PlasmaC Just using pierce for circle centre
- phillc54
- Thank you received: 2100
10 May 2020 06:53 #167256
by phillc54
Replied by phillc54 on topic PlasmaC Just using pierce for circle centre
Clive,
It's been a while since I did this so maybe my memory is telling me the wrong thing. If you can't get it going, post the SheetCam job file and I will take a look tomorrow.
- Clive S
- Thank you received: 486
10 May 2020 07:06 #167258
by Clive S
Phill I am in no hurry I do this as a hobby thanks.
I have added txt to the end.
Replied by Clive S on topic PlasmaC Just using pierce for circle centre
Clive,
- phillc54
10 May 2020 23:53 #167326
by phillc54
- Clive S
11 May 2020 03:07 #167344
by Clive S
Big Thanks Phill. I thought I was going madder than I am. At least I found another bug which you have chased out of the system.
On another note I think I am on 2.9 and have been reading on the forum about mem. leaks should I be going back to 2.8 or just leave it alone.
Sorry Clive, this was all my fault, I cocked up a calculation. Note that now if you use a drilling operation you don't need a 'Centre Spot' tool, you can use any existing tool.
New PP is here
Notes are here
- phillc54
11 May 2020 03:10 #167346
by phillc54
No worries Clive, I am good at breaking things...
TBH there is no good reason these days to be using master for PlasmaC.
Personally I use 2.8 and all the development work is done on 2.8.
- Clive S
11 May 2020 03:47 #167349
by Clive S
Phill Can you please check the above as the PP is showing revision D in the body of the PP on the link
New PP is here
Notes are here
- phillc54
11 May 2020 04:06 - 11 May 2020 04:07 #167351
by phillc54
I was in too much of a hurry. It is the correct file but I forgot to update the revision. I have posted the amended version.Phill Can you please check the above as the PP is showing revision D in the body of the PP on the link
Last edit: 11 May 2020 04:07 by phillc54.
- Clive S
11 May 2020 07:28 #167361
by Clive S
Phill
Not sure what I am doing wrong but I still can not get it to centre spot without the drill
When you get the time would you mind looking at it ?
- phillc54
11 May 2020 07:33 #167364
by phillc54
If it works with the drill then use that.
- Thank you received: 7506
11 May 2020 07:51 #167367
Replied by tommylight on topic PlasmaC Just using pierce for circle centre
Just a quick tip for Plasmac in general, the delete button on the lower right side is in a bad position when removing warnings, just switching places with "new" should be less of a concern.
Time to create page: 1.658 seconds
