  • cmorley
  • cmorley
07 Mar 2025 03:02
Replied by cmorley on topic Qtvcp Development Discussions
Category: Qtvcp
Yes we are interested in potential screen alternatives. We don't you post some pics.
Master is fine for digging out the hidden bugs assuming the major functions work.
I have a 'best/preferred practice' page for GUIs I should add it to master.
How are you testing now? Are you installing the files in the config folder?
  • Nathan40
  • Nathan40
07 Mar 2025 02:57
Replied by Nathan40 on topic Ethernet Settings for Raspi4
Category: Installing LinuxCNC
Thanks PCW for your help! Cheers.
  • rodw
  • rodw's Avatar
07 Mar 2025 02:56
New ethercat / probe basic control for minimonster
Category: CNC Machines
Awesome!
Start with the cia402 example and only add stuff from the manual you need
github.com/dbraun1981/hal-cia402
Should be easy,
  • Sziggy_NC
  • Sziggy_NC
07 Mar 2025 02:55
Replied by Sziggy_NC on topic Calling pockets with carousel
Category: Basic Configuration
That would explain my issue. I thought it was odd when I read the M-code explanation of M68. I was calling it without ever setting it...  I now see that section in the toolchangers for dummies video.
I will try "net car-pos-req motion.analog-out-00 => conv-float-s32.0.in"
And "net car-pos-s32 conv-float-s32.0.out => carousel.0.pocket-number"
Thank you for saving me Andy!
  • ihavenofish
  • ihavenofish
07 Mar 2025 02:47
Replied by ihavenofish on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I just tuned my omron ethercat servos. I fear manual tuning on these lichuans, haha. How are you doing it, just scoping it in twincat or linuxcnc? or do they have an app?
  • ihavenofish
  • ihavenofish
07 Mar 2025 02:43
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Alright, I lied, I haven't given up yet :P
I went and tuned the X and Y. not perfect, but tracks within a couple microns and overshoots only 4-10 microns during 1G acceleration. Also only deviates 2-3 microns when I yank on the spindle with all my weight while moving.
If i can get the linuxcnc part going this thing is gonna rip :)
  • cmorley
  • cmorley
07 Mar 2025 02:38
Replied by cmorley on topic Custom Panel
Custom Panel
Category: AXIS
To use your modified version, put the .ui file in:
YOUR CONFIGURATION FOLDER/qtvcp/screens/qtaxis/
use the name qtaxis.ui
Qtvcp should load your modified .ui file.
  • Philip Lydin
  • Philip Lydin
07 Mar 2025 01:44
Custom mcodes was created by Philip Lydin
Custom mcodes
Category: O Codes (subroutines) and NGCGUI
Hello im currenttly working on a latthe rettrofit. The tailstock on the machine works by movving the z axis so it is aligned with the tailstock then a pin gets hydraullically pressed into the tailstock so when you now move the z axis it brings along the tailstock so you can move it to the desired position. Does anybody have a idea how i can make this. I tried to use a m100-199. But then i saw you canttt use subroutines. Otherwise ittt would be perfect since you can use its related parameters to set where you want to place the tailstock. Is it possible to use parameters with unallocatted mcode. So you could maybe do like a m20p200?
  • Chia
  • Chia
07 Mar 2025 01:41
Replied by Chia on topic LinuxCNC coreXY homing question
Yes, it is a CoreXY machine.
  • Philip Lydin
  • Philip Lydin
07 Mar 2025 01:40 - 07 Mar 2025 01:41
Replied by Philip Lydin on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
im gonna ttry and use them on my lathe retrofit. To see more info look here and feel free to ask some questions!
forum.linuxcnc.org/38-general-linuxcnc-q...ofitt-feeler-ftc-280
  • FraesPaul
  • FraesPaul
07 Mar 2025 00:59 - 07 Mar 2025 00:59
Installation 2.9.4 Debian Bookworm Preempt-RT ISO // Probleme
Category: Deutsch
Hallo,
vielen Dank für die Antwort.
Hier die beiden Ordner
Hello,
Thank you for your reply.
Here are the two folders
  • PCW
  • PCW's Avatar
06 Mar 2025 23:47 - 06 Mar 2025 23:48
Replied by PCW on topic mesa 7i33 7i37
mesa 7i33 7i37
Category: Driver Boards
No, just reverse to get pulldowns vs pullups.
You can cut pin 10 but it does nothing but waste a few mW.
  • JTknives
  • JTknives's Avatar
06 Mar 2025 22:38
Temporary materials was not loaded in a timely manner
Category: Plasmac
Yes I know. I dug up another SSD for my GIGABYTE mini pc so I’m going to do a completely fresh install without compromising my original HD.
  • rodw
  • rodw's Avatar
06 Mar 2025 22:30
Category: Plasmac
Seems like you are trying to set the feed the twice (in gcode and in the material)
I really think you should update QTplasmac.
  • vre
  • vre
06 Mar 2025 22:18
Replied by vre on topic mesa 7i33 7i37
mesa 7i33 7i37
base pin1 is 5v and base pin10 is gnd
if connect resistor in reverse 5v will connected to port pins through last resistor.
Is it better to cut pin10 of resistor network ?
Displaying 17836 - 17850 out of 18735 results.
Time to create page: 0.372 seconds
