  • Sekai
  • Sekai
09 Aug 2025 10:06
Replied by Sekai on topic Tool setter in gmoccapy error.
Category: Gmoccapy
i have the folder macros with change.ngc and on_abort.ngc
  • zz912
  • zz912's Avatar
09 Aug 2025 10:02
Replied by zz912 on topic Tool setter in gmoccapy error.
Category: Gmoccapy
The most important information is:
NGC file not found: ngc=change - 51:REMAP = M6 modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
  • Asymmetrisch
  • Asymmetrisch
09 Aug 2025 09:03
Replied by Asymmetrisch on topic Glasmaßstab EIA-422 an Mesa 7i85 (S)
Category: Deutsch
Bei den SINO-Glasmaßstäben ist die gleiche Pinbelegung wie bei den Ditron angegeben, sollte also so passen.
In der Bedienungsanleitung steht "Nullpunkt-Position: eine alle 500 mm" - weißt du, wo die auf deinen Maßstäben liegen?
  • Sekai
  • Sekai
09 Aug 2025 08:56 - 09 Aug 2025 08:58
Tool setter in gmoccapy error. was created by Sekai
Category: Gmoccapy
Hi.I'm trying to put a automatic tool setter in my 3 axis cnc so i follow the instructions from: linuxcnc.org/docs/html/gui/gmoccapy.html...uto-tool-measurement
but it gives me and error when remap is activated.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.8.4
Machine configuration directory is '/home/cnc/linuxcnc/configs/freza-mea'
Machine configuration file is 'freza-mea.ini'
INIFILE=/home/cnc/linuxcnc/configs/freza-mea/freza-mea.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=gmoccapy
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./freza-mea.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: gmoccapy
emc/task/emctask.cc 416: interp_error: File not open
File not open
emc/task/emctaskmain.cc 3091: can't initialize interpreter
A non blocked signal was caught
Debug file information:
/usr/bin/gmoccapy:312: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
/usr/bin/linuxcnc: line 896: 9599 Killed $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
9557
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 7626.194278] I-pipe: head domain RTAI registered.
[ 7626.194283] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 7626.194308] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7626.194311] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623640, CLK_FREQ 2926144000, CPU_FREQ 2926144000
[ 7626.194314] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 7626.194316] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623640, 16623640, 16026250
[ 7626.200721] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7626.200747] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 7626.200750] RTAI[sched]: hard timer type/freq = APIC/16623640(Hz); default timing: oneshot; linear timed lists.
[ 7626.200753] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2926144000 hz.
[ 7626.200755] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 7626.204552] RTAI[math]: loaded.
[ 7626.339838] config string '0 out'
[ 7635.304394] RTAPI: ERROR: Unexpected realtime delay on task 1
[ 7635.304396] This Message will only display once per session.
[ 7635.304397] Run the Latency Test and resolve before continuing.
[ 7648.985468] RTAI[math]: unloaded.
[ 7648.986662] SCHED releases registered named ALIEN PEDV$D
[ 7648.991033] RTAI[malloc]: unloaded.
[ 7649.088014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7649.089454] I-pipe: head domain RTAI unregistered.
[ 7649.089483] RTAI[hal]: unmounted.
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: joi 7 august 2025, 22:07:47 +0300
UTC Date: joi 7 august 2025, 19:07:47 +0000
this program: /usr/bin/linuxcnc_info
uptime: 22:07:47 up 2:07, 0 users, load average: 0,06, 0,10, 0,13
lsb_release -sa: Debian Debian GNU/Linux 7.11 (wheezy) 7.11 wheezy
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/cnc/linuxcnc/configs/freza-mea
USER: cnc
LOGNAME: cnc
HOME: /home/cnc
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1280x1024 pixels (338x270 millimeters)
PATH: /usr/bin:/home/cnc/linuxcnc/configs/freza-mea/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: cnc
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
machine -m: i686
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=ce037f87-68af-43a0-8860-fcd14ee0c100 ro initrd=/install/initrd.gz lapic quiet rootdelay=5
model name: Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz
cores: 2
cpu MHz: 2926.144
parport: 0378-037a : parport0
serial: 03f8-03ff : serial ec98-ec9f : serial
Versions:
gcc: gcc (Debian 4.7.2-5) 4.7.2
python: Python 2.7.3
git: git version 1.7.10.4
git commit: NA
tcl: 8.5
tk: 8.5
glade: not_in_PATH
glade-gtk2: glade3 3.8.0
linuxcnc_var all:
LINUXCNCVERSION: 2.8.4
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: /usr/realtime-3.4-9-rtai-686-pae/bin/rtai-config
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Dorit=necUnoscut/Instalează/șteRge/curăță(P)/păstrează(H)
| Stare=Ne/Inst/fișCfg/desfăcUt/jum-conF/jum-inst(H)/așteaptă-decl(W)/decl-în-aștepT
|/ Ero?=(nimic)/Reinst-nec (St,Ero: majuscule=rău)
||/ Nume Versiune Architecture Descriere
ii linuxcnc 1:2.8.4 i386 motion controller for CNC machines and robots
un linuxcnc-doc <none> (nici o descriere disponibilă)
ii linuxcnc-doc-en 1:2.8.4 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> (nici o descriere disponibilă)
un linuxcnc-uspace <none> (nici o descriere disponibilă)
I still dont know to fix it.
