  • tivoi
  • tivoi's Avatar
08 Sep 2024 04:22
Replied by tivoi on topic Fanuc 2S AC spindle motor on Delta C2000+
Category: Milling Machines
trying VF control with lower voltage base , ex 150v
fanuc spindle use SIN COS encoder, it is not incr ABZ encoder
  • spumco
  • spumco
08 Sep 2024 03:54
Replied by spumco on topic USB ports quit working?
Category: Installing LinuxCNC
Ok, nevermind.  Was able to get the files off using a live-usb.  Going to reinstall Debian and start with a clean slate.
  • spumco
  • spumco
08 Sep 2024 03:19 - 08 Sep 2024 16:58
Replied by spumco on topic Fanuc 2S AC spindle motor on Delta C2000+
That Fanuc is an induction motor, not a PM.  They will run off a bog-standard VFD; the problem with Fanuc spindle motors is that they generally use a serial or proprietary encoder output that doesn't play well with 'standard' encoder inputs on drives.
First - disconnect your encoder from the VFD, and set the VFD to no-feedback.
The VFD 'wizard' should have an option to enter the basic nameplate data (FL amps, poles, ect.).  Try using that in V/F mode.
I've got a Mitsubishi SJ (similar to your Fanuc) I'm running off a GS3 VFD.
EDIT - Tommy's right.  Your voltage is wrong.  That's a 200v-class motor, can't use it with a 380v VFD unless the VFD can be programmed to drop the voltage to a different class.
EDIT 2 - DOH!
See later post
  • spumco
  • spumco
08 Sep 2024 02:17
If it helps, this is what's displayed when starting in recovery mode.
  • spumco
  • spumco
08 Sep 2024 02:11
USB ports quit working? was created by spumco
(I know this problem isn't really about LCNC, but this forum is full of clever people who know way more about linux and computers than I do.)
Final testing of my ATC (rev2) and getting an error when I try to run M6 Tn via g-code.  M6 Tn works fine via MDI.
Error message was something about remap, pointed to emccannon.CHANGE_TOOL() not matching c++?  Cryptic, backstage code stuff I didn't understand.
Poked around a bit and discovered stdglue.py has been updated since I last updated LCNC, so tried running apt update/upgrade.  Failed due to some broken dependency.
Restart computer and now none of my USB ports work once the desktop has started.  Keyboard works at first boot - can select a kernel or recovery mode - but once the desktop starts I've got no way to do anything.  No mouse, no keyboard.  Unplugging/replugging doesn't fix.
Any ideas?  Even if I have to re-install everything I still need to get my latest config off the drive... it's got all the INI and HAL tweaks I've done in the past week for the ATC.
[Debian 12, 6.6.15-rt-amd, Xfce]
  • cmorley
  • cmorley
08 Sep 2024 00:24
Replied by cmorley on topic Weird Multi Axis MDI Issue in QTDragon_HD
Category: Qtvcp
Can you check on the offsets tab if there is any rotational offset?
  • rodw
  • rodw's Avatar
08 Sep 2024 00:00
Ethercat installation from repositories - how to step by step
Category: EtherCAT
The issue is the source method installs its files in a different folder that the deb install does
  • rodw
  • rodw's Avatar
07 Sep 2024 23:34
Replied by rodw on topic New update on STMBL
New update on STMBL
Category: Driver Boards
I feel that making this as an EtherCAT slave might open something of a licensing can of worms. But it already has Ethernet port for command input, and I would expect the STM32 to have the CPU horesepower to handle the protocol.
I don't think this will be a problem because the ethercat license is paid for in the price of the lan9252 chip.
If you were to manufacture these for commercial sale, you would need to be a company and register for free membership of the ETG to be compliant.
Its only linuxcnc who has a lcensing issue because we do not have any legal business structure.
07 Sep 2024 23:02
Replied by tommylight on topic Fanuc 2S AC spindle motor on Delta C2000+
Moved to "milling machines" so ... is this a mill?
