  • cmorley
  • cmorley
17 May 2025 18:23
Replied by cmorley on topic Error in tool_offsetview.py
Category: Qtvcp
That would work.. I pushed something similar before your post.
  • johnB
  • johnB
17 May 2025 18:05
Raspberry with LinuxCNC direct interface
I wonder, is there a Raspberry HAT that can direct interface with a stepper driver ?
Jonh.
  • pgf
  • pgf
17 May 2025 18:00
Effect of lengthening the servo thread period?
Category: Basic Configuration
I'm using a Raspberry Pi 4 to drive a Mesa 7i96.   For unknown (as yet) reasons, I can't reliably run without errors unless I bump SERVO_PERIOD to 2000000 (i.e., 2ms).
What affect will this have on machine operation?  I sort of understand what's scheduled to run in the base thread, which of course is largely (completely?) irrelevant now that I have the Mesa.  But I don't have a good mental model for what runs in the servo thread, so I don't have a good understanding of what happens to operation/performance if it only runs half as often as usual.  Where would the difference show up?
Until recently my mill maxed out at about 40ipm, so absolute performance wasn't really a consideration.  I've upgraded to a machine capable of at least 80ipm using Grbl, and initial tests with LinuxCNC and the Mesa card indicate 100ipm may be fine.  So now I'm wondering if I need to start worrying more about that servo thread.
paul
  • PCW
  • PCW's Avatar
17 May 2025 17:57
Replied by PCW on topic el5151 reseting counts
Category: EtherCAT
Yes, it seems like some encoder option is not set correctly.
Clearing the count on every index really makes no sense for
general encoder use.
  • Aciera
  • Aciera's Avatar
17 May 2025 17:22 - 17 May 2025 17:22
Replied by Aciera on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
I don't really know but it seems to be set in the ini file:
  • zz912
  • zz912's Avatar
17 May 2025 17:22
  • Muftijaja
  • Muftijaja
17 May 2025 16:41
Two switches/sensors for tool length and 3d touching into motion-probe-in? Howto
Thanks, PCW for this example! I try this out the next days.
or2 is not used actually. 3D is NO and WZL is NC, otherwise I would have put them both in series.
I will see if I have to delete the -not for the 3D switch.
Thanks a lot and have a nice weekend!
Hanno
  • Doc_emmet
  • Doc_emmet
17 May 2025 16:20
Replied by Doc_emmet on topic Install Probe Basic
Install Probe Basic
Category: QtPyVCP
I've installed everything.
Also:
sudo apt update
sudo apt --fix-broken install
sudo apt install python3-qtpyvcp
sudo apt install python3-probe-basic
cd ~
mkdir dev
cd dev
git clone github.com/Lcvette/qtpyvcp-bookworm-installer.git
cd qtpyvcp-bookworm-installer
./install_for_qtpyvcp.sh
./updater.sh
And yet I still get this error:
File "/usr/bin/probe_basic", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3/dist-packages/probe_basic/__init__.py", line 20, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/usr/lib/python3/dist-packages/qtpyvcp/__init__.py", line 26, in run_vcp
run(*args, **kwargs)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/__init__.py", line 129, in run
launch_application(opts, config)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 78, in launch_application
loadWindows(config)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 230, in loadWindows
window = _initialize_object_from_dict(window_dict)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 210, in _initialize_object_from_dict
return obj(*args, **kwargs)
File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 53, in __init__
self.load_user_tabs()
File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 87, in load_user_tabs
user_tab_folders = os.listdir(user_tabs_path)
FileNotFoundError: [Error 2] File or directory not found: 'user_tabs/ # REQUIRED Setting for Probe Basic'
Where is the 'user_tabs/' folder supposed to be? I've moved it to:
linux/configs and, just to be on the safe side, to linux/configs/My_Machine
  • Aciera
  • Aciera's Avatar
17 May 2025 16:13 - 17 May 2025 16:14
Replied by Aciera on topic Python - find out if HAL pin exist
Try this:
try:
    value = hal.get_value("halui.halui-mdi-is-running")
    exists = True
except Exception:
    exists = False
print(exists)
  • PCW
  • PCW's Avatar
17 May 2025 15:38
Something like:
loadrt or2
addf or2.0 servo-thread
net probe-wzl  <= hm2_7i76e.0.7i76.0.0.input-08-not => or2.0.in0
net probe-3d   <= hm2_7i76e.0.7i76.0.0.input-09-not => or2.0.in1
net probe-in     =>  motion.probe-input <= or2.0.out
Notes:
This assumes the "or2" is not already used
(if its already used, you need to add a new instance with the names or count stanza)
Also not sure of the individual 3d and wzl polarities
  • zz912
  • zz912's Avatar
17 May 2025 15:33
Python - find out if HAL pin exist was created by zz912
Hello,
I need read HAL pin in Python. It is not problem for me:
        print(value)
If the "HAL pin" exists, there is no problem:
The problem occurs when the "HAL pin" does not exist:
[Gmoccapy][ERROR]  Found an error!
