  • Lcvette
  • Lcvette's Avatar
13 Aug 2024 15:02
Py3 - Probe Basic Config Conversion Doc Lcnc 2.9+
Category: QtPyVCP
user tabs are in the sim config folder, you simply turn them on or off in the ini file, there is one for the main tab group and the side bar, so it pretty much covers you for being able to add any functionality you may need.
now it doesn't work if you are changing the main ui and need to add things in, but if you have a good idea for a change or addition you can alway voice that here or on the qtpyvcp chat.  we incorporate many ideas to make Probe Basic better often.  that is where many of the latest update changes came from, made to fix some shortcomings and add some feature functionality!.
Below is an image of the user tabs. those should also be available in the stable version.  you would simply edit those two files in qtdesigner and they are loaded on start up. this was they travel with your config and are never overwritten on updates.  you can nest tabs to make them infinitely deep to accomodate the most intesnse project additions.
Chris
  • cakeslob
  • cakeslob
13 Aug 2024 14:27
Replied by cakeslob on topic Remora for RP2040
Remora for RP2040
We would probably need to do some math to verify that it can provide the step speeds you need for all axis. I saw you mentioned something about an encoder, but rp2040 cannot do encoders if thats also what you need.
  • cakeslob
  • cakeslob
13 Aug 2024 14:21 - 13 Aug 2024 14:24
yes, you are right. I need to find the other excel sheet that raf made that had everything on it.
The problem is that it is the wrong board, using those pins in the config will cause problems for other users who use them. If all you need is a reference to which remora pin goes where, you can use the config file you loaded to the board. The part you need may be correct, but the pin assignment is not for the same board. If you use the STM32 pin names on your rt1052 board it will cause issues.
github.com/scottalford75/Remora-RT1052-c...xCNC/nvem-rt1052.txt
Ill even do you one better, here is a trimmed down list of the inputs/outputs that you can use that wont cause problems for other users.
Warning: Spoiler!
  • RLA
  • RLA
13 Aug 2024 14:14
Replied by RLA on topic Computer crashing
Computer crashing
Category: Installing LinuxCNC
I tried log path in terminal and got  "no such file or directory'??
  • mehdidadash
  • mehdidadash's Avatar
13 Aug 2024 13:59
Ethercat installation from repositories - how to step by step
Category: EtherCAT
if you mean this, "sudo udevadm control --reload-rules" , i have done it
also this one
sudo geany /etc/udev/rules.d/99-ethercat.rules
KERNEL=="EtherCAT[0-9]", MODE="0777"
  • Aciera
  • Aciera's Avatar
13 Aug 2024 13:34
Replied by Aciera on topic Ein Neuling sucht Hilfe
Category: Deutsch
Am besten du hängst mal deine .hal and .ini Dateien an.
  • Aciera
  • Aciera's Avatar
13 Aug 2024 13:32
Replied by Aciera on topic Y axis configuration
Not sure if you are aware of this but these are the only relevant lines in the posted file.
###   unbind a key first (if needed), then rebind  to your new thing, for example
root_window.unbind('<Left>')
root_window.unbind('<Right>')
root_window.unbind('<Down>')
root_window.unbind('<Up>')
# then rebind it to your new command
# bind right and left keys to joint 0, usually x
bind_axis("Right", "Left", 0)
# bind down and up keys to joint 1, usually y
bind_axis("Up", "Down", 1)
Everything else are comments as examples.
So basically you need to 'unbind' the keys you want to reassign and then assign the function.
  • rodw
  • rodw's Avatar
13 Aug 2024 13:28
Replied by rodw on topic Ein Neuling sucht Hilfe
Category: Deutsch
Best practice for installing an external estop is to use the estop-latch component.
Fortunately, there u=is an example on the forum
forum.linuxcnc.org/47-hal-examples/25861-external-e-stop
People will offer other ideas but this is the safest way and it will introduce you to hal :)
This video might help
  • Ismacr63
  • Ismacr63
13 Aug 2024 13:01
Replied by Ismacr63 on topic Y axis configuration
Yes, I did that. The file with the modification that the colleague made works perfectly.
I am referring to an example of how the file is modified to reassign a key, so that I can reassign the keys that I need.
  • hans48
  • hans48
13 Aug 2024 12:58
Ein Neuling sucht Hilfe was created by hans48
Category: Deutsch
Hallo Linuxcnc Gemeinde
Bin Neu Hier und suche Hilfe um meine LinuxCNC in Betrieb zu nehmen.
Zur Vorstellung: Mein Name ist Hans 76 Jahre (jetzt wird sich so mancher Fragen was will dieser Alter noch).
Ich habe schon 3 CNC Maschinen gebaut aber mit Mach3 ausgerüstet. Jetzt steht die 4. in der Werkstatt die will ich mit Linuxcnc ausrüsten.
Mach 3 hat relativ gut funktioniert aber manmal auch mit Tücken so habe ich festgestellt das wenn das Prgramm zu groß ist auf einmal die X-Achse abhaut und bis zum Endschalter gefahren ist (habe ein 2,5 D Werkstück aus Holz gefräst).
So jetzt will ich mal es mit Linuxcnc Probieren. Linux CNC runtergeladen und Installiert. Latencytest zu hoch. Nächsten Computer genommen (I5) auch nicht besser. Nach langerhin und her hat sich ein User bereit erklärt mir einen Computer zu besorgen und ihn Aufzusetzen und nach meinen bedürfnissen zu Programmieren (Muste die Mesa Karte ihm schicken). Somit alles gut, aber jetzt habe ich das Problem das so manche ein und ausgänge nicht zuordnen kann. Motoren (4) sind OK. Endschalter auch. E-Stop kann ich weder Eingang noch Ausgang finden es gibt zwar einen Butten im Bildschirm E-Stop aber ich will einen Not-Stop Schalter Installieren.
Gibt es in meiner Nähe irgend jemand (Hartberg) der mich unerstüzen kann? Oder es erbarmt sich jemand und hilft mir.
Wie schon geschrieben bin ein Neuling und muß von Vorne anfangen. Habe mich schon Videos angeschaut die sind schon älteres Datum und passen nicht zu meinen Programm. Habe auch schon in der HAL nachgeschaut aber das ist für mich Bahnhof.
So das war es mal für das erste.
Gruß Hans
  • Mecanix
  • Mecanix
13 Aug 2024 12:51
It's Official. Left to PCB fab an hour ago and so I should receive this badboy in 5~7days. Looking forward enjoying LinuxCNC-RIO over traced hardware (farewell jumper wires and cheap modules, at last). My very first "True Isolated" motion control board!!
  • Aciera
  • Aciera's Avatar
13 Aug 2024 12:39
Can you tell me with an example how to do a key remapping?
See bottom of first answer and the attached file there.
  • Ismacr63
  • Ismacr63
13 Aug 2024 12:35
Yeah can be confusing those MIN/MAX, pos/neg, sensors, logic levels, it's endless. Took me a while to set-up my mill correctly back when I've introduced Lcnc to it.
Shout out if you're stuck. Pleasure btw, be safe and have fun.
13 Aug 2024 12:29
Replied by tommylight on topic 7i77 watch dog catch 22
Category: Driver Boards
Moderator could you please move this message to driver bords section.
Done.
Thank you.
  • rodw
  • rodw's Avatar
13 Aug 2024 11:36
Category: EtherCAT
Seems like the udev rules part of the instructions need redoing
Displaying 22876 - 22890 out of 25397 results.
Time to create page: 0.430 seconds
