Some thoughts and some findings using PlasmaC
5 years 11 months ago #188181 by tommylight
Well Snowwy, you are much better at this than i am, thank you for confirming that.
I do agree that this should be an offset thingy, and i do no mind homing the Z axis again if and when that happens as tripping limit switches should not happen during normal work. The other thing when the Z goes past the soft limit happens due to arc lost at the end of the cuts (lots of them due to cutting thin material with big size nozzle) so it pauses and usually resumes fine, but sometimes it will not resume as it somehow got over the limit, stopping the program execution by pressing ESC and resuming from line works fine.
As for your guess, i did that only once so far and stopped and resumed after raising the torch, i have both machines set to have the Z axis home 20mm under the limit switch, they both have 200mm of travel on Z and one is cutting at the very bottom of the travel while the other is cutting roughly at 120mm under the limit switch, so there is plenty of space.
To rehome Z axis in case the Z axis trips the limit, switch to joint mode, click on "ignore limits", move the Z axis down with the on screen buttons till past limit, press home on the keyboard, this will home just the Z axis and switch to world mode on it's own.
ASUS ROG Crosshair VIII Impact - AMD X570
5 years 11 months ago #188194 by rodw
Geez, it looks like you really have to work hard to break Plasmac these days! EXTREME!!!!
5 years 11 months ago #188253 by tommylight
Did some tests today regarding void sensing and the results are pretty messy,
===setup===
Cebora 120A plasma source set at 50A (does 60 measured), 1.4mm nozzle
Feed rate at 3600 and 1800mm/m (can cut at 4.4m/m with the same current/nozzle)
- cut 10 columns of 200mm length spaced at 30mm
- cut 15 rows of 350mm long cuts
- changing the void sense override on the config panel from 1 to 500 does change the results, but after going on and off several times at the beginning of the cuts ( even when not over a void sometimes ) it just stays on after passing the first to third column/void, remains on a bit after the torch is off.
I did save the hascope data and a screenshot, but they are on the machine PC outside so i will upload them tomorrow.
5 years 11 months ago #188257 by tommylight
On another note, PlasmaC does not have ARCOK off grace period, setting the debounce to 500 did not improve much the issue of getting arc lost at the end of small cuts requiring user intervention to continue.
"mine" had a settable period in the ini file at the very bottom, had it set to 0.2 so it never gave such issues.
Again this is cutting thin material with big nozzles, so not for everyone.
I will try to add a timedelay tomorrow, see if that helps.
Is there a debounce at the end of the signal ? :)
5 years 11 months ago - 5 years 11 months ago #188258 by snowgoer540
tommylight wrote: On another note, PlasmaC does not have ARCOK off grace period, setting the debounce to 500 did not improve much the issue of getting arc lost at the end of small cuts requiring user intervention to continue.
When cutting holes in thin material, I have used G-Code to ignore the arc-ok signal .1" (or so) from the end of the cut with VERY good results. That lets it arc out whenever it wants to, and does not stop the machine. I simply turn it back on before the next cut starts. Rather than use large debounce numbers, I would recommend coding the enabling and disabling of "ignore arc ok" to just ignore it near the end of your cut. No intervention will be required :)
Have a look here
Of course, use synchronized with motion as immediate will "break blending" (it will slow down and stop your cut for a very small increment).
Let me know how it works!
Last edit: 5 years 11 months ago by snowgoer540.
5 years 11 months ago #188259 by tommylight
While i am on a roll, the reverse run is magnificent for the issues i am having as i can always go back and forth and fix any mishaps, BUT, the biggest feature is being able to continue a cut even when the arc was lost on a bend or radius ! :)
With toma_thc config i had to use run from here from a straight line in gcode or from the beginning of the cut when there was no straight lines, so that meant having the torch start and go over an already cut piece forcing me to speed up the cut in that section or raise the cut voltage to prevent the torch from diving into material and dragging rendering the nozzle unusable if i made a mistake during the above procedure.
Now i can do a run from here at the beginning of the failed part and press pause during probing, use the fwd button to get to the uncut part and press resume !
Or to be on the safe side, disable the torch, run from here, pause, check if the torch is where it should be and use fwd/rev to get it there, enable the torch and resume !
Very convenient ! :)
The following user(s) said Thank You: pinder
Time to create page: 0.536 seconds
