19 Apr 2025 11:42
Replied by tommylight on topic 7i80db 7i77 + 7i76 serup Hal conf
Category: Driver Boards
OK,
Mesa 7i76 to connector J2
Mesa 7i77 to connector J4
  • BloodyT
  • BloodyT
19 Apr 2025 11:40
Replied by BloodyT on topic 7i95T & 7i77
7i95T & 7i77
Category: Basic Configuration
thanks!
7i72: oh shi.... sorry... I missed that somehow.
tried mesact with it, sadly does not put out any working stuff.
pncconf did!
machine is starting and I can jog until following error again.
in general:
if I don't want to wire encoders to the mesa, I have no feedback. so far I understand. But is that a bad thing? It would be like running with steppers open loop, isn't it?
I thought it should work, as it obviously did successfully with the old (now dead) controller before for years (so far I looked up all signals that came from the old controller was analog voltage, all feedback is in servo controllers)
if I connect back the error signal from the servo drives I should be able to estop if thinks go out of control. just like I know from another project with stepper drives. that at least was my thought to remove complexity , since I am completely new to servos.
is that a completely bad idea in your opinion?
In Office I can't test with motors because they are 400v... also the machine is a few km away and I am trying to prepare it, until I can come back to it.
I just wanted to test whether or not I get +-10v on the ports to make sure it's virtually wired correctly. Also I want to try if I can cancel movement with e-stop. is at least have to find a way to ignore feedback for now, to have room to elaborate my config. it would be kind of sad to drive there just to see I missed something essential to test-drive or tune.
i also found the 7i77 servo tune post, wich I am currently reading to get used to what I need to do in future.
any workflows / hints appreciated.
as I said, I am a beginner and just trying to figure out things, bumping into new stuff on the way
Thanks for your patience and answers
  • GDTH
  • GDTH's Avatar
19 Apr 2025 11:39
Replied by GDTH on topic 7i80db 7i77 + 7i76 serup Hal conf
mesaflash --device ETHER --readhmid --addr 192.168.1.121 gives:
Configuration Name: HOSTMOT2
  BoardName : MESA7I80
  FPGA Size: 25 KGates
  FPGA Pins: 256
  Number of IO Ports: 4
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: IOPort
  There are 4 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: MuxedQCount
  There are 16 of MuxedQCount in configuration
  Version: 3
  Registers: 5
  BaseAddress: 3500
  Module: MuxedQCountSel
  There are 1 of MuxedQCountSel in configuration
  Version: 0
  Registers: 0
  BaseAddress: 0000
  Module: StepGen
  There are 16 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: SSerial
  There are 2 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5A00
  Instance Stride: 64 bytes
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for J2
DB25 pin#             I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                      0   IOPort       StepGen          0        Dir/Table2      (Out)
14                      1   IOPort       StepGen          0        Step/Table1     (Out)
 2                      2   IOPort       StepGen          1        Dir/Table2      (Out)
15                      3   IOPort       StepGen          1        Step/Table1     (Out)
 3                      4   IOPort       StepGen          2        Dir/Table2      (Out)
16                      5   IOPort       StepGen          2        Step/Table1     (Out)
 4                      6   IOPort       StepGen          3        Dir/Table2      (Out)
17                      7   IOPort       StepGen          3        Step/Table1     (Out)
 5                      8   IOPort       StepGen          4        Dir/Table2      (Out)
 6                      9   IOPort       StepGen          4        Step/Table1     (Out)
 7                     10   IOPort       SSerial          0        TXData0         (Out)
 8                     11   IOPort       SSerial          0        RXData0         (In)
 9                     12   IOPort       SSerial          0        TXData1         (Out)
10                     13   IOPort       SSerial          0        RXData1         (In)
11                     14   IOPort       MuxedQCount      6        MuxQ-IDX        (In)
12                     15   IOPort       MuxedQCount      6        MuxQ-B          (In)
13                     16   IOPort       MuxedQCount      6        MuxQ-A          (In)
IO Connections for J3
 1                     17   IOPort       StepGen          5        Dir/Table2      (Out)
14                     18   IOPort       StepGen          5        Step/Table1     (Out)
 2                     19   IOPort       StepGen          6        Dir/Table2      (Out)
