  • Hakan
  • Hakan
19 Aug 2025 14:28
Replied by Hakan on topic ARE YOU KIDDING ME YOUTUBE !!!
I wonder if ads are connected to monetisation. I think youtube puts in ads "always".
It's just you get a share of the income. When I was active I got around 100 bucks every three months.
In the end I ran out of subjects and appreciated being without the constant chase for content.
Nice experience, nice to be without.
  • andypugh
  • andypugh's Avatar
19 Aug 2025 13:56
Replied by andypugh on topic ARE YOU KIDDING ME YOUTUBE !!!
I have looked into monetisation, but it looks like my lifetime earnings would have been about $25 over the last 15 years, and I prefer not to annoy my subscribers with adverts.
  • andypugh
  • andypugh's Avatar
19 Aug 2025 13:53
You can monetise YT if you have 1000 followers and 4000 hours/365 days so I am on a mission to get to 4000 watch hours.
I think it is 3000 watch hours and 500 subscribers?
  • emresensoy
  • emresensoy
19 Aug 2025 13:52
EtherCAT RC Servo Motor & PWM Output Interface Board
Category: Show Your Stuff
I don't actually know where it's used. However, this board essentially has open-collector PWM outputs. It could be used in PWM-controlled proportional valves, etc., and other components.
As you mentioned, an RC servo motor could offer a fast way to mechanically implement LinuxCNC's powerful robotic infrastructure.
  • Clemens
  • Clemens
19 Aug 2025 13:42
Maybe it helps if I give you more information about my machine.
I have a 4 Axis Mill with 1X 2Y 1Z
In the attachment I added the configuration of the machine and the configuration of the NVEM. I also added the g-code file where I can reproduce the problem
I hope this helps.
Let me know if you need something else
Clemens
  • andypugh
  • andypugh's Avatar
19 Aug 2025 13:03
Replied by andypugh on topic Round system parameter to tenths?
Category: G&M Codes
Is there a code for the g-code to get a result in parameter, like in the debug
%.xf = x (0-9) number of decimals?
No, sorry.
But if you just want to compare two numbers to see if they differ by less than a certain amount:
O100 IF [ ABS[#100 - #101] LT 0.01]
  <do stuff>
O100 ENDIF
linuxcnc.org/docs/html/gcode/overview.html#gcode:functions
linuxcnc.org/docs/stable/html/gcode/o-co...ml#ocode:conditional
  • andypugh
  • andypugh's Avatar
19 Aug 2025 12:53
Replied by andypugh on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
Can I ask if any users of the macros have found that the latest version, with LinuxCNC 2.9.x is very slow? At the moment my whole UI is very slow to respond to button presses etc.
I hope it's not like that for everyone?
My guess is that the redraw/resize is being called continuously, but I haven't found the time to investigate yet.
  • andypugh
  • andypugh's Avatar
19 Aug 2025 12:43
New member from Germany - CNC retrofit of a Leinen FM1
Is there any chance to get connected to the LinuxCNC developer in Münster?
I have passed on your email address, but he says that he already reached out to you on a German forum?
  • andypugh
  • andypugh's Avatar
19 Aug 2025 12:41
Request for Community Feedback on g-code++ (sterp) Integration with LinuxCNC
Right now gcode++ extends g-code by introducing for loops, while/do-while loops, as well as imports (currently working on test cases for the same for the latest LinuxCNC release).
You know that LinuxCNC G-code already has do/while loops?
linuxcnc.org/docs/stable/html/gcode/o-code.html
  • mBender
  • mBender
19 Aug 2025 12:37
I am successful and fully transition from my old Parallel Port PC to an I7 Laptop with Riocore! Finally I am able to browse something without waiting forever :D Thanks Olli! This is great stuff.
I have my
- whb04b-06 Hand wheel operating
- Classic Ladder with RS 485 Modbus working (over an dedicated RS485 USB Dongle)
- Auto squaring Y Axis
- Touch plate/Probe input
It was not terrible, but I feel like I have modified a lot of ini and hal files which were created automatically to make this work. Is there a way that you could add a checkbox or so to ricocore gui to not overwrite the existing config files?
I don't know what the best workflow would be. I think if I want to add another function to the FPGA i I will just do it in a separate folder and flash the FPGA, then add the changed manually to my machine folder ?!?
  • andypugh
  • andypugh's Avatar
19 Aug 2025 12:36
Replied by andypugh on topic Weird problem happening during g71, g70 cycle
Look at the files in the sample directory. They should be already part of your installation, but you can also see them here:
github.com/LinuxCNC/linuxcnc/tree/master/nc_files
Look at the lathe_g7* files.
  • unknown
  • unknown
  • unknown
  • unknown
19 Aug 2025 08:45
OK, there only dif in mine clone was the SPI & FPGA clk pins. Seemed to be very picky regarding that.
Any code in the repo yet ?
  • xenon-alien
  • xenon-alien's Avatar
19 Aug 2025 08:45
Replied by xenon-alien on topic Round system parameter to tenths?
Category: G&M Codes
Hello.
I have the same question.
After probing i have the Z coordinate value.
I measuring 2 points to align the B axis.
I'm doing it 2 times.
The 2nd measuring if gives a result with equal 2 decimals don't rotate the B axis.
Displaying 13501 - 13515 out of 14141 results.
Time to create page: 0.455 seconds
