10 Feb 2025 18:41
Replied by tommylight on topic Voron Life , for anyone going into 3D printing !
Category: Additive Manufacturing
Not much on youtube @toma.3d but there are pictures on instagram with same user name @toma.3d
As for nozzle/hotend, all have V6 cold end with Volcano hot end, from 0.4 to 1mm nozzles. Nothing fancy but works properly.
  • MarkoPolo
  • MarkoPolo
10 Feb 2025 18:35
Replied by MarkoPolo on topic qtvismach, a axis toolpath
Category: Qtvcp
There is one problem after the last changes.
The tool trace disappears after 30 minutes.
It looks like the tool trace is constantly being saved, even though the machine and simulation are not making any movement. I think it is constantly saving to some buffer which, when filled, deletes the oldest content.
The screen in vismach is refreshed every 100ms, if I decrease this value, the trace will disappear earlier than 30 minutes.
  • PCW
  • PCW's Avatar
10 Feb 2025 17:55
Replied by PCW on topic Hal configuration for BISS encoder
Category: HAL
5I25/7I77/7I74-BISS
File Name: 5i25_7i77_...ss3d.zip
File Size:91 KB
5i25/7i76 with 3 PWMgens replacing the first 3 stepgens with BISS on 7I74
File Name: 5i25_7i76p...ss3d.zip
File Size:88 KB
  • timo
  • timo
10 Feb 2025 17:50
need help! mesa 7i95 connection problem
Category: Driver Boards
Hello,
sudo lspci -nn|grep -i ethernet delivers:
"Ethernet controller [0200]: Intel Corporation Ethernet Controller I225-V [8086:15f3] {rev 03}"
further trials did not result in much other than: again 1:45 am :-)
I tried another mini PC that I bought really cheap. Some difficulties to install from USB stick. I am not sure why it refused to install "uefi files" at first. (yet again I "fixed it" by random clicks on different options). The Ethernet adapter on this cheap Mini (it worked yesterday with the now deleted Windows 11) is a Motorcomm YT6801. This Ethernet adapter was not detected during installation. I tried to get it running using this instruction.
github.com/dante1613/Motorcomm-YT6801/bl...20-%20instruction.md
I have the feeling, that I messed the installation up quite a bit, not knowing what I am doing... :-).
The Motorcomm adaper showed (initial value for rx-usecs: 200), smallest value I could set with the ethtool (trying), was rx-usecs:3. The ping times seem to be influenced by that and went down from approx. below 0.5 ms to below 0.2 ms
Latency test in general I did not do these days.
Thank you for helping, so I am relieved that the 7i95 is still working.
  • Sandro
  • Sandro
10 Feb 2025 17:32 - 10 Feb 2025 17:33
THC with Beckhoff EL5101 and THCAD2 => encoder signal loss
Category: Plasmac
Hello everybody,
Thank you all very much for your inputs and recommendations. I can test most of them next weekend and report back to you.
I've tested the THCAD2 with a divider ratio of 1/128 and 1/64 already, but I can't remember if I also checked with 1/32. Will definitely try again.
I will also check the cabling again and the stability of the 5V power supply.
I think the frequency does not go to absolute zero but to less than 1 Hz (guess). I will also have a closer look at the duration of these drops. The EL5101 seems to provide some values for underflow, overflow and also the possibility to filter the frequency.
Warning: Spoiler!
I was also thinking of some moving average to filter the drops. But I don't know how I could implement this. Writing a custom HAL component?
  • unknown
  • unknown
10 Feb 2025 17:05
Replied by unknown on topic The dumification of humanity through internet
I'll just giggle at the irony of your opening post.
  • NT4Boy
  • NT4Boy
10 Feb 2025 16:59 - 10 Feb 2025 17:00
Replied by NT4Boy on topic HURCO KMB-1 Control Update
Category: Milling Machines
Three axes moving. Not without a fight.
On enabling the servos, without me touching anything, the z axis would advance about 1mm, and trip out with joint follower error. Similar symptom to replacing an encoder and getting the a and b channels swapped. Took me too many hours to find in the heart of Tommy's tuning guide the answer, put a minus in front of the motor scale figure. (Required on all the axes.)
I've entered a default figure 20 for P and deadband.0001mm. Kind of surprised I cannot get it to error even at max jog speed.
Keep jacking up the P value, until it oscillates I guess, a job for another day.
  • Todd Zuercher
  • Todd Zuercher's Avatar
10 Feb 2025 16:46
Replied by Todd Zuercher on topic EtherCAT Testing?
EtherCAT Testing?
Category: EtherCAT
The real time kernels run, they just don't "work" as in the latency for real time tasks is about the same as running a non real time kernel.
  • IB_CnC
  • IB_CnC
10 Feb 2025 16:43 - 10 Feb 2025 16:52
ProbeBasic and sidemount, retractable 3D Probe
Category: QtPyVCP
Ahh yes, apologies I did misinterpret.
Yes that would be possibly I think, I did not see this possibility when I was drawing out concepts.
It would require a fairly large (stationary) support structure outside of gantry support, and access to table would be limited a bit, but other than that it should work.
I did already buy all parts for the carousel and got all the aluminum plates ready to route the holes, but its a good alternative option without loosing work area!
  • MaHa
  • MaHa
10 Feb 2025 16:34
Replied by MaHa on topic Z probing with G38.4
Looking at this table in the manual, G38.4 seems not possible without probing move towards piece.
10 Feb 2025 16:15
Replied by tommylight on topic The dumification of humanity through internet
Anyone against deleting this topic?
I failed to raise hell... :)
P.S.
I still maintain that calling silicium "silicon" is not smart, by any stretch of imagination. Sue me !
  • Hakan
  • Hakan
10 Feb 2025 16:05
Replied by Hakan on topic EtherCAT Testing?
EtherCAT Testing?
Category: EtherCAT
I tend to think that EtherCAT doesn't add any timing constraints.
Worthwhile to do a test. But you can't run a realtime linux kernel in a virtual machine, can you?
  • Hakan
  • Hakan
10 Feb 2025 16:01
Replied by Hakan on topic Ethercat + step/dir signals
Category: EtherCAT
Hakan's EaserCat 3000?
Experimental. Perhaps too experimental. I just bought EtherCAT stepper driver Rtelligent ECT60 and used my own IO card.
  • Reddiamonduk
  • Reddiamonduk
10 Feb 2025 15:59 - 10 Feb 2025 23:15
Replied by Reddiamonduk on topic Error starting gmoccapy with spindle speed display.
Category: pyVCP
It seems like you may be on to something, there is no pyvcp in that list. I have also added other photos in case there is something that may help.
Pins
custompanel.xml
hal files in 'ini' file
pyvcp_options.hal file
  • CADdy
  • CADdy's Avatar
10 Feb 2025 15:34
Replied by CADdy on topic Ethercat + step/dir signals
Category: EtherCAT
Displaying 19246 - 19260 out of 19432 results.
Time to create page: 0.486 seconds