The following information may be useful in troubleshooting:
  File "/home/zdenek/linuxcnc/linuxcnc-zz912/bin/gmoccapy", line 4220, in on_tbtn_flood_toggled
RuntimeError: Can't set value: pin / param halui.halui-mdi-is-running not found
 (gmoccapy:62)
I would first need to find out if this "HAL pin" exists and then find out its value.
But I dont know How.
1)
Python HAL interface can check only component, not only "HAL pin".
www.linuxcnc.org/docs/html/config/python-hal-interface.html
 component_exists
    Does the specified component exist at this time.
Example
hal.component_exists("testpanel")
2)
Maybe I could use Python's "Try:"
But I don't know how. I would need to check in initialization if the pin exists and store it in a variable:
halui_cmd_exist = True
or
halui_cmd_exist = False
  • DonatasO
  • DonatasO
17 May 2025 15:17
G53 not ignoring tool length offset after a Python M6 remap
Thanks again!
Looking at the file you linked, I see ways to simplify some parts in my remap.
This is resolved now. Only the tool length sensor's side will remain scarred :D
  • Aciera
  • Aciera's Avatar
17 May 2025 15:10
At least my understanding about emccanon.USE_TOOL_LENGTH_OFFSET() is that it's supposed to be the equivalent of G43, as it issues the same EMC_TRAJ_SET_OFFSET message. Apparently, it does not fully update the initial state.
note that 'G43' reads the tool-offset values from the tool table:
github.com/LinuxCNC/linuxcnc/blob/6c4303...erp_convert.cc#L6202
and calls emccanon.USE_TOOL_LENGTH_OFFSET() in line 6280:
  USE_TOOL_LENGTH_OFFSET(tool_offset);
BUT it also sets 'tool-offsets' in line 6299:
 settings->tool_offset = tool_offset;
So it seems that you will have to handle this in the remap.
  • Muftijaja
  • Muftijaja
17 May 2025 15:02
PCW, thanks a lot for the advice with the smaller resistor! I found one 2.2k with 1W in my boxes and used that today and voilá, it works as it should. Problem solved, I hope. (Don't know if I need noise reduction)Guys, I have no idea how to use sth like mux or mux_generic. I wouldn't even be able to use two inputs - but just out of curiosity , how would you do that in a HAL file if i would use an OR2:
 loadrt or2 count=1
net probe-in     <=  hm2_7i76e.0.7i76.0.0.input-08-not
and the second input hm2_7i76e.0.7i76.0.0.input-09 ? my programming scills are beginner level...
(Yes, I read the example in the LCNC HAL Examples to OR2 but I cannot convert that for my problem.)
Thanks and best regards!
Hanno
  • DonatasO
  • DonatasO
17 May 2025 14:53
My guess would be that your change of tool-length is possibly not reflected in 'tool_offset.tran.z'.
You're right, it's not updated. Setting `self.tool_offset = pose` manually resolves the issue.
Am I missing some call to auto-update it, or does it have to be handled in the remap?
Displaying 3691 - 3705 out of 24608 results.
Time to create page: 0.239 seconds
