  • Aciera
  • Aciera's Avatar
28 Nov 2024 15:51
Gmoccapy Toollength sensor routine stops sometimes
Not sure what's going on but you might want to insert some debugging statements:
M66 E0 L0 (Stop read-ahead and wait for code execution to catch up)
(DEBUG, 1702: #1702)
G53 Z#1702 (Wechsel Z Position)
(DEBUG, 1700: #1700 1701: #1701 )
G53 X#1700 Y#1701 (Wechsel XY Position)
M6 T#<_selected_tool>
Also make sure you don't have X or Y offsets in your tool table.
  • PCW
  • PCW's Avatar
28 Nov 2024 15:50 - 28 Nov 2024 17:54
Replied by PCW on topic Mesa Configuration Tool
Category: Configuration Tools
Do you need PWM or analog for the spindle?
If analog then using the 7I78s analog output would be best.
Here is 7I95T firmware for a 7I95T +7I78: (10 stepgens, 7 encoders, 3 sserial channels, analog spindle out on 7I78)
File Name: 7i95t_7i78d.zip
File Size:317 KB
  • PCW
  • PCW's Avatar
28 Nov 2024 15:35
Replied by PCW on topic 7i96S Basic Switch Wiring confirmation
Category: Basic Configuration
I would wire:
VE- --> 7I96S input common (TB3 pin 12)
VE+ --> X,Y,Z switch COM
X,Y,Z N/C or N/O -->  TB3 pins 5,6,7
28 Nov 2024 14:38
Replied by tommylight on topic CAROUSEL ATC
CAROUSEL ATC
Category: HAL
Pictures?
  • Aciera
  • Aciera's Avatar
28 Nov 2024 14:31
Replied by Aciera on topic Original Gmoccopy setting all gone
New operating system and new Linuxcnc version are expected to give you different behavior.
As for the config not starting, uncomment these lines in your ini and try again:
EMBED_TAB_NAME = Center_panel
EMBED_TAB_COMMAND = gladevcp -c gladevcp  -H gvcp_call_list.hal -x {XID} gvcp-panel.ui
You will likely need to update 'gvcp-panel.ui', opening the file in glade and saving again might already do the trick.
  • Abdulkareem
  • Abdulkareem
28 Nov 2024 14:14
Replied by Abdulkareem on topic CAROUSEL ATC
CAROUSEL ATC
Category: HAL
yes
  • raychar
  • raychar
28 Nov 2024 13:51
Replied by raychar on topic Original Gmoccopy setting all gone
Also, by running linuxcnc -l in terminal, the message found as listed in attachment. However, if I replace the old mSATA drive which has with old version Linuxcnc on this same computer, everything works fine. Don't know why everything goes wrong now including the latency test
28 Nov 2024 13:49
Replied by tommylight on topic Small touchscreen display 7-10' -> 14-16"
Thinking about it, i recal vaguely that 800x600 gui is included in 2.10 so chances are it is in 2.9.3 also.
Still, to small, i am used to at least full HD on 24" and bigger screens.
28 Nov 2024 13:35
Normal Axis without any VCP panels should be ok on 1024x768 screens, so probably will be clipped on 1024x600, although there are modified Axis GUI to fit smaller screens, no idea if they are included with LinuxCNC.
The 1920x1200 at 10" will be very small letters and XFCE (the desktop in official Debian) does not support fractional scaling, but Axis can be set to use bigger letters and it expands accordingly so it might be OK.
Personally i would go for higher resolution always, most stuff can be managed on it, it will be pain and suffering on low resolution as even some windows might not fit.
  • finnstrom
  • finnstrom's Avatar
28 Nov 2024 13:31
LinuxCNC gcode hangs on M63 "main loop took x seconds"
I swapped in my own M6 toolchange code which (mostly) works just fine. Right before grabbing the tool, it runs a command to synchronize grabbing the tool with moving the spindle down slightly:
; Deactivate tool release to grab tool
M63 P17
G91 G1 Z[-#<z_jump>] F[#<z_jump_speed>]
However, on the first (and only first) tool change operation, and on exactly every new program loaded, the gcode just stops running right when it's about to grab the tool. It doesn't toggle machine power, it doesn't stop or pause the program, it just sits there with the "play" button pressed as if it's running. The only message I see on the terminal (even when running verbose) is:
task: main loop took 0.110972 seconds
My workaround is to move the spindle up, retract the tool, and to run the exact same program again, and everything works as it should.Any idea on how to debug this? Or tips on where in LinuxCNC source to add some more debug output around the M63 operation? I'm running 2.9.1 on a system built from LinuxCNC LiveCD. The problem persists in both Axis and QtDragon.
  • royka
  • royka
28 Nov 2024 13:28
Replied by royka on topic Small touchscreen display 7-10' -> 14-16"
I'm not sure about axis, but I think it's compatible with most resolutions, but if you're able to find a 1920x1080 display you'll have more choice of user interfaces. For a smoother experience a Raspberry Pi 5 is a better choice.
28 Nov 2024 13:18
CAROUSEL ATC
Category: HAL
It this a DIY ?
  • slowpoke
  • slowpoke
28 Nov 2024 12:57 - 28 Nov 2024 13:05
I'm looking for a suitable small 7-10" touchscreen display for use with LinuxCNC (lor a lathe). I plan to uses a RaspberryPI 4 that has a HDMI interface. The display will be positioned so that my eyes will be quite close ~12" from the display.
This one is cheap enough not sure if 1024x600 is compatible with axis?
www.amazon.ca/gp/product/B0CPM15T7H/ref=...o00_s00?ie=UTF8&th=1
or this one; 1920x1200
www.amazon.ca/Wstirhy-Portable-Kickstand...y%2Caps%2C160&sr=8-9
I have read there are some compatibility issues with some displays, so if anyone can recommend a display that is known to work well, please share the details.
  • Aciera
  • Aciera's Avatar
28 Nov 2024 12:55 - 28 Nov 2024 12:57
Replied by Aciera on topic MMS einschalten mit einem Taster.
Category: Deutsch
Die 'toggle2nist' Komponente sollte nun ohne die zusätzliche toggle Komponente funktionieren (in der master Version):
forum.linuxcnc.org/24-hal-components/405...nent?start=10#315456
  • Aciera
  • Aciera's Avatar
28 Nov 2024 12:52
Run from terminal again and post the output as there are likely other python2/gtk2 issues..
Displaying 17251 - 17265 out of 24042 results.
Time to create page: 0.439 seconds
