Trajectory Planner using Ruckig Lib
12 Jul 2024 17:40 #305017 by Grotius
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Thanks for the likes.
I made a test for tangential knife and for 3d plasma cut correction for 5 axis.
Here we demonstrate how to use the c axis to rotate a knife along the gcode path.
In the same flow it's possible to do side cut correction for a plasma application. Here we could use a gcode macro to
tell if it's an inside or outside contour, The realtime trajectory planner can then do the correction to inwards or outwards.
So on the list is reading gcode macro's to tell the trajectory planner different stuff.
The following user(s) said Thank You: tommylight, Lcvette, Ritterchen, Aciera, tiagounderground, hmnijp
12 Jul 2024 18:40 #305021 by Aciera
Replied by Aciera on topic Trajectory Planner using Ruckig Lib
Potentially very useful, indeed.
  • tiagounderground
  • Junior Member
  • Junior Member
12 Jul 2024 20:28 #305029 by tiagounderground
Replied by tiagounderground on topic Trajectory Planner using Ruckig Lib
Amazing work.
Is this available for test? I have a high speed glass cutting machine that would greatly improve his performance with this features
13 Jul 2024 09:28 #305062 by Grotius
@Tiagounderground,
Yes, you can test or run the application in posix realtime or non-realtime.
However it is still not finished in the sence of look ahead features and more.
You can test it carefully on your machine on your own risk off course.
It has no homing features, but you can look at the hal file how to setup the axis for a xxyz machine.
Best to build the app is using the ./recompile script.
But first build& install this opencascade and clothoids
Here is the script to actually run a parport machine, this is tested ok.
The following user(s) said Thank You: tiagounderground
13 Jul 2024 11:49 #305067 by Grotius
To make things easyer, I made a  appimage for hal-core. This appimage is a cnc simulator. Its valid for x64.
  • Moderator
  • Moderator
13 Jul 2024 12:19 #305069 by tommylight
Replied by tommylight on topic Trajectory Planner using Ruckig Lib
cnc@HP-Z420:~/Downloads$ ./runtest_cnc-x86_64.AppImage
Segmentation fault (core dumped)
13 Jul 2024 12:33 #305070 by hmnijp
Replied by hmnijp on topic Trajectory Planner using Ruckig Lib
We already have a standard g-code G41/42 defining the compensation side. can't we use it?
13 Jul 2024 12:58 #305073 by Grotius
Hi Tommy,
I just made some changes to the appimage. At my pc it runs from the download dir now, wich was a problem.
Please try it again and report.
Hi Hmnijp,
Perfect point. We use that. I will code it that way.
I also have to bring in offset's soon. To zero the machine at certain point.
And i hope to start coding the fillets on the trajectory itself coming day's. Using the clothoids, then if clothoid's fails, fall
back to spline fillets.
So everything goes as planned.
The following user(s) said Thank You: pommen, hmnijp
13 Jul 2024 13:03 - 13 Jul 2024 13:06 #305074 by Grotius
@Tommy,
I was thinking about the core dump. This is kernel related.
This is my output after downloading the file. Some times i have to start the app twice before i can actually jog.
This is also the case when using not a appimage.
Warning: Spoiler!
If you still keep core dump, i can edit the appimage to run Using POSIX non realtime
Last edit: 13 Jul 2024 13:06 by Grotius.
13 Jul 2024 13:32 #305080 by Aciera
Just tried the updated AppImage and I also get a CoreDump on my non-RT LinuxMint machine. I then tried it on a machine with a preemt_rt kernel and when I try to start the AppImage the terminal just hangs there, no output at all.
Time to create page: 0.209 seconds
