  • Hakan
  • Hakan
29 Dec 2025 17:28 - 29 Dec 2025 17:39
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
The problem is most likely related to the issue with  LWR and LRD/LRW modes that was discussed earlier.
You must at least get that fixed before you can rely on that error message.
automata has a solution. You cannot run lcec with those drives. automata attached
the code for another component to use with the Yaskawa drive.
attached as C file with a Makefile. Download and compile the code.
Use it as a component in hal.
I know it can be a handful to do this, I would foresee some experimentation to get this right.
Edit: I looked in the code and that isn't a ready-to-use component.
There is a lot of work needed to get this to work.
Frankly tar_san, I understood you have the drives on lone for evaluation, right?
Do yourself a favor and return them and get some other servo drives.
I can not spend that much time in getting this going. Hopefully someone else can.
  • Crusader2050
  • Crusader2050
29 Dec 2025 16:40
Replied by Crusader2050 on topic Retrofitting a 1986 Maho MH400E
Category: Milling Machines
from what I've been able to figure out from the drawings and manual provided and in the video, the "voltage fault lamp" on the Indramat seems to indicate an internal problem with the -15v/0v/+15v supply..
check the voltages on the relevant pins on the L6 connector.. ( might be one to scope )
the X axis doesn't seem to be causing an issue? but the Z and sometimes the Y axis trip out?
from the drawings that might be one or more brakes not releasing? as that appears to be linked through 19K2?
without the full schematic I'm guessing at the function of some of the contacts shown on what we do have.
  • PCW
  • PCW's Avatar
29 Dec 2025 16:20
Linuxcnc 2.9.7 - Mesa 5i25 with HKD 5 AXIS MACH3 STEPPER I/FACE and 5i25_5ABOBx2
Category: Driver Boards
Do you have a link to the manual for the HKD breakout?
Also make sure you do not have cable power enabled on the 5I25.
  • andrax
  • andrax's Avatar
29 Dec 2025 15:42 - 30 Dec 2025 17:04
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
Please excuse me for asking more questions.
The following parameters for homing are specified in Collin Bardini's .ini file.
HOME_SEARCH_VEL            = 15.625
HOME_LATCH_VEL            = 15.625
HOME_IGNORE_LIMITS        = YES
CIA402_HOMING_ENABLED = 1
CIA402_HOMING_METHOD=-2
CIA402_HOMING_SEARCH_VELOCITY=20000
CIA402_HOMING_LATCH_VELOCITY=7000
CIA402_HOMING_ACCELERATION=131072
Which of the two parameters determines the homing speed and acceleration?
If the parameters are valid for CIA402, what units are they?
EDIT:
I figured it out. It's the lower values.
However, I still don't know what the units are.
Now I have an additional problem, though.
After completing the homing movement, the axes jump 1-2 mm and go into fault mode. The error can be acknowledged and the axis is referenced.
In the ini file, I have set HOME_OFFSET = 0.0 for the axes.
Where is my mistake?
Thank you in advance.
  • PCW
  • PCW's Avatar
29 Dec 2025 15:41
LinuxCNC + Mesa 7i43 – Axis A stepper (stepgen), error
Category: HAL
7I43 SVST4_4 pinout  (created with mesaflash) is:
File Name: SVST4_4.TXT
File Size:5 KB
  • Crusader2050
  • Crusader2050
29 Dec 2025 15:32
I'm not a Linuxcnc guy, however I do make and fault find control panels for lots of different machines..
is there a possibility of you posting the complete wiring schematic for the control panel? It may be something entirely seemingly unrelated is causing the problem.
  • cncfreak
  • cncfreak
29 Dec 2025 14:40 - 30 Dec 2025 13:55
Replied by cncfreak on topic asd-a2-e ... lcec driver?
Category: EtherCAT
Hi.
I set up my machine and everything worked for me, but there is a small problem: The direction of movement of the X-Axis is not up to standard.
Please tell me how to change the direction of movement of an axis on a machine? How to swap + and - places? The machine is assembled on an ASD-A2 EtherCat. System LinuxCNC 2.9.2.
I tried to configure the change using scale using the following code:net x-vel-cmd    =>  scale.3.in
setp scale.3.gain -1
net x-vel-cmd-DAC  scale.3.out  =>  lcec.0.X.srv-vel-cmdand changing the .iniENCODER_SCALE = -1but the machine goes crazy and does not work normally.
try the P1-01 servo parameter.
  • grandixximo
  • grandixximo's Avatar
29 Dec 2025 14:39
Category: EtherCAT
github.com/linuxcnc-ethercat/linuxcnc-ethercat/pull/461
There is a bug in the linuxcnc-erhercat if you just set the negative option
  • Asmate
  • Asmate
29 Dec 2025 14:27
Fabrication cnc plasma was created by Asmate
Category: Plasma & Laser
Bonjour à tous, j'aimerais bien moi aussi fabriquer ma table plasma , tout seul je suis pas sur de la finir un jour, je voulais tester un peu le forum, savoir si il est suffisamment actif pour me lancer avec vous, je suis prêt à partager toutes les étapes pour les prochains créateurs.
