PlasmaC Just using pierce for circle centre
- Thank you received: 4155
09 Sep 2020 02:14 #181382
Replied by rodw on topic PlasmaC Just using pierce for circle centre
Yes, I did it this way pre plasmac. , I carried that forward into Plasmac with a modified post processor. Its here on the forum somewhere. Once we devised the spotting function of Plasmac, I adopted the Plasmac post processor and use the current POST now. I do remember having to rename my tool to agree with Phill's paradigm.
Remember, post processors are there to be modified to suit you. They are just a text file.
- Clive S
- Thank you received: 486
09 Sep 2020 02:29 #181386
by Clive S
Rod this is getting frustrating. You have just skirted the question "Are you actually using hole centres or arc in."
If you are doing it using are hole centres with various diameters can you please post the actual code.
Replied by Clive S on topic PlasmaC Just using pierce for circle centre
09 Sep 2020 02:37 #181388
I said I used it on a drill operation. Sheetcam then marks the hole centre for you. Its up to your post processor how you mark it. By creating a new tool, you can use it to do what you want without overwriting current behaviour and there is already an example in the post processor file using spotting to guide you..
- Clive S
09 Sep 2020 02:40 - 09 Sep 2020 02:40 #181389
by Clive S
I give up
Last edit: 09 Sep 2020 02:40 by Clive S.
09 Sep 2020 03:22 #181396
If your are not getting the right answers, you are asking the wrong questions
A drill operation in sheetcam has no lead in. It just puts a spot in the centre of the hole. Well, thats how I've always used it
I give up
- phillc54
- Thank you received: 2100
09 Sep 2020 05:33 - 09 Sep 2020 06:39 #181409
by phillc54
Replied by phillc54 on topic PlasmaC Just using pierce for circle centre
Clive, give this postprocessor a try. I think it will do what you want.
In the Operations section you need to set a variable DrillPierce = 1 and then do a drill operation.
Last edit: 09 Sep 2020 06:39 by phillc54.
09 Sep 2020 06:33 #181415
WTF???
Is this an instruction for for Clive?
WTF???
else
post.Text ('we do u fukkn pierce here\n')
end)Is this an instruction for for Clive?
- phillc54
09 Sep 2020 06:36 #181416
by phillc54
oops, do ya like my debug messages?
09 Sep 2020 06:39 #181417
Just gotta keep an eye on the Lead Developer
Ya never know what he gets up to it seems!
I shudder to think what will happen when the test pilot finds this!
- phillc54
09 Sep 2020 06:40 #181420
by phillc54
All fixed, bloody grape juice again...
Time to create page: 0.928 seconds
