  • daveyr
  • daveyr
17 Apr 2025 00:30
Replied by daveyr on topic Rack Tool Changer
Rack Tool Changer
Category: QtPyVCP
Hay Chris. Not sure if you have seen these for rack tool changers. rapidchangeatc.com/product-category/er20-magazines/ For routers they can make it easy to add rack tool changing but need a slightly interesting macro.
I am not sure i can see how to do a PM but if i remember correctly you are in NZ if so let me know if you are interested in playing as could bring one when i come back down under in a couple of weeks if you have an ER collet machine.
17 Apr 2025 00:14
What are the chances of getting this setup working?
Category: Pick and Place
I am sure you have also had to deal with the type of people that look at you and go " Oh you look fine,
say can you ( add requested favor here ) for me"? I have had to deal with that a lot. It don't matter how
tired you are, how much you just gut out life's aches and pains. they are utterly convinced you exist
to make other people's whims a reality.
Yeah that never ended good in my case, as i might have mentioned before, until 2008 i was extremely aggressive, not helped by surviving 2 wars, so i made sure i get no such requests ever again.
Ending rant here, sorry to all.
17 Apr 2025 00:06
Replied by tommylight on topic rotary axis queston
rotary axis queston
If there is no particular and very strong reason for it, i would avoid using the pictured axis designations, it will cause constant headaches with any CAM software you might use.
  • my1987toyota
  • my1987toyota's Avatar
17 Apr 2025 00:04
Replied by my1987toyota on topic What are the chances of getting this setup working?
Sorry went on a bit of a rant there. And no it's no one from  the linuxcnc forum.
  • JohnnyCNC
  • JohnnyCNC's Avatar
16 Apr 2025 23:21
Replied by JohnnyCNC on topic spindle with encoder
Category: Basic Configuration
I'm not really sure exactly what is does, but this is where it is used in my hal file.
It looks like it is set to -10800 because 5400 to -5400 is -10800.
# ---Analog output signals/setup---
setp hm2_7i76e.0.7i83.0.1.analogout5-scalemax [SPINDLE_0]OUTPUT_SCALE
setp hm2_7i76e.0.7i83.0.1.analogout5-minlim [SPINDLE_0]OUTPUT_MIN_LIMIT
setp hm2_7i76e.0.7i83.0.1.analogout5-maxlim [SPINDLE_0]OUTPUT_MAX_LIMIT
net spindle-output => hm2_7i76e.0.7i83.0.1.analogout5
  • acourtjester
  • acourtjester
16 Apr 2025 23:15 - 16 Apr 2025 23:18
Replied by acourtjester on topic rotary axis queston
rotary axis queston
thanks for the reply I did not get a notice you had replied sorry for the delay in my reply.
I will give that a try in the morning. I am using all single motors for the axis. My table config is that the Y is for the across table motion, which is used by some but others use that direction as the X. (: (:  Not having the Y to home will make it so I will not need a home/limit switch for the rotary and I can jut switch the motor signal cable from the controller to the Y or rotary servo.  (:  (:
  • electrosteam
  • electrosteam
16 Apr 2025 22:57
Replied by electrosteam on topic Gmoccapy Touch-Off Offsets
Category: Gmoccapy
I find it odd that a computer cannot populate a memory location with a value entered.
Goes against 65 years of experience.
The Z0.511 error is actually disconcerting.
I tried increasing the precision value from 3 to 4, still strange results.
Note that the errors are either very small, or only arise when setting the Offsets.
Touch-Offs prior to program Run are good.
But, that means I cannot rely on the Offsets.
  • DarkPhoinix
  • DarkPhoinix
16 Apr 2025 22:30 - 16 Apr 2025 22:32
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi everyone, I'm reading this post from the beginning because with the search function I didn't find what I need (I'm on page 66 now)to be able to do a firmware bck and then connect the j-link v8 segger and flash.
I have a nvem v5 with rt1052.
forum.linuxcnc.org/18-computer/55914-nve...xcnc-remora-firmware
  • spumco
  • spumco
16 Apr 2025 22:12
tormach 1500mx modifications, 4th axis, fast I/O expansion, auxilary spindle.
