  • endian
  • endian's Avatar
13 Jul 2024 11:42
Ethercat installation from repositories - how to step by step
Category: EtherCAT
yes they are here...
user@debian:~$ sudo apt-get install linux-headers-$(uname -r) Reading package lists... Done Building dependency tree... Done Reading state information... Done linux-headers-6.1.0-12-rt-amd64 is already the newest version (6.1.52-1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
  • rodw
  • rodw's Avatar
13 Jul 2024 10:46
Category: EtherCAT
have you installed linux-headers? for your RT kernel?
  • andypugh
  • andypugh's Avatar
13 Jul 2024 10:44
Replied by andypugh on topic 2-speed spindle configuration - help
gearchange.comp just picks a gear and sticks with it until the spindle is turned off again.
gearchoice.comp is more meant for lathes with CSS and will attempt to do a gear shift with the spindle still moving, but only during a G0 move. (and then the LinuxCNC system will wait for spindle-at-speed)
It's rather like a skilled driver with a crash gearbox, you can match the shaft speeds and make a seamless shift with everything still in motion.
Here it is in action:
The upshift problem is something that we see with the 1916 fire engine that I drive when going up hills, the engine (motor) speed falls more slowly than the vehicle (spindle) speed and the shaft speeds fail to converge until both have stopped.
In the case of my lathe, I need to fit a braking resistor and increase the spindle deceleration rate, but to do that means pulling the lathe way from the wall to remove the back cover.
13 Jul 2024 10:26
  • Grotius
  • Grotius's Avatar
13 Jul 2024 09:28
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
@Tiagounderground,
Is this available for test? I have a high speed glass cutting machine that would greatly improve his performance with this features
Yes, you can test or run the application in posix realtime or non-realtime.
However it is still not finished in the sence of look ahead features and more.
You can test it carefully on your machine on your own risk off course.
It has no homing features, but you can look at the hal file how to setup the axis for a xxyz machine.
Best to build the app is using the ./recompile script.
But first build& install this opencascade and clothoids
Here is the script to actually run a parport machine, this is tested ok.
  • bkt
  • bkt's Avatar
13 Jul 2024 08:50
Delta Asda2 ethercat servo and mechanical axis gross vibrations problem ...
Category: Pick and Place
these is my mechanical execution on vertical axis .... Delta A2 have smooth vibration parameter .....it works, and with my surprize, using ethercat, a little bit hight min ferror I can use "S" curve regulations without issue for Lcnc. These is ok!! Min ferror must be 20 in my case ... and set it 40 ...... so can use "S" curve parameter in asda soft and servo.
I try to leave it out and set Lcnc min ferror correctly to 20 ..... but impossible leave out the problem.
I have a problem ... my T10 belt is long ... so a little bit elasticity they have .... so when from slow velocity command a quite hight acceleration and velocity sometime servo goes on vibration state ... means it vibrate but run (motor sounds become from "zzzzzzzzzz" to "rrrrrrrrrrr" ).... seems it try continuosly to correct the position ..... I play with I and P parameter whitout success ... or little succes (in Lcnc and asda soft too), plus I play with smooth vibration parameter in asda soft ... actually result servo goes in these stranges state 95% less of time .... but not able to leave out these problem .... how can leave out?
Min ferror is 40 and Ferror is 120 .... so 3 time .... these can not be the problem I think ..... If increase P motor have strange sound ... if decrease too mutch not respect the position or accelerate too smooth .... co I and P param seems correctly set. Plus these parameters is equal as asdasoft find with asda app for motor parameter calibration ....
So any ideas on?
thanks a lot
  • GeckoWorks
  • GeckoWorks
13 Jul 2024 08:46
Replied by GeckoWorks on topic Touch Monitor Size - Any Consensus?
Some unsolicited advice...
If you plan to make an enclosure for the screen, make sure to either:
  • Buy an extra screen in case the first one breaks and has been obsoleted by the mfgr, or
  • Build a separate bezel that's fairly wide and mount the monitor to that.  The bezel then gets mounted to the enclosure.
    • If you have to replace the monitor with something else, you only have to make a new bezel to fit the new screen dimensions.
No worries, I am all for unsolicited, good advice and yours make good sense. Thanks:)
To begin with, I'll keep it simple screen on a Vesa arm and keyboard under it, I think. But I wouldn't be surprised if I want to enclose it later on.
  • GeckoWorks
  • GeckoWorks
13 Jul 2024 08:45
Do begin with, I'll keep it simple screen on a Vesa arm and keyboard under it, I think. But I wouldn't be surprised if I want to enclose it later on.
  • Dmclements
  • Dmclements
13 Jul 2024 08:44
Fresh Rpi4 Install w/7i96s Invalid Bitfile Header
Category: Installing LinuxCNC
Had this stuff for couple years but everytime I try and get something setup I run into problems and then just put it back in a box and back on a shelf.
But now I have an actual need to get this going to replace a 10yr old CandCNC packaged system.
Tried flashing the 7i96s_dpl firmware.
Returns the error: Invalid bitfile header!
The couple other posts I found mentioned updating mesaflash. My current mesaflash version is 3.4.9, and I’m not savy enough with reading github to know if thats up to date or not.
Not to mention network manager seems to be missing on the pi image, or at least there is no straightforward way of launching the gui for it from any menu I’ve looked in. So currently no internet connection on the pi, will work on that tomorrow.
