  • mariusl
  • mariusl's Avatar
14 Apr 2025 06:53 - 14 Apr 2025 06:55
Problem with THC was created by mariusl
Problem with THC
Category: Plasmac
I have a machine that has a Hypertherm 105 Sync source on and I am having issues getting the THC to work correctly.
I had to adjust the THC_delay to 5 seconds before I could get a stable voltage reading for Autovolts. The torch will go down to the cut height but starts moving upwards before the THC_delay has timed out. The cut voltage seems to settle at 55V but the torch moves up until it reaches 75V and stays there.
The strange thing is it will cut the first cut correct and then misbehaves after that.
Any ideas where to fiddle?
  • Aciera
  • Aciera's Avatar
14 Apr 2025 06:48
Replied by Aciera on topic CNC doesn't work with new update
As the debug message indicates, line 6 in your 'Slabber.hal' expects a value for the keyword 'AXES' in the [TRAJ] section of your ini file.
  • Aciera
  • Aciera's Avatar
14 Apr 2025 06:45
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
Not sure, halcompile output looks ok. Starting your config from a terminal may give more debug information.
$ linuxcnc
  • sameedansar
  • sameedansar
14 Apr 2025 06:33
Steppers motor start moving without any commads being given
Thank you, everyone, for your responses. Really appreciate it!
We had already connected the negative direction and step pins of the TB6600 driver to ground using a pull-down resistor. After taking PCW's advice and supplying 5V to our breakout board via the USB cable, all our problems with erroneous movements and strange noises disappeared.
Points to note, though:
We had already made the ground common across the whole system.
Optocouplers are pre-installed on this breakout board.
  • theslawek
  • theslawek
14 Apr 2025 06:16
Need help making rotary axis behave like second spindle
Easiest way would be to make another config.
leave the old one for when you need position.
In the new config change the A to be a spindle.
Lookup step and direction spindle for examples. If you dont want to mess with it I could do it for you.
Then it should work as you intend with me s1000 $1
Yes, I would plan to have an alternative config for this use case.
I've already searched around and tried tweaking things, but wasn't getting any success. I think I may be getting stuck up on the motion related HAL entries but I'm not sure. I would be very grateful if you could sort it out for me.
Does this help at all?
wiki.linuxcnc.org/uploads/orient.svg
It's one potential way to do it.
Andy, I wouldn't know where to start with this.
  • tcbmetalworks
  • tcbmetalworks
14 Apr 2025 05:43
Replied by tcbmetalworks on topic 10.5 x 25 cnc plasma table retrofit
Upon further investigation I think these motors do not have the ability to speed control at the precision required. They are more for like a conveyor system pre set the speed and let er rip or control it with a potentiometer. I think they could still be very useful for projects around the shop maybe to power a few bridge Cranes that don't roll as nicely as they should anymore.
  • unknown
  • unknown
14 Apr 2025 04:41
Replied by unknown on topic 7i92 firmware issue
7i92 firmware issue
Category: Driver Boards
I think it might be a comms issue relating to the filtering issue around the internal voltage regs. All the ref designs I've seen use 4.7uf cap with the 2 100nf with the inductor. I'll have to wait for some caps to come in.
Using openFGPALoader with the flash over SPI works fine (load a config directly to the FPGA then communicates with the FPGA ), so I can reliably write to the flash.
Looking at a session with wireshark, the board stops comms first. And the time it takes to happen can be kind of random. I'm prepared to accept that the design may not just work due to "Reasons" (bad layout, signal trace lengths, lack of knowledge of my behalf). I may have to read the mesaflash code and work out the programming protocol to get a better understanding.
  • notJamesLee
  • notJamesLee
14 Apr 2025 03:44
Determining Angular Scale - Help w/ Microsteps
Category: Configuration Tools
Hi Friends,
I am pulling my hair out trying to determine how many steps it take for my angular C axis to make one full revolution. I recently had to redesign the tangential cutting head so while I had it off the machine I wanted to tune it as much as possible with the tools i had available  (scale, min max jog speed, etc)
So i set out to determine how many steps it would take the motor to rotate the output shaft one full revolution. After a few days of doing what I thought was simple calculations to little to no success I tried to go bottom up. That is, hard coding the number of steps and adjusting based on behavior. this took like 5 minutes to get it pretty close.. However, its not perfect and I'd like it to be close i don't understand why it is the number it is. I don't think i understand the 'Pulse/rev' table on the driver.
The bottom up number i got for steps per revolution was around 540.
Current settings:
Pulse/rev (dip switches) 1600
Motor Step Angle 1.8
Pulley Ratio :3.12
No matter how i combine those numbers i cannot seem to get anywhere close to the 540, the number that actually produces somewhat close to a full revolution.
Any help or explanation is greatly appreciated. My end goal is a precise calculated steps per revolution.
Ps. i am ignoring that this is a servo motor and capable of closed loop control, not sure if this logic holds but i would like it the be as close to correct as possible then use the PID controls to correct error and not lean on it due to sloppy setup work.
  • PCW
  • PCW's Avatar
14 Apr 2025 03:03
Replied by PCW on topic 7i92 firmware issue
7i92 firmware issue
If its just a flash issue, ( normal Ethernet comms  are reliable )
It may possibly be a a compatibility issue or perhaps signal
integrity or some other flash EEPROM connection issue.
  • unknown
  • unknown
14 Apr 2025 00:53
RPi 4, LinuxCNC upgrade doesn't upgrade kernel
Category: Installing LinuxCNC
In all honesty if the kernel gives no issues I wouldn't bother upgrading, from memory there isn't much of a difference in performance.
  • tcbmetalworks
  • tcbmetalworks
14 Apr 2025 00:08
The first issue I run into is that my gear track is 5 TPI The shaft diameter to the motor is 18mm does anyone build gears with metric bores and imperial gear pitch? buy a 5/8 bore pinion chuck it up in the lathe and bore it out to 18mm? hand file to broach out the keyway? a 20 T pinion should get me to about 600 ipm if my calculations are correct. which is honestly to fast but I am worried a 10t will not have enough contact and skip or slop.
  • vre
  • vre
13 Apr 2025 23:23
spindle with encoder was created by vre
Category: Basic Configuration
I have a spindle that has motor pulley belt pulley
after has a geartrain with 2 positions-speeds.
I want to mount encoder to second pulley shaft before geartrain.
Iam confused how to set ini file values
max_speed min_speed encoder_scale output_scale etc
  • foam man
  • foam man
13 Apr 2025 22:54
Replied by foam man on topic CNC doesn't work with new update
  This is the very end of the message
  • foam man
  • foam man
13 Apr 2025 22:50
CNC doesn't work with new update was created by foam man
 Hi, I updated from Linux CNC 2.8.2 to 2.9 and get the following errors when I try and open Linux CNC
Can anyone help Please
  • rodw
  • rodw's Avatar
13 Apr 2025 22:03
Replied by rodw on topic How to pass parameters .comp file
Category: HAL
The IP address is a 32 bit number internally, so you should be able to pass it as an unsigned long parameter. you would need to convert 192.168.1.1 to 4 bytes in hex, then use setp
Displaying 16906 - 16920 out of 17470 results.
Time to create page: 0.415 seconds
