25 Jan 2026 22:23
motor-0-position error beim Abbremsen aus 4-7,5 m/min
Category: Deutsch
Did you try lowering the acceleration?
The default of 750mm/s/s is to much for some machines.
  • grandixximo
  • grandixximo's Avatar
25 Jan 2026 21:33 - 25 Jan 2026 22:36
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
github.com/grandixximo/linuxcnc/tree/9d
This is phase 0 completed, according to my plan, this is extremely experimental work in progress, there are known issues at the moment, no arcs no blends, no scurve, as illustrated by the plan you can find at this post, which I got not much feedback..
forum.linuxcnc.org/38-general-linuxcnc-q...ons?start=640#341856
Next phase it is IMO too hard to be vibe coded, but I will try in my spare time.
  • rodw
  • rodw's Avatar
25 Jan 2026 19:46
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
The issue with the original code was it was developed with a machine that homes to index so it does not work cleanly with home to sensor. The real problem  is that during device homing, Linuxcnc throws following errors because it has not commanded movement. What generally needs to happen is the position feedback is synced with commanded position so Linuxcnc is happy. This is why most working solutions also provide their own cia402.comp
Yes, I think homing can be standardized for cia402 devices and the new home comp is there now to support that. So much of homing.c becomes irrelavent with device homing so the homecomp allows control of what is needed. I've had a couple of goes at it. The first was obsoleted by a rewrite of the homecomp paradigm.
The cia402 state machine is actually very simple. very linear with the exception of error and safety steps to prior states. The flowchart here is a good resource
www.kebamerica.com/blog/comprehensive-gu...a-402-drive-profile/
Anyway, back on task. It occurred to me that I had included some standard PDO's that are not reported by Ethercat pdos. I will revisit that.
  • Mr1576
  • Mr1576
25 Jan 2026 19:11
Replied by Mr1576 on topic HAL Edits for RS485 / VFD Spindle Control
Category: HAL
Thanks for your reply @andypugh
I copied and pasted your suggestion into my HAL file, replacing the original erroneous text.
Unfortunately when launching Linuxcnc, an error is shown up as attached in the .png file.
Revised HAL file also attached.
Regards
Phil
File Name: XYYZA2PPTREV1.txt
File Size:5 KB
  • grandixximo
25 Jan 2026 18:51
I mostly run G64 P0.05 in metric, G64 P0.002 in inches, G61 is afterthought for us, but will be tested...
  • Lcvette
  • Lcvette's Avatar
25 Jan 2026 18:07
Replied by Lcvette on topic Probe Basic Stable error
Category: QtPyVCP
the on screen button and physical button cannot remain synchronized as the screen cannot physically change the mushroom buttons state. so you will need to add in some hal NOT allowing the UI estop button in probe basic to be in a state different from the physical mushroom button.
  • andypugh
  • andypugh's Avatar
25 Jan 2026 17:08
  • andypugh
  • andypugh's Avatar
25 Jan 2026 17:03
[solved] XHC-WHB04B-06 rotary knob button feed rate not work
You could quickly check if those have the desired affect by opening halshow, opening the "watch" tab and picking those pins from the tree. Then you can set values directly.
If that works then link them up in HAL.
  • andypugh
  • andypugh's Avatar
25 Jan 2026 16:59
Replied by andypugh on topic The Current Bread & Butter Setup?
One advantage of the Pi is that it is perfectly reasonable to have an identical spare to swap in in case of trouble.
  • andypugh
  • andypugh's Avatar
25 Jan 2026 16:57
Replied by andypugh on topic How to fix "Queue is not empty after probing"
This feels like possibly a race condition, I wonder what happens if the queue-empty check is just disabled?
(ie, I wonder if it indicates a real problem?)
  • andrax
  • andrax's Avatar
25 Jan 2026 16:52
I use gmoccapy.
So far, I have found that these two signals control the feed rate:
gmocacapy.spc-feed.value
gmocacapy.spc-speed.value
  • andypugh
  • andypugh's Avatar
  • andypugh
  • andypugh's Avatar
25 Jan 2026 16:48
Replied by andypugh on topic HAL Edits for RS485 / VFD Spindle Control
Category: HAL
If this is your whole HAL file then the problem is that you have connected the HAL "net" to the VFD but not to the motion contoller.
# Connect HAL pins to motion controller
net spindle-vel-cmd-rpm-abs  	hy_vfd.speed-command
net spindle-cw       			hy_vfd.spindle-forward
net spindle-enable        		hy_vfd.spindle-on
net spindle-ccw        			hy_vfd.spindle-reverse
net spindle-at-speed   			hy_vfd.spindle-at-speed
This creates "nets" with names like "spindle" enable but there is nothing at the other "end"
Try:
net spindle-vel-cmd-rpm-abs  	spindle.0.speed-out => hy_vfd.speed-command
net spindle-cw       			spindle.0.forward => hy_vfd.spindle-forward
net spindle-enable        		spindle.0.on => hy_vfd.spindle-on
net spindle-at-speed   			spindle.0.at-speed <= hy_vfd.spindle-at-speed
The => are optional and ignored by the computer.
linuxcnc.org/docs/stable/html/man/man9/m....html#SPINDLE%20PINS
  • JT
  • JT's Avatar
25 Jan 2026 16:37
Replied by JT on topic Reload gcode
Reload gcode
Category: Flex GUI
Sorry, I must have got distracted when changing the variable name and didn't finish changing every occurrence. The bug has been squashed.
JT
  • andypugh
  • andypugh's Avatar
25 Jan 2026 16:36
Replied by andypugh on topic PiBot Pendant
PiBot Pendant
I have sent a query about how it interfaces. If it is USB HID then it will probably work fine with hal_input. Otherwise it might need a specific driver.
Displaying 7276 - 7290 out of 13540 results.
Time to create page: 0.530 seconds
