  • Hakan
  • Hakan
29 Nov 2025 20:47
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
That should work. It's a 16-bit encoder counter so be prepared to handle overflow.
TIM2/TIM5 are 32-bit so better to use that when you do your own. There is only one 32-bit though.
  • Unlogic
  • Unlogic
29 Nov 2025 20:41
Replied by Unlogic on topic Schaublin 125-CNC retrofit.
Category: Turning
I added the following HAL code to the configuration of my mill to keep the spindle on for a few seconds after the spindle is disabled just to get the nice smooth ramp down you are looking for:
# --- timedelay before disable spindle output for deceleration ramp --- #
loadrt timedelay names=timedelay.spindle-enable-soft-stop
addf timedelay.spindle-enable-soft-stop servo-thread
setp timedelay.spindle-enable-soft-stop.on-delay 0
setp timedelay.spindle-enable-soft-stop.off-delay 3
net spindle-enable => timedelay.spindle-enable-soft-stop.in
net spindle-enable-soft-stop <= timedelay.spindle-enable-soft-stop.out
net spindle-enable-soft-stop => hm2_7i96s.0.7i84.0.0.output-01
For more information see my post here: forum.linuxcnc.org/12-milling/50559-opti...sion?start=70#309845
  • rodw
  • rodw's Avatar
29 Nov 2025 20:41
Low voltage limit/home switch configuration
Category: Basic Configuration
You have not said what voltage you are using.
The rationale behind 24 volts being more or less standard for industrial systems is that it is more resistant to triggering from noise because a much greater voltage fluctuation is required to trigger false readings.
I think you have already diagnosed the issue.
Also using an industrial power supply like a Meanwell MDR-60-24 won't break the bank. I have lost count of people reporting issues when they use 5 volt plug packs...
  • rasmus
  • rasmus
29 Nov 2025 20:27
Replied by rasmus on topic carousel.comp scale questions.
Thank you.
The encoder is not 1:1 to the ATC Carousel, but mounted directly on the carousel shaft.
The relation is more about 43:1but not exactly, I did a hack reprogramming of the carousel.comp, but not nice and maybe not that thought trough, needs to be tested.
If it does not work i will have a look on the counts mode and see if that will work better.
  • vibram
  • vibram
29 Nov 2025 20:07 - 29 Nov 2025 20:46
Replied by vibram on topic AX58100
AX58100
Category: EtherCAT
Hello
I bought the following card (still waiting for it) and it seems to have TIM8 CH1 and CH2 available
fr.aliexpress.com/item/1005008473184616....gatewayAdapt=glo2fra
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • Sekai
  • Sekai
29 Nov 2025 19:29
Replied by Sekai on topic Chinese Mesa 7I92 from aliexpress NEW
Category: Driver Boards
youre right about the bob, but for now i dont have a bob.
For now i'm new to mesa card in general.
  • Autumn Reign
  • Autumn Reign
29 Nov 2025 19:18
Low voltage limit/home switch configuration was created by Autumn Reign
I have finally gotten my first LinuxCNC machine homing! It is a XXYZA machine. I am quite happy with my progress and everything I have learned. The machine appears to be holding tolerances well while jogging and I am very excited to start running gcode here shortly.
However, I am getting an oddity with my home switches while homing. It's a low voltage system for signals and having spent a lot more time with all of this I realize that a 12 or 24 volt communication voltage and some daughter cards would have kept some of my troubles in the realm of programming and less in the realm of electrical engineering. I have a 6i25 running to a bank of CL86Y's and 4 functioning home switches (XYZA) from 0V to GPIO pins that are normally closed, one for each axis. I think I am making some sort of pullup/pulldown or other fundamental signal error in my home switches.
With my attached hal/ini configs while homing if I start with switches depressed everything homes great. X and A homing are disabled while I am playing with settings but they work when enabled. Halshow shows my switches working as expected. Diag goes "yellow" when the switch is hit and resumes "red" when released. Sometimes I have seen an unexpected flicker, and the shielded wire is not yet grounded. All other cables are shielded and grounded so I think EMI is minimal, but I will be grounding the shield shortly regardless. However, if I start off of switches the axis will pulse forward and then stop after a move of no even length and throw an error about not being on a switch when backing up, as if it was transitioning from search_vel to latch_vel.
