  • AkkiSan
  • AkkiSan
31 Oct 2025 00:25
Replied by AkkiSan on topic Which LinuxCNC HW for 2026+?
Kudos go out to all who made this possible:
60000+ probes for now, during the last 24 hours, with an RPi5, 7c81 and the brand new 2.9.7.
Zero issues, so far.    \o/
While probing, this thing now also runs a VNC server in the background,
I am connected via VPN; it’s streaming music and also downloading a random
10GB image file in a web browser.
Pretty good latency too. Comparable to a decent RTAI setup, imho.
Still some extra steps, as described here,
  forum.linuxcnc.org/49-basic-configuratio...rol-is-choppy#332726
and this "xset -r“ drives me crazy, bc I have to use the keyboard until I managed to get the handwheel working.
  • my1987toyota
  • my1987toyota's Avatar
31 Oct 2025 00:04
Replied by my1987toyota on topic ARE YOU KIDDING ME YOUTUBE !!!
I consider it the fog of war. It gets harder and harder to differentiate between government and criminals.
I leave it to each individual to figure out the definition of each.
  • unknown
  • unknown
30 Oct 2025 23:58
Replied by unknown on topic ARE YOU KIDDING ME YOUTUBE !!!
Yeah I wasn't into EFI on bikes, until I got a 2000 M900......so easy to start
Well those that fell for he covid thing have only got themselves to blame. If more had of stood up.
But hey guess what the "conspiracy theorists" were right.
  • Yaroslav
  • Yaroslav
30 Oct 2025 23:51
Replied by Yaroslav on topic Coil Set and Reset.
Coil Set and Reset.
Category: ClassicLadder
I made a diagram. Here's how it works. When power is applied to the set input, the coil turns on and remains on, but it does not glow red, but its additional contacts glow. Accordingly, powering the reset input turns it off.
  • my1987toyota
30 Oct 2025 23:51
tommylight post=337548 userid=17274Nice, i am glad.
It is unreasonable not having several PC's these days, have work stuff separate from fun stuff and those separate from gaming stuff, etc etc, since the used PC's are very cheap and Linux is perfectly usable on them.
Hilariously in the early 2000's I didn't really care for computers I liked carburetors over EFI though over time that has changed. I have built
and installed multiple MegaSquirt EFI computers  mid 2000's I got my first Windows XP Laptop. It wasn't until mid 2010's that I started
looking into CNC and eventually multiple Linux installs on Desktops and Laptops though I still feel like a noob with mountains of
learning still ahead.
  It is however very disheartening to see the direction the world has been pushed post Covid.
  • merongi
  • merongi
30 Oct 2025 23:50
Seeking best practice advices for precision double side machining
Category: CAD CAM
The parts I makes typically requires double side machining and the Z thickness and flat over X-Y plane are two critical parameters.
I can measure my vice jaw flatness using Z probe over 4 corners as within 5~10um error. And there is tramming error that accounts <10um error over tip to tip in Y direction depending on the tool size.
And here are my procedures to make the parts.
1. Create fixture on vice. Check flatness <10um variation corner to corner.
2. Prepare stock surfacing on vice on both sides
3. Does backside machining on vice
4. Flip and attach it to fixture on vice then front side machining
After this, typical error in thickness over corners are now in 100um range. I don't know where they are coming from and how to improve. My goal is to get to ~50um or less range.
Any advice would be welcomed.
  • spacestate1
  • spacestate1
30 Oct 2025 23:44
Replied by spacestate1 on topic Tool life tracking with tooldata
I know it’s been a couple of years, but since this is the top Google search result for this topic, I’ve finally put something together.
Here is a tool usage track for LinuxCNC  it used the existing tool db api code to get the information it uses.  It does take the place of the current linuxCNC tool table so be aware of this.
It tracks tool usage time (somewhat accurate, +/-3 sec) it's also not super accurate with drilling.
There's also a tool  retirement feature and  tool UID tagging so tool wear and breaks can be tracked.
The attached Debian also contains all the source to build this, and it's MIT so have at it.
