  • DerKlotz
  • DerKlotz
05 Nov 2025 15:11
Try to activate Gladevcp with setp gladevcp -> Linuxcnc
Category: GladeVCP
2. start your config from a terminal ($ linuxcnc) and check output for clues
[GladeVCP][INFO]  Logging to: /home/cnc/gladevcp.log (logger.py:106)
[GladeVCP.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No DEFAULT_SPINDLE_0_SPEED Entry in DISPLAY, Using: 200 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MIN_SPINDLE_0_SPEED Entry in DISPLAY, Using: 100 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MAX_SPINDLE_0_SPEED Entry in DISPLAY, Using: 2500 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MAX_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 1 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:532)
79691779
3. I would recommend using a simple texteditor to edit the files not a word processor like the one in your screen shot.
Ok
  • karlhe
  • karlhe
05 Nov 2025 14:20 - 05 Nov 2025 16:33
booten dauert lange 1min 30 sek , alles ok
    Hallo,
das booten dauert lange, kann man das ändern?
karlhe
  • axemas
  • axemas's Avatar
05 Nov 2025 12:52 - 05 Nov 2025 12:53
  • bevins
  • bevins's Avatar
05 Nov 2025 12:37
Delta Servo ASD-B2, was created by bevins
Delta Servo ASD-B2,
Hi ,
I am looking for some help with this drive. I had one go bad and trying to get a new one up and running.
If someone can help with this drive please let me know.Had a drive go bad and got a new one on ebay and cant get it to act right.
Thanks,
Bob
  • tar_san
  • tar_san
05 Nov 2025 12:29
Replied by tar_san on topic LinuxCNC + RDK X3 = ARMCNC
Great !
Can I use it for RDK X5 ?
How was the result of latency test of Servo Thread ? (X3 and X5)
  • timo
  • timo
05 Nov 2025 12:28 - 05 Nov 2025 12:34
Usable Interface for CNC Turntable on Manual Mill
Category: Other User Interfaces
Hello,
we had a longish discussion about using an arduino for this task; here:
www.homemodelenginemachinist.com/threads...rduino-idexer.35108/
and here:
www.homemodelenginemachinist.com/threads...e-for-dummies.26744/
Be careful with rounding errors and backlash, but for simple indexing this does work fine.
With an Arduino and stepper that is rel. slow, but I would prefer it over a linux CNC system, because it "stand alone" and cheap and easy to build.
The second link is good for the basic setup and wiring description.
The first link dives into the rounding error explanation.
Good luck.
  • axemas
  • axemas's Avatar
05 Nov 2025 12:19
05 Nov 2025 12:04
Replied by tommylight on topic proudly presenting a Maho MH700 retrofit ..
Category: CNC Machines
Hi there. Any chance you still have your ini or HAL?
The whole config is attached on the post above yours, download and unzip.
05 Nov 2025 12:00
Replied by tommylight on topic VTK based version of Vismach
Category: Show Your Stuff
Awesome!!!
  • Gogonfa
  • Gogonfa
05 Nov 2025 10:16
What do i need exactly for ethercat ? Recommended hardware??
Category: EtherCAT
Hi GuiHue,
that sounds really interesting!
I’m using three 1 kW Delta B3M servos on my machine and would like to make the system fully closed-loop by adding linear encoders to the axes. I’m still quite new to LinuxCNC and currently trying to understand how to build my machine configuration file and how to connect all the inputs and outputs from the Beckhoff DI/DO modules. My previous controller was an EDING CNC760 with Step/Puls and no encoder support...
What should I pay special attention to, and where would you recommend I start?
Also, which encoders are you using on your axes?
Best regards,
Michael
  • Aciera
  • Aciera's Avatar
05 Nov 2025 09:45
Replied by Aciera on topic VTK based version of Vismach
Since I had to use PyQt to work around a bug with vtk Timer I added a small optional UI:
  • Hakan
  • Hakan
05 Nov 2025 09:21
Replied by Hakan on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
Regarding Intel ECI, it seems Intel offers the IgH Ethercat master under their ECI umbrella.
We have nothing to do with that.
There is not one linuxcnc system. The linuxcnc system is always tailor-made to fit the machine.
You piece together a number of components for kinematics, drive control, io, gui etc
and connect them together into a working linuxcnc system.
This is done in the hal file. Components are loaded, pins are connected or given values.
Pins are the basic connection points in and out of a component.
lcec (linuxcnc ethercat component) is the component that connects pins to ethercat pdos.
lcec reads and writes data from the ethercat device every servo cycle (like every 1 ms)
and exchanges the data with the connected components.
  • Hakan
  • Hakan
05 Nov 2025 09:02
MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Category: QtPyVCP
I tried to install Monokrom and installed python3-monokrom.
Then it stopped.
monokrom_plasma --install didn't do anything useful as far as I can see.Couldn't find the way forward.
Can some outline the steps to install monokrom. I have a qtplasmac system I want to test this on.
  • mariusl
  • mariusl's Avatar
05 Nov 2025 08:46 - 05 Nov 2025 08:48
Replied by mariusl on topic USB activity causes network error
Category: Plasmac
Thanks Rob. So it will make sense then to force the eth0 irq to the last core?
Yes, be guided by PCW there. Thats what he says but a lot of RT stuff I have read indicates it should be on a seperate core. I have wondered about setting the affinity for eth0 to core 6 and the linuxcnc rtapi thread irq to core 7 (given isolcpus=6,7) The latency test is really irrelevant with mesa hardware and you need to focus on network latency.
I am testing on a machine with 8 cores but the units that are giving me uphill all have only 4 cores. I will isolate 2,3 and put the eth0 irq on 2 to test. I will report back once I have tested it. Unfortunately all the machines that are problematic are a couple of hours away from me. Is there a way to test the network latency?
  • unknown
  • unknown
05 Nov 2025 08:13
LinuxCNC + Mesa 7i92TF + Gecko G540. Docs are useless. Help, Please!
Category: PnCConf Wizard
Does the specific firmware for the G540 for the 792TF need to be loaded on the card?
Just asking for a friend.
Displaying 7606 - 7620 out of 16726 results.
Time to create page: 0.364 seconds
