  • low-blip
  • low-blip
19 May 2025 09:44
Actual position and Commanded position differ, using cia402 [SOLVED]
Category: Basic Configuration
I can't jog or do anything after running a program, I get motor position error on xyz axes afterwards and have to restart linuxcnc before I can reconnect to the machine. Same thing if I run a few lines in MDI mode and switch back to manual control.
Yes the x, y and z axes are driven by leadscrews.
Yes they are stepper motors.
I did double check the unit last week, we have everything set in mm. I wish it was as simple as that.
  • Hakan
  • Hakan
19 May 2025 09:17
Lcnc & Ethercat data types, Ethercat automated hal pin setup.
I've calmed down now :) and want to try the ecad.so module.
I searched around a bit after your code, but don't know how to pull code for ecad, or how to build it.
Can you provide some instruction?
Also, do I need your version of lcec and lcec_conf? Seems old, it didn't recognize float-ieee haltype.
And you have Ethercat master code, do I need that or can I use the distributed apt packaged one?
  • MRx
  • MRx
19 May 2025 09:08 - 19 May 2025 09:15
Replied by MRx on topic Mitsubishi SSCNET
Mitsubishi SSCNET
Category: Installing LinuxCNC
I wonder did you fully reverse engineer the commands for velocity mode?
Are you sending exactly the same values as the original controllers do for the selected RPM?
When I had a look at it last time I found out that the values don't directly translate to the requested RPM value, at least there's no linear mapping, it is a little bit off from time to time.
  • unknown
  • unknown
19 May 2025 07:48
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Read through this thread, there is an example in this very thread.
  • zmrdko
  • zmrdko's Avatar
19 May 2025 07:03
Replied by zmrdko on topic absolute encoders with dual axis
you should have homing to index enabled and working, then you have to align gantry to be perfect square, when homed. And if you use velocity mode with PID, then the linuxcnc uses real feedback from motor encoders. So if you disable servos, and move axis by hand, the position is reflected in linuxcnc and you dont have to re-home. Same with gantry. it will square back.
  • Aciera
  • Aciera's Avatar
19 May 2025 06:31
Replied by Aciera on topic Activate B-axis in Porbe Basic
Category: QtPyVCP
The best option would be to add 'XYZBC' mode to 'probe_basic.ui'. If that is not something you can do then you'll have to convert to 'XYZAC' as you mentioned or hope that @Lcvette has a look at this issue.
  • mikereid0817
  • mikereid0817
19 May 2025 03:40
I have installed the PI5 image (25-01-27) and have gotten everything working EXCEPT the hal_gpio input pins. Outputs...done, inputs... no luck. I can read the input pins with GPIO from python... but not within linuxcnc.
Any ideas?
  • snowgoer540
  • snowgoer540's Avatar
19 May 2025 02:20
Replied by snowgoer540 on topic Ohmic probe aborts immediately
Category: Plasmac
The OHMIC TEST button does not move the Z axis.  The intent is to see if there is a short between the torch tip and the ohmic lead (a ball of oxide can do this, or water from a water table).
User Manual Explanation of OHMIC TEST
If you do have a short, or you create a short to test it, you also need to hold the button to get the OHMIC light to light up in the GUI as there is sometimes a delay.  The click you are doing is far too fast.
  • cmorley
  • cmorley
18 May 2025 23:13
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
Ok I tried fixing it again :)
  • Dave2024
  • Dave2024's Avatar
18 May 2025 23:11
Replied by Dave2024 on topic New side panel and axisui pins
Category: AXIS
Hey that is awesome how you customized the Axis interface like that. Is there a way I can get a copy of that to use on my machine? I really need a search feature in Axis for the GCode so I'm able to goto a specific line and rerun the cut. Like so Im able to search for M6 T1 or M6 T3, T4, T5, etc.... and then re-run the code from that line after changing the tool diameter and making fine tuning of the parts using cutter compensation and or fine tuning the coordinate shifts. Anyways cool! I need this too
  • unknown
  • unknown
18 May 2025 22:10
Replied by unknown on topic Important Info Regarding Rpi4/5 Images.
It was dist-upgrade being the issue, upgrade is fine as the kernel is pinned anyways.
As usual your comments add nothing to the discussion.
  • JPeters
  • JPeters
18 May 2025 22:06
Hello scotta,
thank you for your quick reply. Yes, that is exactly what I thought myself.
The EC500 is powered by an external power supply. From the 6 pin header, GND, SCK and SDO have been connected to one of the probes.
I don´t have any kind of schematic on hands for the EC500. So I am not shure, why the header pin is labeled SDO. I would expect SDIO for a sufficient SWD connector. Is your header labeled with a SDO too?
My EC500 is labeled with IMXR_EC500 2023-05-18
Up to now, there has not been a single successful flash. From within MCUExpresso, I am at least able to build your application.
If this is not going to be successful: do you think, your actual project with W5500 and raspberry pi pico is as powerful as the 1052 solution and could be a viable alternative?
Thank you very much. I will try to give more details tomorrow.
Cheers Julius
  • Thayloreing
  • Thayloreing
18 May 2025 21:11
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi Scotta, do you happen to know what the error I'm having means? It seems like it's not communicating with the cloud in any way.
  • scotta
  • scotta's Avatar
18 May 2025 20:45
Hi Julius,
Very strange that one of those combinations don't work, especially MCUExpressoIDE.
For flashing
1. board is externally powered from 24v, so no VCC connection
2. GND, SCK and SWDIO is all the connections needed to the CMSIS-DAP probe
When I've experienced connection issues, powering on the board as the probe is trying to connect to the MCU has helped.
Displaying 14686 - 14700 out of 17468 results.
Time to create page: 0.495 seconds