  • endian
  • endian's Avatar
13 Jul 2024 08:43
Replied by endian on topic 2-speed spindle configuration - help
hello,
I do not know, but I did my custom component and overwrite the gearchange.comp as my choise because of my lathe setup... I need a little bit more stuff to control
I think a default gearchange.comp from andy will be helpfull for you, because it solve all the stuff but no CSS .. I need them for my setup therefore I did customization...
  • bkt
  • bkt's Avatar
13 Jul 2024 08:33
Replied by bkt on topic LinuxCNC on Linux Mint Debian Edition 6
sorry for late ... need to read from these point ... forum.linuxcnc.org/9-installing-linuxcnc...n-edition-6?start=20 ..... not remember where but at some point I have the same issue ... but if read post from that point fo sure you find my solutions .... seems need to install some dependancy .... find it using debian package command
  • Vector
  • Vector's Avatar
13 Jul 2024 08:29
Replied by Vector on topic Manual tool change + tool lengh touch off
For anyone it might help: QtDragon has documentation for setting up a toolsetter and an M6 remap that will use that toolsetter to automate the measuring of the new tool length after a tool change.
The stock code as of this comment isn't usable since it doesn't return the machine to the same location as before the tool-change was called.
There's a pull request that hopes to address that: PR 2706 .
There's also a post of that code at my stand-alone repository .
And there's a video of how it can be setup and used over on youtube .
It's also attached here, substitute it in your QtDragon configuration wherever you find qt_auto_probe_tool.ngc.
All the best.
  • endian
  • endian's Avatar
13 Jul 2024 08:08
How to monitor OP mode in Panasonic A6B Ethercat
Category: EtherCAT
I do not know where are you from Tommy...
In Kosovo, Eastern Europe (well middle Europe is more correct, but there is no such thing, yet! :) )
Just for kicks, ask your post office how much would it cost to send such a thing here, but be warned: having a glass of water on hand is highly advisable, and so are sedatives! :)
If you ever wondered what a black hole is, now you know, i live in it!
On the brighter side, since this year we are able to travel again visa free in EU, after over 25 years!
I am from Slovakia that should not be problem to send a parcel.. but problem should be the encoder type and motor parameters.. please take a picture of motor nameplate .. if it will support a feedback type and continuos current..
  • endian
  • endian's Avatar
13 Jul 2024 08:03
Category: EtherCAT
hello
have anybody idea what is going on here?
user@debian:~$ sudo apt install ethercat-master libethercat-dev  linuxcnc-ethercat
The following additional packages will be installed:
  ethercat-dkms
The following NEW packages will be installed:
  ethercat-dkms ethercat-master libethercat-dev linuxcnc-ethercat
0 upgraded, 4 newly installed, 0 to remove and 3 not upgraded.
Need to get 0 B/2,422 kB of archives.
After this operation, 73.3 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Selecting previously unselected package ethercat-dkms.
(Reading database ... 185171 files and directories currently installed.)
Preparing to unpack .../ethercat-dkms_1.6.0.gcafd367-1+1.2_all.deb ...
Unpacking ethercat-dkms (1.6.0.gcafd367-1+1.2) ...
Selecting previously unselected package ethercat-master.
Preparing to unpack .../ethercat-master_1.6.0.gcafd367-1+1.2_amd64.deb ...
Unpacking ethercat-master (1.6.0.gcafd367-1+1.2) ...
Selecting previously unselected package libethercat-dev.
Preparing to unpack .../libethercat-dev_1.6.0.gcafd367-1+1.2_amd64.deb ...
Unpacking libethercat-dev (1.6.0.gcafd367-1+1.2) ...
Selecting previously unselected package linuxcnc-ethercat.
Preparing to unpack .../linuxcnc-ethercat_1.39.0.g4299f7a-0_amd64.deb ...
Unpacking linuxcnc-ethercat (1.39.0.g4299f7a-0) ...
Setting up libethercat-dev (1.6.0.gcafd367-1+1.2) ...
Setting up ethercat-dkms (1.6.0.gcafd367-1+1.2) ...
Loading new ethercat-dkms-1.6.0 DKMS files...
Building for 6.1.0-12-rt-amd64 6.1.0-17-rt-amd64
Building initial module for 6.1.0-12-rt-amd64
Error! Bad return status for module build on kernel: 6.1.0-12-rt-amd64 (x86_64)
Consult /var/lib/dkms/ethercat-dkms/1.6.0/build/make.log for more information.
dpkg: error processing package ethercat-dkms (--configure):
 installed ethercat-dkms package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of ethercat-master:
 ethercat-master depends on ethercat-dkms; however:
  Package ethercat-dkms is not configured yet.
dpkg: error processing package ethercat-master (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linuxcnc-ethercat:
 linuxcnc-ethercat depends on etherlabmaster | ethercat-master; however:
  Package etherlabmaster is not installed.
  Package ethercat-master is not configured yet.
dpkg: error processing package linuxcnc-ethercat (--configure):
Errors were encountered while processing:
 ethercat-dkms
 ethercat-master
 linuxcnc-ethercat
E: Sub-process /usr/bin/dpkg returned an error code (1)
I did some core frequency setup to hard value and ethercatMaster stopped working...
  • woai312742
  • woai312742
13 Jul 2024 06:29
Replied by woai312742 on topic WebGUI
WebGUI
Category: Other User Interfaces
bro, that's a good idea.
Displaying 25006 - 25020 out of 25541 results.
Time to create page: 0.454 seconds
