  • jimwhiting
  • jimwhiting
04 Apr 2025 11:29
Replied by jimwhiting on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
I used the XML file SDOconfig option:
     <!-- Homing Config - 1 - Move to negative limit switch 23 home in place-->
      <sdoConfig idx="6098" subIdx="0">
        <sdoDataRaw data="01 00 00 00"/>
      </sdoConfig>
04 Apr 2025 11:27
Replied by tommylight on topic Work with probe
Work with probe
Category: Basic Configuration
My condolences.
  • jdowsonjr
  • jdowsonjr
04 Apr 2025 11:26
Replied by jdowsonjr on topic Marco Reps video on youtube about EtherCAT
Category: EtherCAT
hey guys im trying to test this but i cant find parameter number 6098 to set the homing method to 6 in motion studio, could you please tell me how you configured this parameter?
  • papagno-source
  • papagno-source
04 Apr 2025 10:34 - 04 Apr 2025 11:13
ETHERCAT WAIT SYNC was created by papagno-source
ETHERCAT WAIT SYNC
Category: EtherCAT
Hi at all.
I use normally Debian 10 with ethercat and not have problem.
Now stay testing devian 12 (iso by git linuxcnc with uspace) and Procedure CORBETT ethercat installation
at point 3 and point 4.
When start configuration the value the drive and I/O are refreshed after 10 second after start.
On Dmesg have :ETHERCAT WARNING 0-0 SLAVE DID NOT SYNC AFTER 5000 MS
:ETHERCAT WARNING 0-1 SLAVE DID NOT SYNC AFTER 5000 MS
:ETHERCAT WARNING 0-2 SLAVE DID NOT SYNC AFTER 5000 MS
:ETHERCAT WARNING 0-3 SLAVE DID NOT SYNC AFTER 5000 MS
:ETHERCAT WARNING 0-4 SLAVE DID NOT SYNC AFTER 5000 MS
:ETHERCAT WARNING 0-5 SLAVE DID NOT SYNC AFTER 5000 MS
AFTER THIS TIME THE REFRESH THE VALUE ARE FAST AND NORMAL OPERATION, BUT NOT UNDERSTAND WHY AT START THE LCNC HAVE THIS WAIT FOR READ DRIVE VALUE.
THE SAME CONFIGURATION WITH DEBIAN 10 AND ETHERCAT 1.5.2 AND LCNC 2.9.0-PRE0 RUN OK
  • Pjamesmk1
  • Pjamesmk1
04 Apr 2025 10:15
Qtplasmac radius to end of arc differs error
Category: CAD CAM
Hi All,
Been using sheetcam and Recently changed my OS to Ubuntu from windows. but linuxcnc isn’t happy with the gcode from the post processor. I copied over all the settings from the windows sheetcam to Linux but I get the below error and can’t fathom how to fix it.
Radius to end of arc differs from radius to start.
Any ideas? Thanks
  • Krimbles13
  • Krimbles13
04 Apr 2025 10:14 - 04 Apr 2025 10:18
Hey,
sorry to bother you with this but i can't get this to work and i'm kinda frustrated.
I can't get out of e-stop and get a bad spi payload = 646174
My hardware:
Raspberry Pi 4B
BTT Octopus Pro v1.1 with stm32f446
TMC2209 Drivers with jumpers in SPI mode
I did the wiring acording to the docs and also the installation.
With cutecom i get the output in the attached file for the octopus xyz.hal.
SPI and UART are activated on the Pi and i already did a rewiring of the whole thing.
I'm tottaly new to LinuxCNC so i would really appreciate your help on this.
Thanks! peter
File Name: debugoutput.txt
File Size:2 KB
  • maxi177
  • maxi177
04 Apr 2025 09:47
Replied by maxi177 on topic dead Outputs on Mesa 7i76E and blown up 7i85S
Category: Driver Boards
I wrote an email on March 24th and haven't heard back, so I just wanted to follow up in case it got caught by your spam filter.
Max
  • kevin_allein
  • kevin_allein
04 Apr 2025 07:56
Replied by kevin_allein on topic Home location on CNC Lathe
I guess that means positive and negative news for me. For the limit / home switch for Z position I use an inductive sensor and that is mounted in a way, that the tailstock would be detected. The bad news is obviously now, that the home position is dependent on the tailstock position and I will need to make sure, that the tailstock is exactly in the same position every time I perform homing.
Does that sound like a reasonable approach or should there be some absolute location to avoid that dependency ?
  • jcdammeyer
  • jcdammeyer's Avatar
04 Apr 2025 07:41
Replied by jcdammeyer on topic Work with probe
Work with probe
It's been a while. Lot's happened in the last almost 2 years. Death of our 35 year old son at the end of 2023 has kind of screwed up my world.
Going through the various postings from back in 2023 I never did see you post a copy of
measure_tool_inch.ngc
If you have the time would you post that please?
  • Z3rni3
  • Z3rni3
04 Apr 2025 07:38 - 04 Apr 2025 07:39
Replied by Z3rni3 on topic Encoder on 7i95t
Encoder on 7i95t
Morning,
I replaced "encoder.00.position" with "stepgen.00.position-fb", which worked fine.
Then I checked the encoder and realized that it was counting in the negative direction when moving in positive coordinates. So, I added a minus sign in front of the stepper count in my .ini.
Now, the axis moves during the first part of the homing process. However, as soon as it hits the home switch for the first time which then tells it to change directions a "following Error" occurs.
  • timo
  • timo
04 Apr 2025 06:19
Replied by timo on topic ENCODER_RATIO function implementation.
Did this machine run the hob with a hydraulic motor for the hob spindle?
  • vre
  • vre
04 Apr 2025 06:08
Help,How to customize language of QtDragon's interface
Category: Qtvcp
I have returned back to 2.9.4 but i will try again master.
In qtdragon_hd i can't find touch plate z axis probing.
This exists in qtdragon but can't find it to hd version.
Is somewhere hidden?
04 Apr 2025 05:08
Replied by tommylight on topic Joint1 following error
You should have mentioned this is a RPI.
When running the gcode file, set the Max Velocity slider to a lower value, till you do not get the joint following error anymore, then divide that value with 60 and set that value as the MAX_VELOCITY in the ini file.
Also noted the scaling, if you have direct drive belts with GT2 20 tooth belts, the scaling should be 40 or 80 depending on drive microstepping.
04 Apr 2025 04:58
Replied by tommylight on topic Spindle control not showing in Axis window...
No spindle there at all.
Make a new config, choose a spinlde, choose some rough values for spindle PWM, save, start the config see if it shows the spindle.
  • ffffrf
  • ffffrf
04 Apr 2025 04:49 - 04 Apr 2025 04:50
Using a servo as a spindle and positional axis - keep getting vague errors
one more question before i forget: what issue could be encountered by having a different model of servo driver? Given that you are driving both the spindle and c-axis both with step/dir signals, you just need a driver that can output step/dir, right?
Displaying 17236 - 17250 out of 17647 results.
Time to create page: 1.060 seconds