I don't mind starting the machine homing by hand, but I am concerned my home switches are triggering the 6i25 IO while I would be normally operating. This seems like it cannot be a great thing to be doing, but maybe it would not be relevant.
If you have any suggestions to get more reliable performance, I would appreciate leaning on all of your experience.
File Name: Autumn_2025-11-29.ini
File Size:6 KB
File Name: Autumn_2025-11-29.hal
File Size:15 KB
  • abu
  • abu's Avatar
29 Nov 2025 18:52 - 29 Nov 2025 20:27
LinuxCNC latency and jitter improvements with PREEMPT_RT kernel parameter tuning
Warning: I have a machine with a 12-core Intel i7 (numbered 0 to 11). The numbers shown in this answer will vary depending on the number of cores in each machine. Do not use Ctrl+C/Ctrl+V. You must read the articles cited in the thread. The calculations for the numbers are there.
Ladies and gentlemen, this looks promising!
It seems that POSIX realtime (PREEMPT_RT kernels) is finally working decently.
This is my machine (linuxcnc info):
The file:    /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
     pastebin.com
in order to provide information about the linuxcnc
system and configuration.
VIEWER=kate
                Date: sáb 29 nov 2025 19:36:45 CET
            UTC Date: sáb 29 nov 2025 18:36:45 UTC
        this program: /home/xiuser/linuxcnc/scripts/linuxcnc_info
              uptime:  19:36:45 up  1:04,  1 user,  load average: 0,35, 0,50, 0,79
      lsb_release -a: Distributor ID:    Debian
Description:    Debian GNU/Linux 12 (bookworm)
Release:    12
Codename:    bookworm
            linuxcnc: /home/xiuser/linuxcnc/scripts/linuxcnc
                 pwd: /home/xiuser
                USER: xiuser
             LOGNAME: xiuser
                HOME: /home/xiuser
              EDITOR:
              VISUAL:
            LANGUAGE:
                TERM: xterm-256color
           COLORTERM: truecolor
             DISPLAY: :0.0
             DESKTOP: lightdm-xsession
        display size:     3360x1080 pixels (889x285 millimeters)
                PATH: /home/xiuser/linuxcnc/scripts:/home/xiuser/linuxcnc/bin:/home/xiuser/.local/bin:/home/xiuser/linuxcnc/bin:/home/xiuser/linuxcnc/scripts:/home/xiuser/linuxcnc/tcl:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
         nodename -n: HPi7
      kernel-name -s: Linux
      kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.12.57-1~bpo12+1 (2025-11-17)
          machine -m: x86_64
        processor -p: unknown
         platform -i: unknown
      oper system -o: GNU/Linux
/proc items:
             cmdline: BOOT_IMAGE=/boot/vmlinuz-6.12.57+deb12-rt-amd64 root=UUID=6dec6435-2cb8-427a-9697-c8d82ce45bdb ro net.ifnames=0 skew_tick=1 nosmt=force kthread_cpus=0-5 irqaffinity=0-5 rcu_nocb_poll rcu_nocbs=6-11 nohz=on nohz_full=6-11 isolcpus=6-11 intel_pstate=disable amd_pstate=disable idle=poll cpufreq.off=1 cpuidle.off=1 intel_idle.max_cstate=0 amd_idle.max_cstate=0 nowatchdog nosoftlockup i915.force_probe=!4680 xe.force_probe=4680
          model name:  12th Gen Intel(R) Core(TM) i7-12700
               cores:  12
             cpu MHz:  3685.961
             parport:
              serial:
Versions:
                 gcc: gcc (Debian 12.2.0-14+deb12u1) 12.2.0
              python: Python 3.11.2
                 git: git version 2.39.5
          git commit: 2cee0486b4
                 tcl: 8.6
                  tk: 8.6
               glade: glade 3.40.0
linuxcnc_var all:
     LINUXCNCVERSION: 2.10.0~pre0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
            REALTIME: /home/xiuser/linuxcnc/scripts/realtime
                 RTS: uspace
          HALLIB_DIR: /home/xiuser/linuxcnc/lib/hallib
              PYTHON: /usr/bin/python3.11
This is the latency histogram before tuning:
And this is the histogram after the changes...
