  • georgio
  • georgio
18 Mar 2026 15:05
Installing Linuxcnc on new pc Using Debian 12.13 and Linuxcnc 2.9.8 mesa 7i76eu
Category: Installing LinuxCNC
I just figured out what the gpio pins are and they are if iam correct the 50 pins on P1 and P2 halshow was not showig any sserial port pins. That is probably why the pin do not exist errors I was getting is from.
Just a thought
  • georgio
  • georgio
18 Mar 2026 14:47
Thank you for your response PCW. I have checked and there is field power of 24v across pins 1&8 it is also tranfered to the nearby power block can't remember its tb number but done as mentioned in posts and manuals.
  • PCW
  • PCW's Avatar
18 Mar 2026 14:37
The field I/O (TB4,5,6) is not GPIO.
If you assign TB5 or TB6 I/O pins or spindle (TB4) pins in pncconf and
you get pin not found errors, this most likely means that you do not
have field power applied (TB1 = ORANGE  connector)
  • Alfapro
  • Alfapro
18 Mar 2026 14:07
Replied by Alfapro on topic Buffered G-code streaming from Python
Category: G&M Codes
So it’s actually possible. For some reason I thought MDI only accepts a single command and then blocks until it’s finished.
I’m working on my bachelor’s thesis about a 6-DOF robotic manipulator, and I’m planning to implement something higher-level than G-code. I assumed I’d first have to fully translate my logic into G-code and then execute it, but now I’m thinking of handling the logic in Python and sending commands directly to LinuxCNC instead.
Thanks for the help!
  • jlfauvel
  • jlfauvel's Avatar
18 Mar 2026 13:55
Mouvement par à coups et bruyant avec servo X : CNC Precix 2100 et LinuxCNC
Category: Français
... very technical, but thanks anyway. I willl take a serious look at your post. By the way, yesterday I managed to eliminate the "noise" from the X servo. Now I just need to adjust the movement smoothly.
  • georgio
  • georgio
18 Mar 2026 13:16
forgot to mention that in halshow i could not see any action on pins the only ones i could see were gpio pins and it listed 50 pins. Just for curiosity i looked at all 50 of the pins and tried activating the limit switchs and saw no change
  • georgio
  • georgio
18 Mar 2026 13:11
Startiing on line 34 of hal limits not existing pin does not exist. I commented out all six lines after reltating to non existing pins to get thru with no errors. I checked these pins on TB6 04-09 and they all has voltage of 24v until activated then went to aprox .4v.There may be an issue with the board.
Thanks PCW
  • hellvetica
  • hellvetica
18 Mar 2026 12:50
Replied by hellvetica on topic halui: updateStatus: status buffer is not valid
Hi thanks for the reply.
I found where it's printed but my question is what could cause the status buffer to be invalid after ~1hr of working flawlessly?
Is it possible it's some sort of hardware/memory corruption issue?
  • mm26
  • mm26
18 Mar 2026 12:15
I was at exactly same point yesterday.
Everything runs perfectly until i add the spindle output.
I figured out that the spindle outputs are on the second half of the board which is internally connected by sserial. As I was testing everything on my desk, I just powered the board via the 5V supply. After digging deeper into the manual, I figured out that the field power needs to be applied as well. Some more LED lighted up, board was working :)
hope this helps
  • hellvetica
  • hellvetica
18 Mar 2026 11:16
after running our system for a while, sometimes linuxcnc basically stops working, starts acting very weird and i get this in the logs
Can you please help me diagnose this, as I don't event know where to start looking.
  • grandixximo
  • grandixximo's Avatar
18 Mar 2026 08:57
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
No worries, I'm just not sure when that's gonna happen, Scott's not been active in the repo since beginning of January... Tried to reach out by email, no reply...
  • andrax
  • andrax's Avatar
18 Mar 2026 08:34
Replied by andrax on topic Ethercat random jitter fix
Category: EtherCAT
@grandixximo: I'd like to test it, but I'd rather wait until your changes and optimizations are incorporated into the official repository.
Until then, I'll stick with refClockSyncCycles="-1" for now.
  • dm17ry
  • dm17ry's Avatar
18 Mar 2026 08:24
Replied by dm17ry on topic Mitsubishi MR-J3-XX"A" drive + 7i94 config?
Category: Driver Boards
ethernet - i've finished the hardware, but still working on software...
  • amanker
  • amanker
18 Mar 2026 05:39
Replied by amanker on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
I have added 4th axis rotary and 5th axis tilting head, bascially XYZAB configuration. In vismach it moves machine parts (rotary and tilting head) as i move A/B axis. But tool remains at same loaction, it moves on xyz only.
Displaying 661 - 675 out of 17460 results.
Time to create page: 0.200 seconds
