Yes, yes it was as i had just changed the Z axis limits but was still using old heights.phillc54 wrote: Tom is it possible that the material buckled up enough so the the top of the material was above the Probe Height. Remember that Probe Height is measured from the MIN_LIMIT rather than the material.
Thanks for the contribution, it looks good and has been merged.DenkBrettl wrote:
Franklin wrote: One more note for pierce/cut mode. When in the Gcode is present the spotting function and turn on the "Pierce only" mode the plasmac makes piercing instead of spotting.
It would be great to ignore spotting when "Pierce only" mode.
I had exactly the same problem today. So I fixed it
My fork can be found here: github.com/DenkBrettl/linuxcnc - I've opened a pull request as well.
Klaus
