  • Spyderbreath
  • Spyderbreath's Avatar
29 Apr 2025 11:03
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Good day all. I seem to be having a bit to trouble getting started. I have an NVEM V5 controller and RPI 5 with LinuxCNC installed. Is there anywhere on planet earth that has a start to finish, all in one place, all on one page, set of instructions or video that will tell me what version of what software from what source to use in what way using what commands and what wires to hook up where to get it all done with the hardware I have. I have gone through 100's of posts and can grasp the general concepts of what needs to be done but it's a small and sometimes incomplete piece of info from 1 post and then one has to read 5 or 20 more before the rest of the info is found. In the end, and totally a flaw of my own, I seem unable to pull all of this scattered info together and have it make any sense as to how to get from start to finish without burning something up or creating an unsalvageable mess.
I found a video by Scott 3D on youtube but it is 3 years old and several key points are just blown by with no explanation and no info on exactly what versions of what from where is needed today.
Is there a single set of complete instructions with valid links in existence anywhere for setting up an NVEM v5 with LinuxCNC?
  • Muftijaja
  • Muftijaja
29 Apr 2025 11:02 - 29 Apr 2025 12:11
motor-0-position error beim Abbremsen aus 4-7,5 m/min
Category: Deutsch
This is my last effort to get the ping down. I set the Cool Option to thermally optimized, a cool&quiet option in BIOS. Other settings would bee acoustic optimized or full throttle. I hope it does not affect anything of cpu clocks.
rtt min/avg/max/mdev = 0.105/0.126/0.259/0.002 ms  what do you think?
Greetings, Hanno
  • Muftijaja
  • Muftijaja
29 Apr 2025 10:40 - 29 Apr 2025 10:42
Category: Deutsch
Hi, I tried a lot the last days.
I set the P to 500 as you said, I made the realtec optional kernel settings, i took a look for Energy efficiency and did not find anything of this, I set ff2 back to 0, and in the first try (an air run of my last part) it seemed to run - but 2 min after start the motor-0-position error came again, right in a direction change of the path. As before.
That was very disappointing, so I decided to get another PC from the shelf, a Lenovo m910q with 16GB, i7-6700T 4C/8T and put the SSD from the other in it.
The machine started at once, no problems to fix, I declined all BIOS settings that are described in the latency thread. This jounger PC has WLAN for the Internet and a I219-LM Intel network card, that should be better, somebody told me.
I did the coalescence workaround in etc/interfaces, I made the ethtool working (sudo ethtool -C enp0s31f6 rx-usecs 0), I made the kernel options:   quiet irqaffinity=0,1 isolcpus=3 intel_idle.max_cstate=1 i915.enable_rc6=0
The outcome was not bad, but worse than before, regarding the ping times. The realtec gave me 0,056-0,070, the intel gives out:
rtt min/avg/max/mdev = 0.165/0.189/0.307/0.052 ms which is bad in my eyes.
Even if i kill the WLAN adapter, it does not much better:
111 packets transmitted, 111 received, 0% packet loss, time 112114ms
rtt min/avg/max/mdev = 0.108/0.164/0.199/0.011 ms
What do you think about it? should I go down to the machine and try it out or should I do sthing else?
Thanks for your advice, I appreciate that much!
Hanno
  • zmrdko
  • zmrdko's Avatar
29 Apr 2025 10:24
Replied by zmrdko on topic LinuxCNC S-Curve Accelerations
it worked on my Delta B3 Ethercat servos using CIA402/CSP config (see attachment).
i used linuxcnc-scurve-compat  from codeberg.
  • DarkPhoinix
  • DarkPhoinix
29 Apr 2025 10:23
Replied by DarkPhoinix on topic [SOLVED]linuxcnc Latency test ambiguous results
I still don't have the steppers or the drivers, I hope they will arrive soon, for now I have tested with only this stepper and driver connected:
thinking this was the problem I disconnected the stepper and left the card alone but the error is the same as soon as I start a video on YouTube or if I start chrt 99 ping -i .001 10.10.10.10 -c 40000000
the file conf:
File Name: nvem-rt1052.hal
File Size:3 KB
File Name: nvem-rt1052.ini
File Size:5 KB
File Name: nvem-rt1052.txt
File Size:7 KB
driver:TB6560 JP-1635A
stepper: 57HD0401 15SB
controller: NVEM V5
Stepper and driver is only for test not final hardware.
  • emresensoy
  • emresensoy
29 Apr 2025 09:22
Replied by emresensoy on topic QtPyVCP designer plugin fails
Category: QtPyVCP
--SOLVED--
with activating on terminal;
source venv/bin/activate
then I run editvcp and select config.yml file
everything is ok now
  • Surmetall
  • Surmetall's Avatar
29 Apr 2025 09:19
WEMAS MT 32 CNC Lathe -> LinuxCNC - Mesa or EtherCAT?
