  • PCW
  • PCW's Avatar
05 Jun 2025 13:25
Replied by PCW on topic Mesa 7i97T & LinuxCNC setup struggles
Category: Installing LinuxCNC
Do the motors have tachometers connected to the drives?
(these are needed for velocity mode)
  • langdons
  • langdons
05 Jun 2025 12:26
Replied by langdons on topic LinuxCNC compatible industrial PC
99.9% of people at my school would not be able to calculate that.
(I can tho)
  • javanree
  • javanree's Avatar
05 Jun 2025 11:41
MESA 7i92TH to power an OmioCNC 3040 LPT system ; which firmware ?
Category: Driver Boards
I'm trying to convert my cheap 3040 router with an LPT card to connect to LinuxCNC using a Mesa 7i92TH
Current LPT pinout is :
1 VFD spindle on (CW) , using a small relay
2 X step
3 X dir
4 Y step
5 Y dir
6 Z step
7 Z dir
11 X home in
12 Y home in
13 Z home in
15 probe in
17 VFD spindle PWM (0-2000Hz)
If I read the documentation ( 7i92tman.pdf ) correct the PROB_RFX2D would match it almost perfect , but that file is not in the ti92t.zip from the Mesa website. Which firmware am I best off to use ?
  • andypugh
  • andypugh's Avatar
05 Jun 2025 10:44
Replied by andypugh on topic Need help with Linux 2.5 on a CNC lathe
Hello got everything up and running the machine will home. I keep getting the same error and I’m not able to run a program. I am not skilled at writing G code, but hopefully this is a quick fix. Any assistance is greatly appreciated
Unable to open file <135>
In line 39 of the referenced G-code file it looks ike there is a command to call a subroutine. That hasn't been found in the current file, so it is looking for it ina separate file of the same name.
At a guess (and this is a complete guess) you may be running the cooper_groove_master_2B.ngc  file from a backup location ("Old to Hold") and the referenced subroutine file may not exist in that location.
Have a look around line 39 (might not be _exactly_ line 39 for a reference to <135> and see what it is looking for, and if that exists elsewhere.
  • andypugh
  • andypugh's Avatar
05 Jun 2025 10:34
Replied by andypugh on topic G0 not zero? (more info)
Does the "G54 Work" change to G55 if you are in G55? (I am not familiar with probe basic)
  • andypugh
  • andypugh's Avatar
05 Jun 2025 10:30
Replied by andypugh on topic reference during rotorhoming
Can you elaborate?
What triggers the motor to home?
  • Aciera
  • Aciera's Avatar
05 Jun 2025 08:32
  • BlownCorona
  • BlownCorona
05 Jun 2025 07:01
Replied by BlownCorona on topic Mesa 7i97T & LinuxCNC setup struggles
i have struggled to find out what "mode" my drivers run in. as far as i can tell there is no option to choose between the torque or velocity.
My drivers are Advanced Motion Control (branded as Precision Valve & Automation) B12A6F-PV2. i have not been able to track down any manual or documentation for this specific drive, but i do have a general setup guide from AMC which covers this era of hardware and gives me some idea of how to operate it.
www.a-m-c.com/wp-content/uploads/support...ual_Analog_Panel.pdf
However in re reading the above documentation i think the dip switch labeled "open loop" on my drive (which is switched off) is the mode change switch, with "open loop" being velocity, and the alternative being torque. Pages 14 - 16 have the modes of operation, but my drives do not have all those options. below is an image of what i have showing the pots and the dip switches.
www.a-m-c.com/product/b12a6/
  • alexandrap
  • alexandrap
05 Jun 2025 06:57 - 05 Jun 2025 06:59
Replied by alexandrap on topic Updating pncconf for 7i95t
Category: PnCConf Wizard
texas instruments TPS2596 - 2.7 to 19 V, 0.125 to 2-A, 89-mΩ eFuse With Accurate Current Monitor and Fast Overvoltage Protection
Adjustable overvoltage lockout (OVLO) with a
response time of 1.3-μs (typical
  • Lcvette
  • Lcvette's Avatar
05 Jun 2025 06:12
Confused about how to set up Probe Basic on a Raspberry Pi
Category: QtPyVCP
we do now have rpi4 apt installation, just need to follow the installation guide for it. it is built in our buildbot.
kcjengr.github.io/probe_basic/development_quick_start_apt.html
  • Lcvette
  • Lcvette's Avatar
05 Jun 2025 06:05
Porbe basic lathe: Questions about the keyboard
Category: QtPyVCP
ok i have reworked keyboard jogging, it now has the following functionality and is available in the latest apt install for develop branch.
ini settings:
KEYBOARD_JOG = true
(turns keyboard jogging on)
KEYBOARD_JOG_SAFETY_OFF = true
(removes the need for the control key)
shift key + jog key will give you rapid jog speed (works in safety mode and normal mode)
jog key gives you jog speed with jog feed override slider percentage applied
Probe Basic Lathe uses the following for keyboard jogging:
Left and Right arrow keys for Z axis
Up and Down arrow keys for X Axis
(in the display section, set one of the following entries only, LATHE is for front tool post, BACK_TOOL_LATHE is for rear mounted tool post)
[DISLPLAY]
LATHE = 1
(this makes X Positive direction jog key the down arrow key)
BACK_TOOL_LATHE = 1
(this makes X Positive direction jog key the up arrow key)
I think these all make sense and follow the linuxcnc std a little more closely!
Best Regards,
Chris
  • Kieran
  • Kieran
05 Jun 2025 05:15
Replied by Kieran on topic xml and hal - I am lost
Category: EtherCAT
Ive got a single X axis going!
I used info from here...    forum.linuxcnc.org/ethercat/54965-stepperonline-a6-servo
My main problem this evening was installing the cia402  hal correctly. I ended up just making a dedicated folder home/linuxcnc/cia402 and placed cia402.comp there.
 Then I opened the terminal and  >>     sudo halcompile --install cia402.comp
that worked!
  • juliankoenig87
  • juliankoenig87
05 Jun 2025 04:50
Replied by juliankoenig87 on topic Toyota embroidery machine - retrofit
Category: CNC Machines
To be honest. I think I would ad a lever and a switch for homing (plus index). But it depends. Maybe you want to have it as original as possible?
  • juliankoenig87
  • juliankoenig87
05 Jun 2025 04:47
For homing I would meassure how much the resistor value changes for one motor revolution. After that one can think of solutions. That said. It would be a good step to identify the ratios of the axis.
For the needle encoder. Plug it to a mesa card (first test with bench power supply and oscilloscope) and turn 10 revolutions....
  • rodw
  • rodw's Avatar
05 Jun 2025 03:08
Replied by rodw on topic Using the preinstalled vnc server
I can assure you a VNC of any kind is not included in the distribution ISO.
Displaying 2236 - 2250 out of 24997 results.
Time to create page: 0.339 seconds