INSTRUCTIONS:
 INSTALL THE PACKAGE
Install with dpkg:
  sudo dpkg -i linuxcnc-db-tool_1.0.0_amd64.deb
This installs:
  /usr/local/bin/db_tool           - Main daemon
  /usr/local/bin/db_tool_manager   - GUI manager
  /usr/local/bin/db_tool_monitor   - GUI viewer
  /usr/local/share/linuxcnc-db-tool/ - Documentation & examples
STEP 3: CONFIGURE LINUXCNC
Edit your LinuxCNC INI file and add:
  [EMCIO]
  DB_PROGRAM = /usr/local/bin/db_tool /path/to/your/tool_table.tbl
Example:
  [EMCIO]
  DB_PROGRAM = /usr/local/bin/db_tool /home/cnc/linuxcnc/configs/my_mill/tool.tbl
STEP 4: START LINUXCNC
Start LinuxCNC as normal. The tool database daemon will:
Start automatically
Launch the GUI manager (if enabled)
Begin tracking tool usage
  • my1987toyota
30 Oct 2025 23:33 - 30 Oct 2025 23:34
Florida actually. Though probably about the same governmental mind set as Texas. LOL
  • PCW
  • PCW's Avatar
30 Oct 2025 23:24
Replied by PCW on topic MESA 7I92 programming
Category: Driver Boards
Not sure what the issue is, it works for me (LinuxCNC 2.9.4).
did you choose a lathe XZ configuration at the beginning?
Also note that stepgen 5 is used for the charge-pump
so you need to enable al 6 stepgens to have that available
  • ihavenofish
  • ihavenofish
30 Oct 2025 23:09
Replied by ihavenofish on topic ARE YOU KIDDING ME YOUTUBE !!!
I tried pulling up multiple video's today on my Linux and windows 10 laptops and every single time no matter the video
it requested that I log in to view the videos. Video's that played just fine yesterday (tutorials on Tkinter) now request
that I log in. whether it's official policy is immaterial. It's the fact that it's happening.
ihavenofish If you're able to watch YouTube without logging in then perhaps there is some technical aspect in the mix
that I don't know about, region, country, municipality, internet provider. ect. any of the above could be it.
 I will try my machines when I get home and see if there is a difference.
OK, now this makes sense. yes, this will be country - or likely state - specific. You happen to be in texas? I know they just implements some form of this.
This isn't youtube's fault though, this is the government of wherever you live. They just have to follow the laws.
30 Oct 2025 22:50
Replied by tommylight on topic ARE YOU KIDDING ME YOUTUBE !!!
Nice, i am glad.
30 Oct 2025 22:44
Replied by tommylight on topic MESA 7I92 programming
You have 1 active PWM generator but no pin out for it chosen, so either set the PWM number to 0 or select a pin for spindle PWM
  • my1987toyota
30 Oct 2025 22:21
  Fortunately the only thing that gets truly logged onto at work is Fusion 360. I will be changing the password on that
momentarily. everything else is either off line or no log in used. My Linux laptop gets a complete wipe and re install
every so often anyway. It's also what I usually play Youtube on.
  • TJ
  • TJ's Avatar
30 Oct 2025 22:18
Replied by TJ on topic MESA 7I92 programming
Pncconf found the card, read the settings and they are displayed.
I chose a lathe X-Z axis for the test.
I configured the X-Z spindle PWM and the Charge pump encoder end positions etc...
It doesn't let me proceed, it says no axis or PWM is configured.
What did you do wrong?
A few pictures of the settings.
  • john.obrien
  • john.obrien
30 Oct 2025 22:11
Replied by john.obrien on topic 6i25 bitfile
6i25 bitfile
I see. Thanks for clarifying why the manual states that there are advantages to using a bitfile that is not distributed compiled in the archive of supported software that is linked to next to it on this page: store.mesanet.com/index.php?route=produc...ct_id=58&search=6i25
Displaying 7891 - 7905 out of 16732 results.
Time to create page: 1.757 seconds