15                     20   IOPort       StepGen          6        Step/Table1     (Out)
 3                     21   IOPort       StepGen          7        Dir/Table2      (Out)
16                     22   IOPort       StepGen          7        Step/Table1     (Out)
 4                     23   IOPort       StepGen          8        Dir/Table2      (Out)
17                     24   IOPort       StepGen          8        Step/Table1     (Out)
 5                     25   IOPort       StepGen          9        Dir/Table2      (Out)
 6                     26   IOPort       StepGen          9        Step/Table1     (Out)
 7                     27   IOPort       SSerial          0        TXData2         (Out)
 8                     28   IOPort       SSerial          0        RXData2         (In)
 9                     29   IOPort       SSerial          0        TXData3         (Out)
10                     30   IOPort       SSerial          0        RXData3         (In)
11                     31   IOPort       MuxedQCount      7        MuxQ-IDX        (In)
12                     32   IOPort       MuxedQCount      7        MuxQ-B          (In)
13                     33   IOPort       MuxedQCount      7        MuxQ-A          (In)
IO Connections for J4
 1                     34   IOPort       SSerial          1        TXEn2           (Out)
14                     35   IOPort       SSerial          1        TXData2         (Out)
 2                     36   IOPort       SSerial          1        RXData2         (In)
15                     37   IOPort       SSerial          1        TXData1         (Out)
 3                     38   IOPort       SSerial          1        RXData1         (In)
16                     39   IOPort       SSerial          1        TXData0         (Out)
 4                     40   IOPort       SSerial          1        RXData0         (In)
17                     41   IOPort       MuxedQCountSel   0        MuxSel0         (Out)
 5                     42   IOPort       MuxedQCount      0        MuxQ-A          (In)
 6                     43   IOPort       MuxedQCount      0        MuxQ-B          (In)
 7                     44   IOPort       MuxedQCount      0        MuxQ-IDX        (In)
 8                     45   IOPort       MuxedQCount      1        MuxQ-A          (In)
 9                     46   IOPort       MuxedQCount      1        MuxQ-B          (In)
10                     47   IOPort       MuxedQCount      1        MuxQ-IDX        (In)
11                     48   IOPort       MuxedQCount      2        MuxQ-A          (In)
12                     49   IOPort       MuxedQCount      2        MuxQ-B          (In)
13                     50   IOPort       MuxedQCount      2        MuxQ-IDX        (In)
IO Connections for J5
 1                     51   IOPort       SSerial          1        TXEn5           (Out)
14                     52   IOPort       SSerial          1        TXData5         (Out)
 2                     53   IOPort       SSerial          1        RXData5         (In)
15                     54   IOPort       SSerial          1        TXData4         (Out)
 3                     55   IOPort       SSerial          1        RXData4         (In)
16                     56   IOPort       SSerial          1        TXData3         (Out)
 4                     57   IOPort       SSerial          1        RXData3         (In)
17                     58   IOPort       MuxedQCountSel   6        MuxSel0         (Out)
 5                     59   IOPort       MuxedQCount      3        MuxQ-A          (In)
 6                     60   IOPort       MuxedQCount      3        MuxQ-B          (In)
 7                     61   IOPort       MuxedQCount      3        MuxQ-IDX        (In)
 8                     62   IOPort       MuxedQCount      4        MuxQ-A          (In)
 9                     63   IOPort       MuxedQCount      4        MuxQ-B          (In)
10                     64   IOPort       MuxedQCount      4        MuxQ-IDX        (In)
11                     65   IOPort       MuxedQCount      5        MuxQ-A          (In)
12                     66   IOPort       MuxedQCount      5        MuxQ-B          (In)
13                     67   IOPort       MuxedQCount      5        MuxQ-IDX        (In)
19 Apr 2025 11:35
What does
report?
  • GDTH
  • GDTH's Avatar
19 Apr 2025 11:31
7i80db 7i77 + 7i76 serup Hal conf was created by GDTH
Hello,
I am trying to get a 7i80db-25 working with a 7i77 and a 7i76. I have installed a bitfile that should make this possible. When I start up linuxcnc I am not able to find the 7i77 and 7i76 board in the Hal conf. I was expecting something like hm2_7i80.0.7i77.input.
Am I doing something wrong or is it normal to just have a gpio list. If so how do I know what is connected to what.
