23 Oct 2024 11:17
ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
@Wez,
How the hell did you cram all that stuff into an ESP32? :)
Hal2UDP version works, your version is refusing to work on a Wroom module, no network, and ipconfig will reset it.
The rest seems ok, can set motors, enable wifi, etc.
Will report back later if i manage to find the culprit.
It is the "doit" version with strange pinout so had always issues with it, will also try another board
  • Stanislavz
  • Stanislavz
23 Oct 2024 11:07 - 23 Oct 2024 13:03
Replied by Stanislavz on topic Double / twin scara robot
Scara is a certain type of robot arm, usually with 4 or 5 joints/axis, not a foam cutter.
Yes, it can do indepent axis foam cutter, i have made several of them, and it can have configurations for 2 axis with 4 joints or tandem and a configuration for independent 4 axis, even 5 is you want to add a rotary table.
Some examples
www.google.com/search?q=foam%20cutter%20...%20cutter%20linuxcnc
Thank you for reply, by meaning scara - i do have in mind to replace two linear rails with two steppers and some gears on it. For each side. For smaller one it is ok to have 1:4 gear ratio to have ok resolution for foam cutter. With 8 microstep it shell give 0.1227mm step ~0.5mm at 500mm arm radius.
I have made mre than one foam cutter and i do hate to drag it around. Scara would be wery compact then not used.
23 Oct 2024 11:03
Replied by tommylight on topic Max_Angular_Velocity
Category: Basic Configuration
Not sure if anything changed, but XYZ were always linear and ABC were always angular, but i know i have set A axis as linear and it worked for what i need. The gremlin (vizualization on GUI) might still show it as angular, though, and i do not know how to change that.
Should wait for someone with more knowledge to chime in.
23 Oct 2024 10:57
Replied by tommylight on topic How to put the 7i77 encoder in mode 1?
Category: HAL Examples
In the hal file, the loadrt line containing Mesa IP address, the number of encoders is set to 1, should be set to 8 i think, see your other topic already replied by PCW.
Then you would have to also change the encoder number, most probably from encoder.00 to encoder.06 for every entry of that encoder.
23 Oct 2024 10:48
Replied by tommylight on topic Double / twin scara robot
Some examples
  • gitano
  • gitano
23 Oct 2024 10:47 - 23 Oct 2024 11:11
...just discovered this a few days ago and i am really impressed! Really nice work, also with the configuration wizard in the docker container!
Just stepped inside the LinuxCNC world with a rudimentary BOB setup, so maybe a bit early... but i am really considering having a look at this :)
Cheers!
-lgitano
  • Stanislavz
  • Stanislavz
23 Oct 2024 10:28
Double / twin scara robot was created by Stanislavz
Hello. Is it possible to configure linuxcnc for two scara x/y and u/z axis from same controller ? Ie - i would like to make a cnc foam cutter, and have independednt sides controlled from same controller for tapered cuts. .
  • phillc54
  • phillc54's Avatar
23 Oct 2024 10:16
Replied by phillc54 on topic Update failure
Update failure
Category: Plasmac
There should be three of encoder A, numbered 0, 1, and 2. Click the arrow next to the encoder you want for arc voltage.
If you are using an encoder for ohmic comp you need to do that manually after PnCconf has completed, the default ohmic sensing for QtPlasmaC is done using a solid state relay rather than a THCAD.
Warning: Spoiler!
  • freemoore
  • freemoore
23 Oct 2024 09:50
Replied by freemoore on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
When would suit you?
  • zack
  • zack's Avatar
23 Oct 2024 09:38
Replied by zack on topic 10" 1024 x 600 display with touchscreen
This version supports touch screens
  • daveyr
  • daveyr
23 Oct 2024 09:18
Replied by daveyr on topic Probe Basic Contour ShuttlExpress
Category: QtPyVCP
Not sure if it is to late but here is the Hal file that i used for my shuttle.
As a warning every now and then i would get a run away when using the outer jog wheel thing where it would just go all the way on the axis. As a result i mainly used the jog wheel in the middle and have now transitioned to a normal pendant using a 7i73 for stepping.
To make it work all you should have to do is include the HALFILE in your .ini
#Shuttle Pendant
HALFILE = shuttle.hal
  • Aciera
  • Aciera's Avatar
23 Oct 2024 09:08
Machine moves when you stop program in the middle
Looks fine
If is was something like on abort, shouldn't it do it all the time? I mean like for any program?
Well, yes but since this is an obscure problem it is not likely just related to your hal and ini files.
I think I need to try and revert back to before trying to install easy probe.
Indeed, the easiest would be if you had made a copy of your machine config folder before trying to do the install.
  • btvpimill
  • btvpimill
23 Oct 2024 08:53
I found it finally. I don't see anything in it but here it is. I hope you do. I think I need to try and revert back to before trying to install easy probe.
1- I was unsuccessful in the install (didn't try very hard)
2- not using it since I was unsuccessful
3- never experienced anything like this over the last 12 years or so since finding EMC
  • Guytou
  • Guytou
23 Oct 2024 08:43
Replied by Guytou on topic 10" 1024 x 600 display with touchscreen
Thanks for the tips.
Does Axis support touch screens ?
I was thinking using Gmocappy.
  • tray
  • tray
23 Oct 2024 08:17
Replied by tray on topic Mesact 2 Setup
Mesact 2 Setup
Category: Configuration Tools
Yeah, sorry I'm at a loss also.
I was thinking of getting linux mint and installing Linuxcnc on that.
After all this is a fresh install I am attempting to install the mesact on.
Displaying 19471 - 19485 out of 24147 results.
Time to create page: 2.917 seconds