07 Sep 2024 23:00
After a quick run through i could not find any mention of induction or permanent magnet type.... Fanuc, that is really not nice.
Disconnect the motor from VFD, connect any two motor wires together and turn the shaft by hand, can you feel detent's and does it require more force to turn than when wires are not connected together?
If there are detents, it is a permanent magnet motor so it does not work with VFD, use a servo drive.
If it turns out to be an induction type, you can try settings on the VFD, there are several types of "drive modes" there, like Vector, triangle, sinusoidal, etc. These are just what i recall, been several years since i last set up a VFD.
Also, limit the current on the drive, you are using a 200V motor with a 380V VFD.
  • rodw
  • rodw's Avatar
07 Sep 2024 22:26
Replied by rodw on topic Where is qtplasmac_comp.hal loaded
Category: Plasmac
Got it. I ran up a new config with pncconf and indeed the ini file was missing
HALFILE = qtplasmac_comp.hal
in the ini file. It must have been deleted along the way.
  • vre
  • vre
07 Sep 2024 22:10
Replied by vre on topic New update on STMBL
New update on STMBL
More useful than ethercat is 600vdc because opens the door
to more powerful from 2kw range servos like spindle servos and big cnc servos.
Except other igbt module to handle 600vdc better isolation better connectors
what other needs?
The modifications will be in power stage.. driving stage needs modification?
To all stmbl owners are you happy from stmbl ? Works like commercial servos?
  • rodw
  • rodw's Avatar
07 Sep 2024 21:59
Category: Plasmac
Just finalising an implementation of qtplasmac on a retrofit and we don't seem to have the breakaway and float switch connected
I know these should be connected to plasmac.float-switch and plasmac.breakaway
These seem to be connected in qtplasmac_comp.hal but I can't see this hal file is being loaded anywhere in our config so maybe we broke something. If that is the case, there are a lot of other signals unconnected.
Can someody set me straight here?
  • routerman22
  • routerman22
07 Sep 2024 21:54
Fanuc 2S AC spindle motor on Delta C2000+ was created by routerman22
Hi All,
I have finally reached the point in my Kitamura CNC retrofit that i can get the spindle turning.
I got a Delta 3.7KW C2000+ (3PH 380v) VFD + PG-01H encoder card. But I'm having some interesting issues....
So My Spindle motor is an old FANUC 2S 2.2 / 3.7KW 200V 4P 1500/8000rpm spindle motor:
Datasheet link:  s3.amazonaws.com/Icarus/DOCUMENTS/Fanuc_Manuals_1791.pdf So what I tried is to first figure out if this is an AC induction motor or an PM motor. From what I can find (or not find in this case) anything in the datasheet so that made me think it is an AC motor as i feel no "dents" when i turn the motor by hand.
So I connected it all including the OEM Fanuc encoder signals the the VFD.
And then I went through the setup wizard, (immediately went for the complicated method) of including the encoder feedback etc.
When i tried to do a test run it just immediately jumps in OL3 error. I tried some of the advisement in the datasheet such as changing accel time or carrier frequency but that did not help.
So i went back to the basics and just put it in V/F mode. Max output voltage 200V , poles: 4 , max freq 267Hz , base freq 50hz (1500rpm) .
Now when i pressed run it turned, but it did not sound good. The current was around 17A's when it runs with no load on like 500rpm. I tried to set it to higher RPM but the high load pretty much states around. After a bit the VFD throws and overload as it is pulling too much current.
And now... I'm quite lost, any idea what I'm doing wrong? I have worked quite a bit with vfd's and never had such troubles so I'm thinking there is something fundamentally wrong. (this servo spindle worked well with the FANUC drive it had before).
  • PCW
  • PCW's Avatar
07 Sep 2024 21:44
Replied by PCW on topic 7i95 sserial port as gpio
Category: HAL
No, 7i95t_5abobd.bin should work.
Displaying 23551 - 23565 out of 23569 results.
Time to create page: 0.379 seconds
