in the .ini and .hal files, since the pins are fixed in the .bin.
❓ Current issue:
Even after all the steps above, LinuxCNC does not enable the machine (emergency state remains active). The NVEM board does not seem to start communication with the host, even though the IP is correctly configured and it responds to ping.
❓ Questions:
1. Is there any minimum requirement in the .hal or .ini files for LinuxCNC to properly initiate communication with fixed firmware?
2. What else could prevent the machine from exiting emergency, even with the correct fixed .bin?
3. Has anyone successfully used the NVEM V5 with fixed pins in the firmware, without using remora.conf?
  • PCW
  • PCW's Avatar
19 Jul 2025 22:51 - 19 Jul 2025 23:07
Replied by PCW on topic Y axis A slave help request
Jogging  a joint is not allowed (because it will rack the gantry)
You can jog the Y axis but only after homing is complete.
So if you don't have dual homing switches you need to setup immediate homing
Also unless you have a rotary A axis, there should be no mention of A anywhere
It would be a lot less confusing to refer to the Y Axis as Y and Y1
  • beefy
  • beefy
19 Jul 2025 22:15
Replied by beefy on topic XHC-WHB04B-6 not increasing MPG counts
Category: HAL
Thanks very much Finnengineering.
That's good to hear. I'll have another play with it in Halshow and see if I can set that pin.
  • rocket6delta
  • rocket6delta
19 Jul 2025 22:00
Replied by rocket6delta on topic 7i76EU Hal and Ini File
Category: HAL
Found it...looks like i have the wrong version?
therman@Debian-LinuxCNC:~$ linuxcnc -v
Verbose mode on
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
Where can i download the correct version?
  • rocket6delta
  • rocket6delta
19 Jul 2025 21:58
Category: HAL
Where can i see the Linux Version?
therman@Debian-LinuxCNC:~$ mesaflash --device ethernet --addr 10.10.10.10
ETH device 7I76EU at ip=10.10.10.10
  • PCW
  • PCW's Avatar
19 Jul 2025 21:45
Replied by PCW on topic 7i76EU Hal and Ini File
Category: HAL
That's very odd
I am assuming this is LinuxCNC 2.9.4?
I just tested 2.9.4 and a 7I76EU an the pin names are all prefixed with hm2_7i76e
as expected
What does
report?
  • Esaber
  • Esaber
19 Jul 2025 20:49
Replied by Esaber on topic Esab Ultrarex UXD-P2000 Upgrade Project
Category: Plasma & Laser
So I found a 7i77 on ebay. Put it in and all is good. I then tried qtplasmac and converted the old file to qtplasmac but no luck enabling the machine ! I did set the estop button to mode 2 but estop does not move and power button does not move. Same ini file settings work fine in linuxcnc axis mode. I have a physical estop by the way.
Displaying 12016 - 12030 out of 17316 results.
Time to create page: 0.390 seconds
