  • PCW
  • PCW's Avatar
22 Jun 2025 21:04
Replied by PCW on topic Spindle speed?
Spindle speed?
Category: Basic Configuration
In cases where you have an unsigned spindle speed device (like an analog 0..10V VFD)
and encoder feedback, It might be better to use the signed commanded spindle speed
into the PID and just use the ABS on the output of the PID component to always get positive
analog values and also use the ABS components is_positive and is_negative pins for driving
the VFDs FWD/REV controls.
  • meister
  • meister
22 Jun 2025 21:02
Replied by meister on topic EasyCAT Arduino shield
Category: EtherCAT
ready for testing:
github.com/multigcs/esitool/
there are some testfiles in tests/
and they are all bit exactly as generated by the siitool
but i need more testfiles and maybe some tester
  • PCW
  • PCW's Avatar
22 Jun 2025 20:49
homing with Phase Z encoder on MESA 7i96s
That points to hardware issues, are you sure:
The index wiring is correct.
The encoders actually have an index output.
  • JackRay
  • JackRay
22 Jun 2025 20:22
Replied by JackRay on topic homing with Phase Z encoder on MESA 7i96s
i do that, but never nothing
  • Aciera
  • Aciera's Avatar
22 Jun 2025 19:59
Issue with Inverse Kinematics Failing During Homing – 3-Axis Robot with LinuxCNC
Category: HAL
Note that 'genserkins' uses 'modified' DH parameters.
Have a look here (there is also an example of how to derive the parameters for a manipulator):
www.linuxcnc.org/docs/stable/html/motion...ml#cha:dh-parameters
  • andypugh
  • andypugh's Avatar
22 Jun 2025 19:50
Category: HAL
Do the joints not move at all when you try to home them?
As a short-term expedient you can turn off the requirement to home (INI NO_FORCE_HOMING) and (if you are using the Axis interface) switch to world mode with Ctrl-$.
But don't forget that then the machine will have no idea where the joints are, so the end-effector motion will be a very curly version of cartesian.
  • andypugh
  • andypugh's Avatar
22 Jun 2025 19:36
Replied by andypugh on topic Weird problem happening during g71, g70 cycle
"Bad character" should tell you which line of the G-code the error is on. This is much more likley to be a problem in your G-code than in the G71 code. (not that I exclude that possibility)
  • andypugh
  • andypugh's Avatar
22 Jun 2025 19:13
Replied by andypugh on topic Spindle speed?
Spindle speed?
At a guess you have closed-loop control of the spindle, but the PID is being commanded by absolute spindle speed request.
  • andypugh
  • andypugh's Avatar
22 Jun 2025 19:07
Replaced Hard drive - now my 'fast move' (SHIFT->arrow |PgUp/PgDn is not working
I am not sure why you used Stepconf at all. You should have been able to just copy the old "linuxcnc" directory from one drive to the other, and carry on as before.
  • andypugh
  • andypugh's Avatar
22 Jun 2025 19:04
M6 shuts off spindle, but no UI confirmation, and program doesn't pause
M3 probably _could_ be remappable. It would just need the hooks adding to the code. After literally seconds of contemplation I can't think of anything that means it fundamentally couldn't be remapped if the code was modified to handle it.
  • lex200
  • lex200
22 Jun 2025 19:04
Category: HAL
The issue is that I'm not even able to move the robot arm, because it requires me to perform a 'Home All' operation before initiating any movement. I'm 90% sure that the problem lies in the incorrect application of DH parameters on my part. The tricky part is that it's so simple, I have no further idea what could be going wrong. I've been stuck at this point for a couple of days now, and still no progress. Later, I plan to rebuild the project from scratch to avoid any unnecessary correlations with the original Puma source files. Maybe that will help.
  • andypugh
  • andypugh's Avatar
22 Jun 2025 18:46
Replied by andypugh on topic Error compiling modbus configuration file
My guess would be that you lost the { at the end of
static const hm2_modbus_chan_descriptor_t channels[] = {
or possibly the one that terminates that set.
If you still have the good and bad files, then could you attach them? I don't think that I can make the compiler more helpful in it's error messages, but possibly the preprocessor could be.
  • Creative25
  • Creative25
22 Jun 2025 18:36
Replied by Creative25 on topic TB 6600 getting hot
TB 6600 getting hot
Category: Driver Boards
How good are the clones they sell o AliExpress?
Has anyone tried one of these on a Nena 23 motors.
embeddedtronicsblog.wordpress.com/2020/06/24/tmc2160/
  • andypugh
  • andypugh's Avatar
22 Jun 2025 18:36
Category: HAL
Note that all that I know about kinematics is that it confuses me...
Forward kinematics takes the joint positions and calculates the end effector position. This will always work and will always return exactly one solution.
Inverse kins takes the required end effector position and calculates the joint positions to achieve that. Sometimes there is no solution (because the arm simply can't reach that point). Sometimes there are multiple solutions (in fact there _generaly_ are.
So, the kins has to choose a solution. And sometimes it can lock itself in a corner, where there are solutions for the current position, and for the next position, but it would have to pass through a "wrong" position to get there.
This isn't just robots. I am sure you have been in this position with your own arms.... The difference is that you have a brain and are not blindly following what is basically a relatively simple mathematical equation which has no predictive capability.
So, back to your questiion: Homing happens in joint space, using forward kinematics. So presumably you only see the error after homing is completed, and the system switches to "world mode" and inverse kins.
Maybe your home position (in XYZABC rather than joint angles) simply isn't reachable? (or, doesn't _actually_ correspond to the joints-homed position?)
  • Aciera
  • Aciera's Avatar
22 Jun 2025 18:34 - 22 Jun 2025 18:38
Axis view options are not persistant between sessions. Any thoughts?
Category: AXIS
I see.
Looking at line 2968 makes me think that 'hide pyvcp' was simply not intended to be persistent by the original author:
github.com/LinuxCNC/linuxcnc/commit/6948...6d967654a7R250-R2968
Displaying 13051 - 13065 out of 17379 results.
Time to create page: 0.488 seconds