J' ai bien conscience qu'ici ont devrait plus discuter de la partie paramétrage de logiciels, mais avant d'acheter n'importe quoi, je préférerais profiter de votre expérience.
Merci
  • grandixximo
29 Dec 2025 14:14
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
Thank you, I'll keep that in mind.
  • JT
  • JT's Avatar
29 Dec 2025 13:59
Replied by JT on topic Disable pushbutton
Disable pushbutton
Category: Flex GUI
To have a button with an object name of state_stop_pb be disabled when the estop is on and enabled when the estop is off.
parent.state_estop_pb.setEnabled(False)
parent.state_estop['state_estop_pb'] = False
parent.state_estop_reset['state_estop_pb'] = True
To have a button with the object name of state_on be off when the power is off
parent.state_on_pb.setEnabled(False)
parent.state_estop_reset['state_on_pb'] = False
parent.state_on['state_on_pb'] = True
And to answer your question to have a button disabled when a program is running add the object name to the following dictionaries
parent.state_on['disabled_running_pb'] = True
parent.program_running['disabled_running_pb'] = False
JT
  • Aciera
  • Aciera's Avatar
29 Dec 2025 13:26 - 29 Dec 2025 15:59
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
Good to hear that you are making progress.
[edit]
I would be interested to know how tool offsets are handled in the tool table for lathe tooling in the milling spindle on such a mill-turn machine. On a lathe the tool offset is different to a mill in the sense that the length of the tool is an X-offset as opposed to a Z-offset. That is why I have made two different TCP (mill / lathe) modes in this sample config. I wonder if that is actually necessary or if lathe tool offsets are handled just like milling tools.
  • jochen91
  • jochen91
29 Dec 2025 13:12
Hi Folks,
im still living. Wanna give you a status update:
  1. The spindle taper is fixed (Needed to be Laserwelded and reground)
  2. New spindle bearings
  3. I scraped the geometry of the Y axis. Which was a major step, and im not satisfied with the bearing points. (Geometry is excellent) When it gets warmer in Germany i want the moglice all the guide ways. Epoxy is already ordered.
  4. I reassembled the B axis. In january i hope to reassemble the spindle and mount it to the B axis. I need the spindle and B axis ready and mounted to the X axis slide to check and scrape (even for moglice scraping is needed) the geometry.
Kind regards and happy new year,
Jochen
  • matasbuk
  • matasbuk
29 Dec 2025 13:06
Replied by matasbuk on topic Retrofitting a 1986 Maho MH400E
At this stage, I would bypass the contactors so the Indramat is on when the power is connected to the machine (maybe through estop chain) without LCNC and manually give an analog signal to the indromat using a 1.5V AA battery. If the Z axis moves, you can continue to troubleshoot the following error. If it does not, then the indramat is dead.
  • andrax
  • andrax's Avatar
29 Dec 2025 12:48 - 29 Dec 2025 12:49
Replied by andrax on topic Problem bei installation Ethercat
Category: Deutsch
Hallo zusammen,
melde mich wieder nach langer Zeit aus der Versenkung.
Ich habe neues zu berichten. Meine alte Konfiguration mit SEW-Servos und analoger Ansteuerung über die Mesa 7i97 lief mehr schlecht als recht.
Ich hab das alles rausgeworfen und den freiwerdenden Platz mit  A6 Servos (Ethercat) von Stepperonline gefüllt.
Mit Hilfe aus den Forum forum.linuxcnc.org/ethercat/54965-stepperonline-a6-servo hab ich alles erfolgreich zum laufen gebracht.
Meine Konfiguration:
Gantry: XYYZ (1800mm x 600mm x 300mm)
Servos: X A6 750W Ethercat STO, YYZ A6 400W Ethercat STO
Die Servos laufen über Netztwerkkarte 1 und die I/O über Netzwerkkarte2
Oberfläche: Gmoccapy
Homing über Homeschalter
Die Servos werden leider ohne I/O Kabel geliefert. Das wird benötigt, um die Homeschalter an die Servos anzuschließen.
Ich habe mir hier DB15 VGA Stecker bestellt und die Kabel selbst gebaut.
Die Achsen verfahren, Homing funktioniert, jetzt muss ich nur noch die Feineinstellungen erledigen.
Grüße
Andre
File Name: ethercat_2...2-29.xml
File Size:8 KB
File Name: Andres_Frs...2-29.hal
File Size:9 KB
File Name: Andres_Frs...2-29.ini
File Size:4 KB
Displaying 5041 - 5055 out of 16972 results.
Time to create page: 0.291 seconds