19 Apr 2025 11:30 - 19 Apr 2025 11:38
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
As requested, deleted the empty posts.
For future reference, all users are able to delete their own posts.
Edit:
Apparently you did try and failed to delete the posts.
Can you edit them?
No matter what or how, feel free to do the same, namely request us to delete the posts.
Thank you.
19 Apr 2025 11:27
Replied by tommylight on topic Black Friday Deal got me :)
Category: Plasma & Laser
Music was nice! :)
  • IB_CnC
  • IB_CnC
19 Apr 2025 10:45 - 19 Apr 2025 10:50
Probe Basic and Carousel ATC with Geneva and Stepper
Category: QtPyVCP
I think I already found most of what I was looking for, as I just found:
github.com/kcjengr/probe_basic/blob/main...toolchange_index.hal :-))
Still have to find out the best approach to map the stepper drive signal in velocity mode to
net car-ccw motion.digital-out-03
net car-cw motion.digital-out-04
  • IB_CnC
  • IB_CnC
19 Apr 2025 10:34 - 19 Apr 2025 10:38
Category: QtPyVCP
Hi, i've build a gantry piggy back toolchanger for my router, driven by a stepper (with gear reduction) and a geneva wheel, and am looking for some quick pointers.
At this point I've got it to rotate, creating an extra axis in HAL / INI, nothing else.
I was planning to use the stepper 'velocity mode' to drive the stepper.
I envision I need to place two proximity sensors:
  1. Prox sensor for homing pin
  2. Prox sensor to detect an index step, for counting logic of the pockets
    How does the base Probe Basic configuration handle pocket homing (locating pocket nr 1), counting pockets and the drive signals to the motor?
    Some clips of the geneva mechanism:
  • IB_CnC
  • IB_CnC
19 Apr 2025 10:27 - 20 Apr 2025 00:01
Replied by IB_CnC on topic Losing some values after PB restart
Category: QtPyVCP
Small update:
After updating almost all values get stored and recalled correctly.
One exception seems to be the Spindle_zero.
If manually entered, it doesn't get stored and recalled.
If measured via subroutine, it does get stored an recalled on restart of PB.
(Subroutine folder is up to date)
  • DarkPhoinix
  • DarkPhoinix
19 Apr 2025 10:27
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
These are photos showing different connection diagrams with swdio and swclk reversed
  • Grotius
  • Grotius's Avatar
19 Apr 2025 10:01
Replied by Grotius on topic Strange behaviour of custom component
Hi Endian,
Here is a example for you. I assume you can clone the repository, do the install script.
Then you can try it out.
  • DarkPhoinix
  • DarkPhoinix
19 Apr 2025 09:58 - 19 Apr 2025 10:46
pyocd reset --target mimxrt1050_quadspi
pyocd erase --chip --target mimxrt1050_quadspi
pyocd flash remora-rt1052-3.1.3.bin --target mimxrt1050_quadspi
I tried with stlink and j-link with errors.I also tried reversing swdio and swclk, because I saw images of pins connected differently.
  • DarkPhoinix
  • DarkPhoinix
19 Apr 2025 09:44
Hey Scott,
Sorry to bug you again, but just wanted to let you know I finally managed to flash the firmware and ping 10.10.10.10! Next up is diving into the LinuxCNC side of things.
I’m planning to document everything I did to get it all working and might make a YouTube video showing the steps once my exams are out of the way next week. Also, I was thinking it’d be cool to contribute to the project documentation if there’s any way I can help out.
Thanks again for all your help – really appreciate it!
how did you solve the flash problems?
could you please insert the strings you inserted? Photos of the connection pins? Did you power the NVEM V5 at 12V or 24V? Did you press the button?
  • Grotius
  • Grotius's Avatar
19 Apr 2025 08:38
Replied by Grotius on topic LinuxCNC S-Curve Accelerations
Hi Rod,
The planner is indeed in it's own folder under src/emc/planner link
It uses the original Makefile to build the planner.
If you use 2 different build systems we experienced a kind off linking errors. Resulting that
the motmod.so and liblinuxcnchal.so had to be recompiled by cmake. But the excact reason why
this is, is unknown for me.
Displaying 16546 - 16560 out of 17456 results.
Time to create page: 1.112 seconds
