  • jhandel
  • jhandel
03 Jul 2025 01:02
PID tuning when you have a tuned Servo in CSP mode?
Category: EtherCAT
I am building out POC with Teknic ClearPath EtherCat servos and so far the Cia402 driver is working great.. I have a question around PID tuning.
I ran around in circles trying to get the right P, I, D, FF, FF1, FF2, etc settings and couldn't get the servo anywhere near its limits before it would fail out with a joint follow error.
I got rid of all the PID settings and now it won't fail on following but it runs a f-error of about 5.8 when I do some long mock moves (the 5.8 on the scope is a nice trapazoid shape with a ramp up, flat top and a ramp down.. )
So folks with servos that have their own internal control-loop, how do you configure your PID or tune so that when you have 3 of these guys going their combined f-errors don't cause you to make wonky parts?
Thanks in advance..  Since this is mostly a theory question I'm not posting configs, but happy to if folks ask.
  • PCW
  • PCW's Avatar
02 Jul 2025 23:58
Replied by PCW on topic Configuración thcad2 con mesa 7i96s
I don't think there is a pin 0 issue as this is a 7I96s and the encoder is on pins
27,28,29
Language may be the issue, I don't know enough about locales and translations
but do all strings in the source get translated? (en_US):
                    if "Arc Voltage" in pinchanged:
                        self.d._arcvpin = pin
                    elif self.d._arcvpin == pin:
                        self.d._arcvpin = None
                    if self.d._arcvpin and self.d.frontend == _PD._QTPLASMAC:
                        self.p.page_set_state('thcad', True)
                    else:
  • kworm
  • kworm
02 Jul 2025 23:34
Replied by kworm on topic Configuración thcad2 con mesa 7i96s
Hi, I had the same issue and there was a problem with pncconf displaying the THCAD page if the pin number was 0.  I made a pull request that has been merged a couple of days ago into 2.10 master.  You could either use an input that doesn't have a pin number of 0 or upgrade to the 2.10 master.
Hope this helps.
  • RogEnk
  • RogEnk
02 Jul 2025 23:24
Homing brain fog? was created by RogEnk
Homing brain fog?
Category: Basic Configuration
Hi all,
Finally got around to LinuxCNC'ing my cheap bench top mini mill, making the jump from Arduino/GRBL (Ughh) to a Mesa7196S.
Problem is my Y axis is making me feel like my IQ has plummeted..
X and Z, perfect (have opto sensors at Z+ and X- (X is mounted to the left of Y saddle as viewed from front - aiming to have bottom left corner as my 0,0).
Unfortunately I appear to lack the logic to get the Y limit configured so that it can be a combined home/limit at +145mm without mirroring the Y axis!
For clarity: I want to home the machine by moving the bed fully to the right for the X axis (working) and fully towards the idiot Operator (tool max +Y), but everything I have tried either inverts the Y or results in soft limit exceeded.
My ini and hal are attached, any help will be very much appreciated!
Cheers,
Rog
  • PCW
  • PCW's Avatar
02 Jul 2025 23:20 - 02 Jul 2025 23:22
7i92M very weird communication problem!!!
Category: Installing LinuxCNC
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 60420ms
rtt min/avg/max/mdev = 0.057/0.276/16.993/0.227 ms, pipe 2
OK that (almost 17 ms) is the issue.
Depending on the Ethernet hardware on the host, solutions are:
If it's a Realtek MAC, install the DKMS driver
Disable PCIE/Ethernet power management
Make sure all power management is disabled in the BIOS
It that's not good enough, pin the Ethernet IRQ to the last processor
and use isolcpus in the kernel command line.
Here's a long  thread on solutions to this issue:
forum.linuxcnc.org/18-computer/56380-error-finishing-read-sigh
  • ANGELOS13
  • ANGELOS13
02 Jul 2025 22:56
Replied by ANGELOS13 on topic 7i92M very weird communication problem!!!
  • PCW
  • PCW's Avatar
02 Jul 2025 22:09 - 02 Jul 2025 22:10
OK, so there is a real time issue that needs to be addressed
before LinuxCNC will run on that system.
To get a rough idea of network latency:
sudo chrt 99 ping -i .001 -q -c 60000 10.10.10.10
This will run for a minute and then print statistics.
  • Benb
  • Benb's Avatar
02 Jul 2025 21:41
  • ANGELOS13
  • ANGELOS13
02 Jul 2025 21:36
Linuxcnc is running, the light on the rj45 stays solid green and the lights on the board stay solid without any activity.
  • PCW
  • PCW's Avatar
02 Jul 2025 21:31
The THCAD support was added to pncconf about 3 years ago so definitely in 2.9.4
The THCAD screen should appear on the next screen after the one where
you set the stepgen/encoder functions.
  • Johnnysacalu
  • Johnnysacalu
02 Jul 2025 21:06
Replied by Johnnysacalu on topic Configuración thcad2 con mesa 7i96s
he vuelto a instalar linuxcnc ultima version estable y nada sigue sin darme la option del thc
porque¿
  • PCW
  • PCW's Avatar
02 Jul 2025 21:05 - 02 Jul 2025 22:16
homing with Phase Z encoder on MESA 7i96s
The search velocity is the speed when searching for the first
home switch actuation, the latch velocity is the velocity used
for for the actual homing switch/index move so only the latching
velocity is needed in this case.
Basically, Index-only homing is specified by setting the search
velocity to 0. (as the homing documentation specifies)
  • unknown
  • unknown
02 Jul 2025 20:40
Replied by unknown on topic Bios error during lcnc start
Seems to be a commonly found issue, HP support forums discuss this quite a bit with various cards.
Might be an idea to google your issue, TLP poisoned, and see if there are any solutions. I wouldn't mention a specific card in your searches to begin with.
My first thought was if the card wasn't on a "whitelist" the PC may refuse to play ball .
  • PCW
  • PCW's Avatar
02 Jul 2025 20:20
MESA 7i76U inputs changing state without changes to config
7I76U inputs are always sinking so normal connection would be:
+24V --> SWITCH --> 7I76U input
If you look in halshow, hm2_5i25.0.7i76.0.0.input-07 will always be
in the opposite state as hm2_5i25.0.7i76.0.0.input-07-not, so choosing
one or the other should make a difference.
  • scsmith1451
  • scsmith1451's Avatar
02 Jul 2025 19:49
Well, that didn't work. Inputs are back to sinking inputs as specified in the manual. I did comment out the PROBE input so it is not currently part of the configuration. However, on startup LCNC continues to show the EStop button activated so I cannot continue testing Homing.
Unable to continue at testing at this point.
These are the states of the inputs at this time:
And this is my HAL config:
File Name: my_TestMill.hal
File Size:12 KB
Any help would be greatly appreciated.
Displaying 14356 - 14370 out of 15148 results.
Time to create page: 0.601 seconds