the debian is wheezy.
thanks
  • juergen-home
  • juergen-home
09 Aug 2025 08:35 - 09 Aug 2025 08:43
Replied by juergen-home on topic China BOB with Relais, clarification help, mesa 5i25
Category: Driver Boards
  Yes, the input pins don't work without 12-24v on the china bob mach3. They are supplied with the 10V generated from that input. Output Schematic is here forum.linuxcnc.org/27-driver-boards/3905...uts-inputs-ok#167355 (Mach3 Interface Board)
  • Hakan
  • Hakan
09 Aug 2025 08:25
modprobe: ERROR: could not insert 'ec_master': Key was rejected by service
Category: EtherCAT
Certainly an issue with secure boot and unsigned kernel modules, so the author is on the right track.
Twenty lines down there is a hidden spoiler section with more instructions, in case they were not seen.
The ec_master and ec_generic modules are built during ethercat package installation to fit the current kernel.
The modules do not get signed properly as required by secure boot. There was a case some months back
despite switching off secure boot in bios the kernel refused to load the modules.
By googling around it seems possible the modules can be signed but it is not so easy, but you can always try.
Switching off secure boot should work but doesn't always it seems.
  • Hakan
  • Hakan
09 Aug 2025 08:13
Replied by Hakan on topic Amplifier Fault ECT60 Closed Loop
Category: EtherCAT
I have three ECT60 and never had a problem. That's not any help of course, but I can offer my config.
<masters>
  <master idx="0" appTimePeriod="1000000" refClockSyncCycles="5">
    <slave idx="0" name="X" type="generic" vid="00000a88" pid="0a880002" configPdos="true">
      <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
      <sdoConfig idx="2000" subIdx="0"><sdoDataRaw data ="a0 0f"/></sdoConfig>  <!-- Max motor current (3.0A=b80b 4.0=a00f 5.0=8813) Rated=4.0A -->
      <sdoConfig idx="2003" subIdx="0"><sdoDataRaw data ="64 00"/></sdoConfig>  <!-- Standby current percentage (100%) -->
      <sdoConfig idx="2011" subIdx="0"><sdoDataRaw data ="01 00"/></sdoConfig>  <!-- Closed loop -->
      <sdoConfig idx="2023" subIdx="1"><sdoDataRaw data ="a0 0f"/></sdoConfig>  <!-- Kp=4000 (def=2000) -->
      <syncManager idx="2" dir="out">
        <pdo idx="1600">
          <pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32"/>
          <pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="opmode" halType="s32"/>
          <pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="target-position" halType="s32"/>
          #<pdoEntry idx="60FF" subIdx="00" bitLen="32" halPin="target-velocity" halType="s32"/>
        </pdo>
      </syncManager>
      <syncManager idx="3" dir="in">
        <pdo idx="1a00">
          <pdoEntry idx="6041" subIdx="00" bitLen="16" halPin="cia-statusword" halType="u32"/>
          <pdoEntry idx="6061" subIdx="00" bitLen="8" halPin="opmode-display" halType="s32"/>
          <pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="actual-position" halType="s32"/>
          #<pdoEntry idx="606C" subIdx="00" bitLen="32" halPin="actual-velocity" halType="s32"/>
          #<pdoEntry idx="6077" subIdx="00" bitLen="32" halPin="actual-torque" halType="s32"/>
        </pdo>
      </syncManager>
    </slave>
You don't need to go the detour with sdoconfig to reset to factory default. You can set the SDO directly with
ethercat download 0x1011 1 1
and there is an "ethercat upload" that works in a similar way if you want to check individual SDOs.