Category: Turning
What do you mean with "SoE"?
Maybe i try to get a used Beckhoff AX5xx from eBay when thats easyer to use with LCNC.
... the SIEMENS etherCAT pcb is hard to get. it starts to annoying me...
endian post=327010 userid=29161
AX5xxx from beckhoff is SoE and it can be pain to create custom .xml which should be editable out of Sachas own .xml files...
  • rodw
  • rodw's Avatar
29 Apr 2025 09:11
Replied by rodw on topic Tandem Y Axis in stepconf assistance.
Category: StepConf Wizard
Rod, why?
He did not confirm that the machine has switches on both sides yet, so why send him that way, he will end up with a mangled machine.
Well he did say
I would imagine that it does. All the documentation suggests so and from what i can see on the other side (Its right up against a wall) It looks the same on both sides so I would wager it has them on both. So im going with yes on that.
  • stenly
  • stenly
29 Apr 2025 09:09
Implementing Spindle Homing for DELTA C2000 Plus (In)correctly?
Category: EtherCAT
I have managed to make some progress over the past weeks.
I believe I managed to add homing properly to the DeMS300 driver, however I am now facing the issue that the homing mode PDOs 6099, 607C and 609A (respectively homing speed, homing offset and homing accel.) are simply not showing up. Hence why the driver fails to initialize them. Interestingly 6098, the homing method, does show up on
ethercat pdos
, but the other 3 do not. This makes the drive give the motor a current and fixes it in place, however it is not able to start the homing procedure and just stays in place. The control and status words look entirely correct, so my assumption is that the missing 6099, 607C and 609A PDOs are causing it to be unable to start homing.
As you can see in the driver I modified, those PDOs are commented out at the initialization (on lines 225-227). Uncommenting them has the driver compile successfully, yet it fails to start as it is unable to initialize them. I am not sure how I should initialize them properly. In the header file I changed LCEC_DEMS300_PDOS to 15 as well (it used to be 11).
Do you think the PDO mappings are the problem here? I had no success in establishing a connection over TwinCAT, but I may need to look into that again.
  • Neiji_msk
  • Neiji_msk
29 Apr 2025 08:36
Replied by Neiji_msk on topic EtherCAT and selfmade driver
Category: EtherCAT
No, its random driver without any documentation (2abs servo driver)
  • Hakan
  • Hakan
29 Apr 2025 08:34
First time to try build my xml for not listed ethercat in-out component
Category: EtherCAT
You can't get the ECL16DP to show up on the ethercat bus?
This is the unit, right?
There sure seems to be an ETH1 and an ETH2.
There is nothing on "ethercat slaves" when you connect to ETH1 and power on?
  • dannym
  • dannym
29 Apr 2025 08:15
Replied by dannym on topic Z axis is being controlled by A
Category: Basic Configuration
Ah, ok, now things make sense.
That is actually the MX4660. But I had that servo with the built-in drive so I was only going to use 3 channels. The stepper power output channel plugs are a row under another row of plugs, hard to see, I didn't realize I skipped the 3rd and had the Z hooked to the 4th channel.
  • Hakan
  • Hakan
29 Apr 2025 07:47
Replied by Hakan on topic General Questions about using ethercat
Category: EtherCAT
A common error is to not have the right vid and pid in the ethercat-conf.xml file.
Double-check that the vendor id and product code from the output of
ethercat slaves -p 0 -v
matches the vid and pid fields in ethercat-conf.xml.
Check that for all slaves (0,1,2,etc)
If that didn't help please attach the ethercat-conf.xml file, the hal file and the output of "ethercat slaves -v"
  • Hakan
  • Hakan
29 Apr 2025 07:33
Replied by Hakan on topic EtherCAT and selfmade driver
Category: EtherCAT
The hal and ini files are empty.
Is it the VEICHI SD700 drive www.veichi.com/product/sd700-high-performance-servo-system.html?
  • Neiji_msk
  • Neiji_msk
29 Apr 2025 07:11 - 29 Apr 2025 09:46
EtherCAT and selfmade driver was created by Neiji_msk
Category: EtherCAT
Hello everyone, I ask for help, I encountered a problem connecting the driver via etcherkat, everything is displayed via the terminal and the driver is visible, but when I launch Linux, the driver does not move. In my case, the driver is connected directly to the PC, and does not go into OP mode. I tried to connect to the delta drivers and everything worked. Unfortunately, there are no instructions for my driver. My assembly (hal, ini and xml files):
Displaying 16066 - 16080 out of 17395 results.
Time to create page: 0.498 seconds
