  • andypugh
  • andypugh's Avatar
17 Nov 2025 21:35
Replied by andypugh on topic Maho MH800e Retrofit Project
Category: Milling Machines
You are making good progress. Once you have it all running, I will have to use your HAL and Ini to upgrade my machine to 2.9
The updater script _should_ handle any necessary HAL changes.
Not a lot changed between 2.8 and 2.9 (2.7 to 2.8 was the big shift)
  • andypugh
  • andypugh's Avatar
17 Nov 2025 21:31
Replied by andypugh on topic HURCO KMB-1 Control Update
./Hurco_7i92.hal:347: Pin 'encoder.position' does not exist
It's almost certainly encoder.0.position that you need (or some other number that identifies the spindle encoder.
  • andypugh
  • andypugh's Avatar
17 Nov 2025 21:30
Replied by andypugh on topic Probe tripped during non-probe move deadlock
Why do you need 2.8.4?
Are you stuck on Buster (or even Stretch / Jessie?
You could, in principle, patch 2.8.4 with the updates made in 2.9 and recompile.
  • kor
  • kor
17 Nov 2025 21:27 - 17 Nov 2025 21:28
Ethercat installation from repositories - how to step by step
Category: EtherCAT
I tried to install the linux-ethercat package
but I get the error that they are dependent on other packages: libtool, autoconf, autoconf-archive and automake. which can not be installed.
I do have a freshly installed linuxcnc 2.9.4 preempt-rt installed from the iso image.
  • andypugh
  • andypugh's Avatar
17 Nov 2025 21:26
Replied by andypugh on topic VTK based version of Vismach
Category: Show Your Stuff
It's 52MB on top of a stock Bookworm install.
What was your motivation for doing it? Do you think that others will share that motivation?
17 Nov 2025 20:35
Post installation / problème pour ouvrir des images / Paramétrage de Python ?
Category: Français
Try dmap2gcode from
www.scorchworks.com/Dmap2gcode/dmap2gcode.html
The error seems to be dues to uppercase I letter where there should be a lower case letter i, but it seems to be in the software and might require editing the source code and issuing a pull request on GitHub.
  • gardenweazel
  • gardenweazel's Avatar
17 Nov 2025 20:26
Replied by gardenweazel on topic Rerunning a tool in qt_dragon_hd
Category: Qtvcp
What about using the start/from this line? I believe if you do a right-click it allows you to select to start from the line you you right-clicked on.
  • gardenweazel
17 Nov 2025 20:11
Replied by gardenweazel on topic Motor Driver Electrical Question
Category: Basic Configuration
Confirming that the 3.8A is a comfortable setting and additionally lowered the heat of the motors.
Thank to everyone that provided feedback!
  • abs32
  • abs32
17 Nov 2025 20:10 - 18 Nov 2025 15:02
Installation v2.9.7 linuxcnc in November 2025.
Category: Installing LinuxCNC
Error in published instruction. It should actually be -
vi sources.list.d/linuxcnc-uspace.list
deb [arch=amd64,arm64 signed-by=/etc/apt/trusted.gpg.d/linuxcnc.gpg.key.binary.gpg] www.linuxcnc.org/ bookworm base 2.9-uspace 2.9-rt
  • stephhubert
  • stephhubert
17 Nov 2025 20:08
Category: Français
Bonjour à toutes et tous,
Quand j'ouvre une image en .png, il apparaît ce message :
  File "/usr/bin/image-to-gcode", line 34, in <module>
    plus_inf = numpy.core.Inf
  File "/usr/lib/python3/dist-packages/numpy/core/__init__.py", line 30, in __getattr__
    attr = getattr(_core, attr_name)
  File "/usr/lib/python3/dist-packages/numpy/_core/__init__.py", line 167, in __getattr__
    raise AttributeError(f"Module {__name__!r} has no attribute {name!r}")
AttributeError: Module 'numpy._core' has no attribute 'Inf'. Did you mean: 'inf'?
D'où vient mon problème ?
Quelles perspectives pour corriger ?
Merci !
  • Cooped-Up
  • Cooped-Up
17 Nov 2025 20:04
Replied by Cooped-Up on topic Maho MH800e Retrofit Project
That seems like a fair trade haha, currently watching videos on the 7i73 to modify the hal for all the buttons. also just designed a rough draft pendant
  • nwallace
  • nwallace
17 Nov 2025 19:59
Replied by nwallace on topic How to disable buttons in Probe Basic
Category: QtPyVCP
Unfortunately, this does not work on the actual machine. It worked on the sim on a VM but does not behave the same on the physical machine. I can't figure out why. I also can't figure out why just disabling with 'self.probe_spindle_nose_subcallbutton.setEnabled(False)' doesn't work either. Any pointers? I am out of things to look at that I can vaguely understand.
  • PCW
  • PCW's Avatar
17 Nov 2025 16:04
Replied by PCW on topic Problema de altura en el eje Z
Category: Español
In any case, it seems like the Z axis homing is unreliable
If the latch velocity is low than this seem more like a switch/mechanical  or debounce issue
  • laurentl38
  • laurentl38
17 Nov 2025 15:57
Diameter tool probing with toolsetter, basic probe
Category: QtPyVCP
I've started reading and thinking about a solution.
Right now, unfortunately, I don't have the time to make the progress I'd like.
I've come a long way, but I'm not giving up... ;-)
Thank you for your work, it's a great help.
  • Lcvette
  • Lcvette's Avatar
17 Nov 2025 15:52
Replied by Lcvette on topic Probe Basic backplot error when loading file
Category: QtPyVCP
Thanks Unlogic! we are wrestling with the builder at the moment but once that is squared away we will be able to update the current main branch with the updates!
Displaying 7021 - 7035 out of 16686 results.
Time to create page: 0.551 seconds