Category: PathPilot
Unless I'm misreading your response, you might want to buy a single drive and test the IO response speed with the actual hardware you intend to use before committing to buying a complete machine.
The other thing to consider is that nobody outside Tormach knows exactly how they're doing stuff behind the scenes with PathPilot.  They've not released the ethercat version of PP to the opensource community (yet?), and what little I've dug in to the non-ethercat version of PP indicates it's really, really different from standard LCNC.  Lots of python-based stuff, not as much HAL/INI.
I'm pointing this out because you're not as likely to get much help from this forum if you're trying to modify a 1500MX, whereas if you stick with a standard LCNC installation and some ethercat drives you'd likely find some assistance here when things inevitably go sideways.
16 Apr 2025 22:02
I am glad.
And i am fully aware of the pain and suffering those types of injuries incur, been over 30 years i messed my spine, still hurts more or less, over 20 years since i messed my knee still hurts daily, elbow, hand, left foot, etc etc.
I learned to live with the pain to the point of not noticing most of the time while working, but any strain reminds me. Luckily, it has not stopped me or even slowed down a bit...well maybe about 10% slow down in general.
  • my1987toyota
16 Apr 2025 20:49
Replied by my1987toyota on topic The dumification of humanity through internet
Then on the other side of the spectrum you have this
  • my1987toyota
16 Apr 2025 20:46
if you're referring to my back it's as good as it is going to get. I have to be careful how much I lift
because If I do to much weight I could inadvertently start loosening the screws. For the most
part though I'm good.
  • Rockwood
  • Rockwood
16 Apr 2025 20:02
Category: PathPilot
Thanks for that great info on the drives, I hadn't identified the model yet.
I'm diving deeper into the user manual/electrical prints. They are pretty well done. tormach.com/support/mill/1500mx-documents
The prints confirm you are right on all counts. They are getting the I/O from the drives. The I/O board is called "Tormach Servo IO Breakout". and its connected to each drive with a cable.
And the axis drives are listed as:
"Inovance SV660N, AC Servo Drive, Ethercat, 220 Vac, 5.5 A, STO Function"
I'm likely going to add a 4th axis anyway. So either 5in 3out more will be enough for me, or I'll just buy a Beckhof module like PCW mentioned.
I'm sure I could repurpose some of those existing 25/15 I/O, I'm not going to have flood coolant, for example. But it would be nice to leave the factory stuff alone as much as I can, just for simplicity.
I also noticed the ATC option, which I was going to get, looks like it gives 2 more In and 1 more out unused. It looks like I've got plenty of I/O options.
Thanks for your response!
  • scotth
  • scotth
16 Apr 2025 18:59 - 16 Apr 2025 19:00
Replied by scotth on topic Linux_Mint_22.1_LinuxCNC_2.10.iso
Category: Installing LinuxCNC
I can go back to a stable Debian system on this computer if needed. I have your original 2.10 on my HP, and it is working. I'm just trying to get the AMD system up with 2.10. It is not a panic situation at all.
Thank you.
  • notJamesLee
  • notJamesLee
16 Apr 2025 18:42 - 16 Apr 2025 18:43
Replied by notJamesLee on topic Determining Angular Scale - Help w/ Microsteps
Category: Configuration Tools
Friends,
from what I can only assume is inconsistencies in diameter or something but 533.33 is the number.
with 533 after 20+ revolutions you can see the starting point creep earlier -- indicating its just short of the number of steps to complete a full circle.
with 534 after 20+ it goes the opposite way.
I have a few follow up questions:
- what should i have the dip switches set to? Now that we've figured out they don't do anything to effect the steps per revolution is there an optimal value for this? I dont need insane amounts of torque or rpms
- is this something i can easily fix with the encoder once i do move to LCNC and tune in the encoder error?
thanks all for sanity checking me thus far, nice to know im not 100% crazy.
Displaying 16501 - 16515 out of 17623 results.
Time to create page: 0.482 seconds