If you haven't done so, power cycle the drive afterwards reset to factory default.
  • RoberCNC
  • RoberCNC
09 Aug 2025 08:10
Replied by RoberCNC on topic LiCHUAN A5 AC Servo Fine tunning
I totally agree, Andy. The Y axis is the LiCHUAN. I'm convinced it's due to acceleration and speed. Would you start by modifying the INI file? Wouldn't you look for it via the driver's own parameters?
  • ChironFZ16
  • ChironFZ16's Avatar
09 Aug 2025 08:05 - 09 Aug 2025 08:17
Replied by ChironFZ16 on topic Bitfile for 6i25+7i74+7i85
Yes,forPWMs u.Servos i have 2 x 5i20
  • automata
  • automata
09 Aug 2025 07:32
Replied by automata on topic PathPilot V2 source code
Category: PathPilot
From what I am seeing in the Tormach V2.12 branch, it does not have jerk-limiting.
That is a grotius only special (and tormach is forbidden from using it ;-) (codeberg.org/skynet/linuxcnc_scurve_comp...ter/cmake/LICENCE.md).
-automata
  • automata
  • automata
09 Aug 2025 07:29
Category: PathPilot
I have not gotten the tormach V2.12 version of linuxcnc to compile.
I have one Tormachs earlier versions (V2.10) to compile on Debian Stretch. 1. It has the 9 axis lookahead.
2. It does not however account for sittner's PLL patch which is extremely useful for Ethercat distributed clocks when used with a Preempt-rt Linux kernel.
3.This version also does not differentiate between Joints and axes as Tormach has forked linuxcnc before the joints-axis patches were finalized.
I have v2.9 of Linuxcnc compiled and running on Debian Bookworm.
-automata
  • GeckoWorks
  • GeckoWorks
09 Aug 2025 03:29 - 09 Aug 2025 11:16
Announcing Deckard: StreamDeck support for LinuxCNC
Category: Show Your Stuff
There are now a few cheaper clones/competitors out there, too. Generally called Streamdock (not deck) and it seems they come from another(?) OEM and are often sold under the Mirabox name but they are sometimes rebranded, too.
Prices are all over the place though as in my brief search, I have seen the 15 key version ranging from USD 50-100.
Not sure if the protocols are identical or it would take a lot of re-work to make them work with Lcnc.
But they are quite a lot cheaper so might lower the bar for people interested in getting into these.
Also, on at least one of the models, the buttons seem to be a bit larger than on the real Streamdeck - which might not be a bad thing for machining use.
  • tcbmetalworks
  • tcbmetalworks
09 Aug 2025 03:03 - 09 Aug 2025 03:03
Replied by tcbmetalworks on topic Automatic band saw marvel v10a
Category: CNC Machines
I was able to make a basic gui to turn on and off 2 leds using cursor. Pretty cool tbh. It took 2 days of pain in the ass vibe coding to get it done but now that I'm here everything should be smooth sailing. This is really a new method to make gui that is not talked about much. In my opinion it's much easier then trying to learn a few programming languages. Pretty neat because cursor is pretty strong at using the ai to make python gui. I don't think I would use it for a mill but for basic input outputs it should be strong enough.
  • andypugh
  • andypugh's Avatar
09 Aug 2025 01:20
Replied by andypugh on topic M66 keeps waiting
M66 keeps waiting
Category: G&M Codes
LinuxCNC version on the splash screen is 2.9.0~pre1+git20230208.f1270d6ed7
I really thought we had a newer version than that on Bookworm, but the package lists suggest otherwise.
I don't think that anything has changed with M66 since that version (which was a prerelease that found it's way into the Debian archives during their testing phase, expected to be replaced, and then wasn't.
I don't expect it to make a difference to this particular issue but there are other fixed bugs that I would be happier knowing you are not going to see. The current release version (outside Debian) is 2.9.4.  You can just download the .deb file and install it from our server:
www.linuxcnc.org/dists/
What Linux are you running? (eg, Debian Bookworm (my first guess)) and on what platform? (PC? Pi? Oher?) we can then point you to the exact package file you need.
  • pippin88
  • pippin88
Displaying 13996 - 14010 out of 14144 results.
Time to create page: 0.463 seconds
