  • Cdub
  • Cdub
27 May 2025 21:20
Replied by Cdub on topic M62-M68 codes not working
Category: Plasmac
Doesn’t work. Says “does not have release file”
  • Studio_TC
  • Studio_TC
27 May 2025 21:15
Getting Setup with PC and MESA was created by Studio_TC
I have a Sherline 5400 CNC that has been in storage and I am planning on getting it up and running again (it's been some years).  I am computer shopping and weighing options and looking into what has changed.  My previous setup was a PC Tower with a Parallel port running to a Gecko 540.  Instead of replacing that setup in-kind, I am looking into using a small form factor (or mini) computer with a MESA ethernet card.  Am I understanding things correctly that I can use a small/mini computer with ethernet, run it to a MESA 7i92TF, which in turn runs to my Gecko 540 (thereby skipping a PCIe parallel port card)?  Also do I need to worry about male/female couplings for the MESA DB25 (7i92TF vs 7i92TM) or can it be managed with gender changers (not ideal) or are there signal considerations with gender changers?  Finally, to confirm, I should be using the preempt-RT kernel if I am going to use MESA ethernet?
I have been reading here and the docs, but I am still a little overwhelmed playing catchup and appreciate any guidance before I purchase a PC and MESA Card.
Thanks,
Tom
27 May 2025 20:50
Replied by tommylight on topic Up grading Debian 12 rt
How am I running a raspberry pi all of a sudden?
You are not, it is a remnance of a Debian f@kup that is still dragging on.
Is it possible to install a nvidia graphics card and still use Linuxcnc?
Most probably not, proprietary NVIDIA drivers did not work at all on RT-Preempt kernel last i tried over a year ago.
You are welcomed, always.
  • Hastrh2o
  • Hastrh2o
27 May 2025 20:47
Replied by Hastrh2o on topic Mecanumeric MF2040 LI retrofit (Pantograph)
Category: Milling Machines
I have read your description on usinages.com (I'm french).
I have bought Delta motors from Movitecnic in France, they are really helpful and have good prices.
I used Leadshine on stepper system only, it was ok.
27 May 2025 20:45
Replied by tommylight on topic M62-M68 codes not working
Category: Plasmac
Not exactly sure but i think that is the wrong buildbot, try
buildbot.linuxcnc.org
  • Hastrh2o
  • Hastrh2o
27 May 2025 20:32
Replied by Hastrh2o on topic cnc sur bordeaux
cnc sur bordeaux
Category: Français
Envoie moi un sms au 0699361110 quand tu vois ce message
  • Cdub
  • Cdub
27 May 2025 20:17 - 27 May 2025 20:20
Category: Plasmac
Ok I cannot make any sense of this I have been trying to update to 2.10 for the past few hours thinking that 2.9 might be the root of anll my problems and can’t figure it out. I went into sympathetic package manager then repositories and deleted the two lunixcnc.com lines and refreshed. I then created a new one as follows
buildbot2.highlab.com/debian/
bookworm
master-uspace
then when I enter “sudo apt update” in the terminal it gives me the error I attached bellow. I have read through these post several times, but just end up more confused each time.
www.forum.linuxcnc.org/38-general-linuxc...-do-i-update-to-2-10
forum.linuxcnc.org/9-installing-linuxcnc...ate-from-2-9-to-2-10
Some clarification would be amazing, thank you.
  • aaron
  • aaron
27 May 2025 20:09
Replied by aaron on topic Up grading Debian 12 rt
Thank you for this. That did the trick, but I have a couple of questions.
And
Thanks again
Aaron
  • pgf
  • pgf
27 May 2025 20:00
Replied by pgf on topic ISO: very basic gladevcp panel
Category: GladeVCP
My setup isn't actually *that* primitive. The touch-off plate is a very nice bar of aluminum that is about 2" long and *exactly* 3/8" on every side. I found it in my scrap box, and it already had a threaded hole in one side. Very convenient. And because it's square, I can use it in almost any orientation. (I remeasure it once in a while because I still can't believe that it's exactly square in cross-section.)
