Another plasma component...
- thefabricator03
- Visitor
I am having difficulty with the Ohmic sensor, When I cut out a large slot or hole the water that is sprayed up after the end of cut when the center falls away is causing the ohmic probe to trip on the next probe event,
I do not see much way around this, as this only occurs on certain parts ,is there a way we could place a Ohmic Enable or Disable box in the plasma config page? That way we could turn it off when we know we will be doing parts that will spray water up and rely on the probe limit switch to detect the surface height.
- phillc54
- Thank you received: 2100
It would be interesting to hear if others are having that issue as well.
How about one of:
1: Increase the post flow time so that the air may blow the water away.
2: Pulse the torch on at probe start to get some airflow to blow the water away.
- thefabricator03
- Visitor
Ohmic enable/disable could certainly be done.
How about one of:
I would like to try the second option as I feel the first will increase cycle times,
Also just having the option in the option in the software to manually disable the Ohmic probe and revert to the probe limit switch would be a very handy feature, I know its not a good idea to just keep adding features after features but I see a real common sense usage for that particular feature.
- phillc54
If we added option 2 then we would also probably need to be able to enable/disable that as well.
- thefabricator03
- Visitor
I have had the torch airflow running after the cut but when I go to probe I get the ohmic probe detected while moving to probe height error.
And yeah the when the torch is about to fire it stops the air flow from the last cut so I would assume that it would have to wait until the airflow stops.
- phillc54
OK, we will forget that idea, the diode "should" protect it but it is probably better to be safe than sorry.Just thinking about it and maybe pulsing the torch would not be a good idea if there is a bridge between the nozzle and the shield. Is it likely that having the ohmic circuit live during a torch pulse will cause damage to the ohmic circuit.
Hmm, airflow "shouldn't" have any effect on probe detection, I don't know why that would be...I have had the torch airflow running after the cut but when I go to probe I get the ohmic probe detected while moving to probe height error.
OK, my inexperience showing again.And yeah the when the torch is about to fire it stops the air flow from the last cut so I would assume that it would have to wait until the airflow stops.
I'll put together an enable/disable and hopefully get it out tomorrow sometime.
- Thank you received: 4151
Thanks for your help guys,
As what Rod posted I had both sets of Velocity and Acceleration set to the same number, I did not read the ini closely enough and did not realize I needed to double the first set of numbers.
It cutting much faster, I just need to set up the THC off before the end of cut in sheetcam because the torch is diving at the end of cut and tripping the probe limit switch.
Great I helped. I got half way through that post and wondered if I was wasting my time. I think we need a chapter about external offsets in the plasma primer (sorry Phill!)
It great to have so much feedback and a responsive developer. This stuff is going to set the standard for plasma for years to come.
- phillc54
My preference it to leave it follow the sensor or would that confuse users.
rodw wrote:
Great I helped. I got half way through that post and wondered if I was wasting my time. I think we need a chapter about external offsets in the plasma primer (sorry Phill!)No worries Rod, you write it and I'll push it...
I just about have written it in my earlier post
- phillc54
Ohmic Probe enable/disable in Config tab
If Probe Height is higher than Safe Height then don't move up to Probe Height, probe directly from Safe Height.
