  • Todd Zuercher
  • Todd Zuercher's Avatar
05 Mar 2025 18:04
Replied by Todd Zuercher on topic Custom Panel
Custom Panel
Category: AXIS
The instructions in the manual are what you should follow for building or modifying a configuration.
Stepconfig, is a wizard application for creating basic machine configurations. It asks you questions and you fill in the answers about your machine config, then it builds the configurations files (*.hal, *.ini ...) for you. The end result being a set of machine config files that might work for you, or be a stepping off point giving you a framework to create a more complex configuration from.
PS once you've created a config using one of the wizards, if you make manual hand modifications to the config files, do not try to make changes using the wizards. Because the wizards do not look at the existing config files for info, any previous changes to them will be lost and overwritten. (They work from other files that are not used for running Linuxcnc.)
  • PCW
  • PCW's Avatar
05 Mar 2025 17:40 - 05 Mar 2025 17:42
Replied by PCW on topic Ethernet Settings for Raspi4
Category: Installing LinuxCNC
As others have mentioned, you definitely do not want DHCP and you do
need to set a static address.
You might try this:
       auto eth0
       iface eth0 inet static
           address 10.10.10.100
           netmask 255.255.255.0
DO NOT set a gateway or nameservers
  • LCR
  • LCR
05 Mar 2025 17:31
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
They do seem to work. I've spent about 3 hrs tuning these so far. I'll have a hopefully final go next week. I've got 4 1kw servos (gantry). There are enough details in the manual to do the tuning. The velocity feed forward from Linux Cnc really helps with following error to a ramp, which is what I'm testing. I wish there was a way to restart communication without restarting the drives. It is tedious using the buttons on the drives. If I get a satisfactory procedure I'll write it up.
05 Mar 2025 17:19
Replied by tommylight on topic Ethernet Settings for Raspi4
We can not give you exact settings as you did not reply to our questions, so go back, read and reply.
  • unknown
  • unknown
05 Mar 2025 17:18
Built In Wifi Not Working Raspberry Pi 5 and 2.9.4
I don't know where you saw the info about the setup wizard, but this is absolutely wrong.
As the image is essentially Debian Bookworm you can use the below link to get an idea. Also there is a large sticky thread related to the RPi images, in the Installing Linuxcnc heading.
What other image are you referring to ?
wiki.debian.org/NetworkConfiguration
  • ihavenofish
  • ihavenofish
05 Mar 2025 17:10
Replied by ihavenofish on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I'm still waiting to see these in proper functional use on a machine too.
These are very appealing to spec on my machine, but I want someone else to make sure it works first, hahaha.
  • ihavenofish
  • ihavenofish
05 Mar 2025 16:46
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
Category: CNC Machines
ok, i've finished your instructions. now what? haha.
I've only ever set up linuxcnc with the mesa wizard. what guide should i follow now for the rest?
Thanks!
  • Nathan40
  • Nathan40
05 Mar 2025 16:44
Replied by Nathan40 on topic Ethernet Settings for Raspi4
Thanks for your reply! If possible can you share exact settings so that noobs like us can know and get this 7i95t up and running. Any help will be highly appreciated.
  • noqui
  • noqui
05 Mar 2025 16:40
Custom Panel was created by noqui
Custom Panel
Category: AXIS
Hi. I am a little bit confuse about working with your own Panels.
I modified the AXIS.ui with this panel ROBOT.ui
Se image 1. ROBOTui
Basically, I only added 6 tab windows
Then, as in the documentary PyVCP says it must be included in the INI I did it.
See image 2 PyVCP
But when I run again the Linux Stepconf to include the changes I find a place where I should add custom panels.
See image 3      Stepconf
In conclusion I don´t know where I have to place my custom ROBOT.ui that is an AXIS.ui modified.
Sorry for my English, is not my mother tongue,
By the way I am working in the translation into Spanish of the Developers Manual - 25 January 2025.
Thanks a lot.
05 Mar 2025 16:32 - 19 Mar 2025 23:30
Should I just suck it up and buy a good stepper driver?
Category: Driver Boards
I have seen plenty of dead drives due to those mosfet drivers, some IR.8.1.2.. i can not recall, but i did not bother to check why or how, just left it to using cheap IRF540 or IRF740 output stages that have max 100V VGS and slapping 80V working voltage on the drives, so any coasting or hard brake would release the magic smoke.
I am sure you can figure out what company made those.
Fortunately i still have some in use as with 30-48V they are fine.
  • PCW
  • PCW's Avatar
05 Mar 2025 16:32
7i95t pin and firmware files with Stepgens and Inputs 5Axis BoB
Most will work for step/dir but the spindle PWM output may be on different pins
What is the pinout of a breakout available to you?
  • PCW
  • PCW's Avatar
05 Mar 2025 16:10
Mesa 7i96 mixed voltage field input wiring
Here is the 7I96/7I96S input circuit
Notes:
1. The quad optos are AC input type
2. The solid GND symbol is input common
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • mindstormmaster1
  • mindstormmaster1
05 Mar 2025 15:52
Built In Wifi Not Working Raspberry Pi 5 and 2.9.4 was created by mindstormmaster1
I installed Linuxcnc on an 8GB Pi5 using this file since I want to use a MESA board, it looked like the right choice.
www.linuxcnc.org/iso/rpi-5-debian-bookwo...25-01-27-0140.img.xz
Everything booted up well(but there was no initial setup wizard like I have seen some people mention), and the install looks good, but I don't see wifi anywhere or network options of any kind. I tried a USB wifi dongle, and that didn't change anything and unfortunately, ethernet is not an option for me. Does anyone have any tips for getting wifi working? Should I have used the other .iso? Thanks!
  • jmelson
  • jmelson
05 Mar 2025 15:51
HEXFET, TrenchFET, Epitaxial FET, .... damn i am getting old and this time i am not blaming it on being 3:15AM right now, there are many more types of MOSFET's, and almost all have flyback diodes, you can spend days sifting through catalogs to find any that does not
I have been making servo amps since about 2004, and had some issues with them blowing up under certain conditions.  I used some beefy 56 A International Rectifier HEXFETs.  Using a digital scope, I was horrified to see that the body diodes in these transistors did not start to conduct until about 10 us after they were forward biased by up to 12 V!  So, I had to add in some ultra-fast diodes across the transistors to prevent this.  The issue was that when the high-side transistor was sourcing current and then shut off, motor and filter inductance would pull the source of that upper transistor down to large negative voltages, and cause the gate driver chip to turn both transistors on at the same time, leading to fireworks.  The  extra diodes solved this issue.
Jon
05 Mar 2025 15:41
Any clue why adding fast diodes would cause them to blow up?
IT WILL NOT!
Unless you reverse polarity.
I wonder where are you getting such wrong info from and why are you so stuck at diodes ...
Are you aware that miss wiring the stepper motor will blow the drive?
The "fuses" you mention, are NOT fuses, they are resistors used for current limiting in the drives.
Also mentioned before, do NOT cut the drive power on the DC side, ever, meaning, if you wire the drive and motor and use any power supply that is already powered, then touch/wire the DC power to the drives = they are dead in most cases.
Displaying 17926 - 17940 out of 18737 results.
Time to create page: 2.845 seconds
