PlasmaC Just using pierce for circle centre
04 May 2020 01:47 - 10 Sep 2020 05:47 #166573 by Clive S
PlasmaC Just using pierce for circle centre.
I want to just pierce through the centre of some holes for later drilling to the correct size without a lead in or out.
What would be the correct procedure for this. Also would there be a problem with arc being lost.
I would be using sheetcam loaded with the dxf pattern of the holes
Last edit: 10 Sep 2020 05:47 by Clive S.
04 May 2020 03:10 #166591 by rodw
I use sheetcam for this and have a tool called centerpunch. I move the holes to another layer and run the centerpunch operation on that layer only.
I thn Phill's post also has a spotting tool that is used the same way.
04 May 2020 03:18 #166594 by phillc54
Replied by phillc54 on topic PlasmaC Just using pierce for circle centre
Yes, for the PP here you just need a tool named Centre Spot or Center Spot (no favouritism here)
You can change a couple of parameters if you use the spotting tool
linuxcnc.org/docs/2.8/html/plasma/plasma...guide.html#_spotting
04 May 2020 04:20 #166596 by Clive S
Replied by Clive S on topic PlasmaC Just using pierce for circle centre
Rod can you share your centre-punch sheet cam tool.
Do you have any problems with arc lost when piercing right though then moving to the next hole. I would like to cut through
04 May 2020 04:24 #166597 by phillc54
If you want to pierce right through then you could use the pierce only mode
04 May 2020 04:34 #166598 by Clive S
I have seen this pierce only but thought it might not pierce in the circle centre
04 May 2020 04:36 - 04 May 2020 04:38 #166599 by phillc54
No, it will be where the original pierce is.
Edit: From memory if you use the PP from the forum the centre punch tool only requires the correct name, PlasmaC handles all the other parameters, they can be anything.
Last edit: 04 May 2020 04:38 by phillc54.
04 May 2020 04:46 #166600 by rodw
Clive, I've adopted Phill's postprocessor but I have not done any spotting with it yet. I'm trying to avoid the work and I can cut 10mm holes for nutserts and M6 clearance holes OK. My post is here on the forum somewhere but I think you are better off using Phill's In fact I asked Les Newell to grab it from the forum here so it could be included in Sheetcam earlier in the week.
So you just need to create a tool as per the name Phill mentioned and do a drilling operation using it. Just make sure the hole diameters in the process picks up your holes.
Mine predated Phill's spotting method so mine was a bit cruder. I just turned the torch on and turned it off when I got an ArcOK.
04 May 2020 04:46 #166601 by rodw
Sheetcam looks after that!
04 May 2020 04:53 #166602 by Clive S
So if I made the circles 1mm or 0.5mm it should pierce near enough centre.
I think I am using the PP from the forum. I use the tools that I set up in PlasmaC with the cut params that I have found to work with testing. But not sure where the centre punch tool is (requires the correct name !!)
Sorry to be APITA :(
Time to create page: 0.553 seconds