First change: A new kernel that includes the new Intel Xe video driver, which will replace the venerable i915. Xe is in kernels >= 6.12.
Second change:
the GRUB_CMDLINE_LINUX_DEFAULT boot line in Grub. Now cmdline is:
Note: force_probe => i915 OFF and Xe ON. My video device ID is 4680. Yours may be different. lspci gives the ID for each machine.
Third change: Modifying kernel parameters at runtime:
sudo sysctl kernel.timer_migration=0
sudo sysctl kernel.sched_rt_runtime_us=-1
  • Muzzer
  • Muzzer
29 Nov 2025 18:46
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
Aha. Many thanks - commenting out that duplicated line did the trick, so I now have the machine moving in closed loop, homing correctly and e-stopping safely. That's a great step forward and it feels as if I'm getting close to getting this sorted out.
I now have to get the xhc-whb04b-6 MPG connected up (currently commented out) and the spindle vfd doesn't respond, so I'll need to check that out too.
Andy Pugh's macros don't show up in my GUI. I have the tab showing up but clicking on it does nothing - none of the graphics appear. There are several gmoccapy lathe sims that work but something's not right in my setup. Again, I'm not clear what files need to be where and what configs need to be set up. Is there any documentation for the lathe macros that I can refer to?
Many thanks
  • endian
  • endian's Avatar
29 Nov 2025 18:17 - 30 Nov 2025 13:27
Replied by endian on topic Reduce read-all timing 7i76e + 7i77
hello PCW,
base thread or servo thread latency is way under 6us ...
here are statistics
Warning: Spoiler!
what to do next please? regards and thanks
  • Aciera
  • Aciera's Avatar
29 Nov 2025 18:09
Replied by Aciera on topic StepperOnline A6 Servo
Category: EtherCAT
trivkins: already exists
Looks like you are trying to load the kinematics module twice.
I can see one in your screen shot:
'loadrt [KINS] KINEMATICS'
Generally a bit difficult to help with just snippets of information.
  • mooser
  • mooser
29 Nov 2025 17:20
Replied by mooser on topic 7i84u probably toasted
With the jumper removed, connected to field power and the 7i96s connected:
Nothing between 1 and 3 pins on W1
22.8v between 1 and 2, nothing between 2 and 3
carefully removed the IC, still nothing between 1 and 3 and the status lights are still the same.
Ah well, it was an expensive evening
M
  • DemonClaW
  • DemonClaW
29 Nov 2025 17:14
Replied by DemonClaW on topic StepperOnline A6 Servo
Category: EtherCAT
I just got my first servo, too. But even after all Iread here i wasnt able to get it running maybe one of you already had the same problem or im just doing the same mistake over and over again.
Thanks for your help
  • PCW
  • PCW's Avatar
29 Nov 2025 16:32
Is there any way to use Pncconf Wizard to set up 7i97T with 7i73 pendant board?
Adding a simple probe input does not require adding any components, basically just
making some connections in the hal file, something like:
 net probe hm2_7i97.inmux.00.input-15 =>  motion.probe-input
 or perhaps
net probe hm2_7i97.inmux.00.input-15-not =>  motion.probe-input
depending on the probe polarity.
Adding a MPG will typically require at least one components as a mux component
is often used to select between jog increments.
Searching the forum for MPG will finds a number of MPG implementations and hal file examples.
  • PCW
  • PCW's Avatar
29 Nov 2025 16:21
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
With a 7I92, you would normally chose firmware that matches the
pinout of the breakout board you use. The G540x2 firmware is made
to match the pinout of the Gecko G540 4 Axis step/dir drive.
A commonly use breakout board (BOB)  is the Sainsmart "Mach 5 Axis CNC" breakout
For the, you would use  "5ABOB" firmware
Displaying 6301 - 6315 out of 16732 results.
Time to create page: 0.313 seconds