In addition to the panel, I have a (shell) script which will tail the probe log, and based on the last two probe entries it will give me either the angle at which the work is sitting (if the probes were both from the same side) or the center point between the probes (if they were in opposite directions). As output it prints the G10 L20 line necessary to make use of the result. So I can do much of what Easyprobe does. Just not quite as Easy. ;-)
  • User_paulvdh_42
  • User_paulvdh_42
27 May 2025 19:43
Replied by User_paulvdh_42 on topic Loading different configurations during startup.
Category: Basic Configuration
... and frankly i see no need for it, you would have to change stuff mechanically first then start a config for that setup.
No restart of the PC required for running different configs.
Indeed. That is the intention.
The old machines such as the Hommel require quite a lot of work to setup, because everything is mechanical, and drive axles for auto feed and such have to be reconfigured manually too. In my modernized version accessories such as for example a rotary table or an XY table get their own built in stepper motor(s), and you just plug it into the control box and load the fitting configuration. So you first reconfigure the hardware, and you load the (preconfigured) corresponding configuration. Goal is to have 4 to 8 different configurations. For example for:
  1. Vertical milling.
  2. Horizontal milling.
  3. Line Boring.
  4. 4th / possible 5th axis configuration.
Below a picture of the same Hommel machine, but configured as a lathe.
So you can start with a 3 axis machine, use it to make a rotary table, and then extend it to 4 or even full 5 axis, but also go back to 3 axis, because that allows for more rigidity and heavier machining. Andysmachines has made some excellent youtube tutorials on gear milling, and this has a lot of error prone manual machining, which also gets boring very quickly. And this begs for more automation. The goal is not to work with mechanical CAD that spits out a big G code file, but to write some python code that generates some G code for special applications. For example gear cutting with a disk mill, or with a profile mill. The number of teeth for the gear is then just a number in a for loop (and a radius change).
So the question still is: How do you load different configurations in LinuxCNC? Is this a command line option, do you have to fiddle with configuration files outside of LinuxCNC? Does a configuration change also reprogram the Mesa card without a hard reset?
My experience with LinuxCNC is very limited. I did some short tests with Machinekit some 10 years ago, and recently I tried it on 3 different PC's, but latency tests were atrocious, so I need better hardware. I'm also still in doubt to whether go with LinuxCNC or to stick with something simpler such as GRBL. Worst case scenario for multiple configurations, is to write a script that interprets G code, and then swaps axis and direction, and write it back to another file.
  • clayton2ndtry
  • clayton2ndtry
27 May 2025 19:35
Replied by clayton2ndtry on topic Known good USB wifi for linux....
Someone here told me to get a now I cannot remember which chipset, but SMC Wireless USB 2.0 Adapter matched it on Amazon. I just plugged it in and now, instead of 24 Kbps, I have 15 Mbps. (My shop is several feet below the router. A refrigerator is also in the path.)
  • juliankoenig87
  • juliankoenig87
27 May 2025 19:34
Higher (more than 5V) step/dir voltages with mesa cards (7i96)
Yes. I also think its the easies solution.
Darlington transistors at each driver is way more work.
Thanks for the hint. Will do it with an array.
  • Aciera
  • Aciera's Avatar
27 May 2025 19:25
Replied by Aciera on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
R denotes the XY rotation angle around the Z axis.
www.linuxcnc.org/docs/html/gcode/overvie...gcode:ini-hal-params
Looks like there has been a discussion about it but it seems to have stalled:
github.com/LinuxCNC/linuxcnc/issues/3064
  • juliankoenig87
  • juliankoenig87
27 May 2025 19:22
Replied by juliankoenig87 on topic EasyProbe + PGFUN 3D probe
Hehe,
yes, I never ever thought about having z positive down :-)
  • Hakan
  • Hakan
27 May 2025 19:20
resolved-- Regarding the data reading offset issue of the ether cat IO module
Category: EtherCAT
Have you tried in TwinCAT? Does it work there? If not, the device is faulty.
Displaying 2881 - 2895 out of 24887 results.
Time to create page: 0.256 seconds
