  • Lcvette
  • Lcvette's Avatar
06 Jan 2025 13:43
[SOLVED] ProbeBasic NameError: name 'tool' is not defined
Category: QtPyVCP
happy to help!  sorry for the hiccup!
Chris
  • Lcvette
  • Lcvette's Avatar
06 Jan 2025 13:32 - 06 Jan 2025 13:41
Replied by Lcvette on topic Installation links failing
Category: QtPyVCP
yup, moved here, we are working on fixing the builder that updates the links!
  • Lcvette
  • Lcvette's Avatar
06 Jan 2025 13:30
Working Lathe config with Mesa 7196s + Encoder (no probing yet)
Category: QtPyVCP
nice! it is a wonderful thing to get true rpm working and have threading available! congrats!! post some picture too! show off your project!
Chris
  • Lcvette
  • Lcvette's Avatar
06 Jan 2025 13:23
  • sajurcaju
  • sajurcaju
06 Jan 2025 13:06
Replied by sajurcaju on topic Adding a linefeed to a gcode line
Category: AXIS
Nice idea, but it still says "bad character"
  • JT
  • JT's Avatar
06 Jan 2025 12:53
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Flex GUI
Oh and is there any way to use a progress bar for something like spindle speed feedback? I don't see progressbar in the docs
I'll have to add a HAL QProgressBar... then you can connect it in your postgui.hal file.
JT
  • JT
  • JT's Avatar
06 Jan 2025 12:52
Flexible GUI
Category: Flex GUI
Can stuff like "view_dro_cb" be a pushbutton that is set to checkable rather than a checkbox?
You can now and no need to set it checkable in the designer the code does that for you.
JT
  • JT
  • JT's Avatar
06 Jan 2025 12:16
Flexible GUI
Category: Flex GUI
Is there any mechanism to use a qstackedwidget and some pushbuttons instead of the tab widget? I suppose you generally need to stuff some python in there to use the former.
So yes you can use a QStackedWidget now.
JT
  • vre
  • vre
06 Jan 2025 12:01
Replied by vre on topic Additional Inputs
Additional Inputs
Category: Driver Boards
How can i switch parallel to input mode?
  • blazini36
  • blazini36
06 Jan 2025 11:54
Replied by blazini36 on topic Flexible GUI
Flexible GUI
Category: Flex GUI
  • blazini36
  • blazini36
06 Jan 2025 11:46
Flexible GUI
Category: Flex GUI
I have used a QStackedWidget before but not in this project and yes you need to code the buttons to change pages. I'm assuming you have a small monitor and the tabs from a QTabWidget take up too much space?
JT
Nah, it's a 16" touchscreen and a good portion of the controls will be in the hardware. I'm just not a huge fan of tab widgets, when the handles are large enough to be useable on a touchscreen they waste space, plus all of the handles are in 1 spot, vs pushbuttons that can be anywhere. I'm just getting rolling so they'll work for now.
  • rairsa
  • rairsa
06 Jan 2025 11:36
  • phillc54
  • phillc54's Avatar
06 Jan 2025 11:16
Replied by phillc54 on topic Adding a linefeed to a gcode line
Category: AXIS
Does the pipe character create a new line?
G64 P0.001 | G4 P3
  • JT
  • JT's Avatar
06 Jan 2025 10:49
Flexible GUI
Category: Flex GUI
JT
  • Aciera
  • Aciera's Avatar
06 Jan 2025 09:26
Replied by Aciera on topic Adding a linefeed to a gcode line
Category: AXIS
One solution would be to put those lines in a subroutine and insert the subroutine call into F-engrave.
Displaying 20626 - 20640 out of 21676 results.
Time to create page: 0.335 seconds
