27 Jul 2024 18:39
Replied by tommylight on topic PIN Allocation another search for answers
Category: Installing LinuxCNC
You are not helping yourself.
Go back and read your posts, then come back and tell us they are OK.
You can not, as they are from extremely short with absolutely no information to go on, to plain ignoring what info we asked you to provide, to refusing to test what was proposed to you.
  • Aciera
  • Aciera's Avatar
27 Jul 2024 18:15 - 27 Jul 2024 18:16
Replied by Aciera on topic PIN Allocation another search for answers
Hi, I am not getting any help on this forum
Well frankly, as somebody who has tried to help you several times on this very forum I find this a little hard to take. Instead of answering questions about your setup or following the advice you're given you just go and open a new topic asking the same question all over again. It's like yelling into a black hole.
I'm going to give this one more shot in the dark and then I'm done:
in your hal file change this:
net spindle-on => parport.0.pin-14-out
to this:
net spindle-on <= spindle.0.on => parport.0.pin-14-out
27 Jul 2024 17:45
Replied by tommylight on topic Motor locks but will not move when testing
Category: StepConf Wizard
Tried 0xd800 no change in behavior.... I hear the relay click...not sure why that is happening
OK that should confirm it is working, so set the base period to 100000 and step time and space to 10000 and try to jog the machine.
  • Lpkkk
  • Lpkkk
27 Jul 2024 17:43 - 27 Jul 2024 17:45
How to fix timeout error during uploading config for nvem board?
Ping 10.10.10.10 went OK
  • Irritant
  • Irritant
27 Jul 2024 17:41
Hi, I am not getting any help on this forum so I thought someone may have had this issue and hopefully found a cure.
The problem:
My new install seems okay but LinuxCNC will not turn the spindle (Bosch router) on. The info for my Probotix Unity controller says pin 14 is the spindle.
I select his and/or invert and it does not work and many others. I have attached the ini and hal files. The date on the file is when I started on this installation, pretty much full time. Right now I have it plugged into a power bar and I flip on and off.
I had a problem where the axis would not move. I was told the change the table size and it worked. So somehow the table size setting are interconnected with the ability to move.
  • juliankoenig87
  • juliankoenig87
27 Jul 2024 17:05
Replied by juliankoenig87 on topic error finishing read!
Category: Driver Boards
As far as I understand he has to comment out this line:
source /etc/network/interfaces.d/*
Best regards
Julian
  • cutnweld
  • cutnweld
27 Jul 2024 16:47
Replied by cutnweld on topic X and Y switched
X and Y switched
Category: Plasmac
As far as Gcode goes, it was done in conversational, long gone.I am not sure which version I am running but it is probably at least 2yr old. BTW I would like to thank all who have been a part of the plasmac interface development, I came from Mach3 to Plasmac, it was like going from riding an oxcart to driving a Mercedes. It is so easy to run and to learn, in the old mach3 days I would have a random torch dive and estop, sometimes wading thru thousands of lines of gcode to figure out where to restart, now I rarely ever have a thc issue and if there is a problem its easy as pushing rewind. Plus a Bucket list of other things that are way superiour. I have several miles of cutting logged on by now and very few issues. Thanks again.
  • hanskuster
  • hanskuster's Avatar
27 Jul 2024 16:30
Replied by hanskuster on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi all, hi scotta,
I reflashed my EC500 with the newest firmware to check if the NVMPG now works.
After reflashing LinuxCNC doesn't connect anymore. The EC500 doesn't respond to pings either.
I wanted to erase the EC500 to reflash it from new, but erase doesn't work anymore.
Issuing this command:
pyocd erase --target mimxrt1050_quadspi --mass
returns this error message:
0000718 C No ACK received [__main__]
I use a DAP Link btw.
I flashed the newest firmware to a second EC500, and now this one seems to bricked also.
I can't erase nor re-flash both of them anymore.
How can I un-brick them?
regards, hanskuster
  • chernogorsky
  • chernogorsky
27 Jul 2024 16:24
Replied by chernogorsky on topic Work with probe
Work with probe
Category: Basic Configuration
Have some issue, cant make Probe height for current tool / Probe height and dia of the current tool working
all other functions works, but that 2 probing remain disabled
versaprobe is set and working
pi4 / linuxcnc 2.9.1 / qtdragonhd
Tool measure enabled
M6 remap done
toolsetter xyz set, speed, dia, rev speed seet
[TOOLSENSOR] X = -112.285 Y = -253.954 Z = -30 MAXPROBE = -60 RAPID_SPEED = 600 TS_DIAMETER = 19.72 REV_ROTATION_SPEED = 0 [VERSA_TOOLSETTER] X = -135.39 Y = -233.91 Z = -2 Z_MAX_CLEAR = -2 MAXPROBE =  125 RAPID_SPEED = 600 TS_DIAMETER = 19.72 REV_ROTATION_SPEED = 2000 [CHANGE_POSITION] X = -135.39 Y = -233.91 Z = -2 [RS274NGC] PARAMETER_FILE = linuxcnc.var RS274NGC_STARTUP_CODE = G21 G40 G90 G94 G97 G64 P0.025 SUBROUTINE_PATH = ~/linuxcnc/nc_files:~/linuxcnc/nc_files/remap-subroutines:~/linuxcnc/nc_files/remap_lib:~/linuxcnc/nc_files/ngcgui_lib ON_ABORT_COMMAND=O call REMAP=M6  modalgroup=6 prolog=change_prolog ngc=qt_auto_probe_tool epilog=change_epilog
  • geostein8888
  • geostein8888
27 Jul 2024 16:10
Replied by geostein8888 on topic BOB wiring
BOB wiring
Hello,
these white connectors are to nonnect the steppers via such cables who fit in
by the way, did you got the endswitches/ref switches to work? i have now the second board and the signal is not coming through to linuxcnc, i have connected the 12V
do i need to use the GNDon the input pin blocks for the sensors somehow instead of the gnd i use for the step/dir signals?
Georg
  • Aciera
  • Aciera's Avatar
27 Jul 2024 15:40
Replied by Aciera on topic Trajectory Planner using Ruckig Lib
I see.
Very handy to have these graphs. Like hal-scope for the preview.
  • Grotius
  • Grotius's Avatar
27 Jul 2024 15:25
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Hi Arciera,
The red is the vm based on curvature.
Forward sweep starts at zero vel. Backwards sweep start at zero vel.
Then the algo has to look if the velocity may be increased or not.
  • Aciera
  • Aciera's Avatar
27 Jul 2024 13:53
Taig Lathe conversion to LinuxCNC: M3 is not turning on spindle
Is this something that could have been done from StepConfig? Or do I have to edit the hal file manually?
I'm not sure but I guess you did not configure a spindle in StepConf hence your hal file has no spindle entries at all.
  • Aciera
  • Aciera's Avatar
27 Jul 2024 13:46
What is the line in red and how do you choose the start velocity for a segment in the forward and backward sweep?
  • Grotius
  • Grotius's Avatar
27 Jul 2024 13:27
Hi Arciera,
A time optimal algo we can add on the todo list. It's really interesting to code this, and see the results.
I have no idea how difficult it is to code this.
For now i plotted the trajectory path lenghts vs the velocity profile on the xz plane.
Then for fitting the scurve on the trajectory (look ahead), we could do a forward sweep in white.
Then a backward sweep in green.
Then get the create a final blue curve that is below the green & white curve.
The blue curve is the overall path velocity profile. I think this should be correct.
Displaying 24466 - 24480 out of 25072 results.
Time to create page: 0.523 seconds
