Another plasma component...
16 Jul 2019 02:00 #139531 by docwelch
Replied by docwelch on topic Another plasma component...
It is a standard format. I do not think there is any way to make custom additions.
They also have a JSON output. I don't know what would be easier for you to work with so I have attached a file in that format to this post. I think I added one tool since I sent you the other file.
I like your idea of pulling in the data that is in the file and prompting for the rest of the fields.
I've made some good progress on the post-processor. It seems to be working (as best I can tell without an actual machine to try it on). I've compared the output to some files posted by Rod and all seems well. I want to clean up just a few things and I'll start a thread and post it for others to try. I know you have some sample ngc files in the repository. Do you have any of the drawings you used to create those files or did you just hand code them completely from scratch?
Steven
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
16 Jul 2019 02:05 #139532 by phillc54
Attached is the very original wrench, actually I didn't know that I still had it...
All the others are just hand coded.
16 Jul 2019 02:21 #139533 by docwelch
Thanks, I'll download it and see how my output compares to what is in the repository.
Steven
  • phillc54
  • Platinum Member
  • Platinum Member
16 Jul 2019 08:59 #139547 by phillc54
Steven,
Attached is the preliminary converter file if you would like to give it a try.
I have used the tab limited version.
I have assumed that the original units are either metric or imperial so no conversion should be necessary, it seems SheetCam store all units as metric equivalents.
It will ask for the unknown parameters for each 'tool' as it loops through the file. The last entered parameters will be used as the default for the current tool.
The following user(s) said Thank You: docwelch
  • thefabricator03
  • thefabricator03's Avatar
  • Visitor
  • Visitor
17 Jul 2019 00:59 #139658 by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
Phill,
Have you pushed any updates lately,
I did a git pull and could not see a disable box for the ohmic, are we still going to put that in?
Dont get me wrong I am not complaining just wondering if that feature request will make it in.
  • thefabricator03
  • Visitor
  • Visitor
17 Jul 2019 01:02 - 17 Jul 2019 01:02 #139659 by thefabricator03
Also the disable G-code feature is working well,
I have gotten my Sheetcam cut rules sorted and now am using the turn off g-code feature on my holes and towards the end of the cut, That has fully eliminated the torch diving when it is performing a overcut.
Last edit: 17 Jul 2019 01:02 by thefabricator03.
  • phillc54
  • Platinum Member
  • Platinum Member
17 Jul 2019 01:06 - 17 Jul 2019 01:09 #139660 by phillc54
Phill,
Ohmic Enable should be a check box on the Config tab.
Edit: maybe that would actually be better on the Run tab???
Last edit: 17 Jul 2019 01:09 by phillc54.
  • thefabricator03
  • Visitor
  • Visitor
17 Jul 2019 02:52 #139665 by thefabricator03
Run tab would be good.
  • phillc54
  • Platinum Member
  • Platinum Member
17 Jul 2019 02:53 #139666 by phillc54
Did you find it in your config?
  • thefabricator03
  • Visitor
  • Visitor
17 Jul 2019 03:00 #139667 by thefabricator03
No I did not, I must of done something wrong with the git pull,
I am halfway though a sheet, ill try again this afternoon.
Time to create page: 0.242 seconds
