Why is Plasmac and QTplasmac pausing at the end of a cut for no reason?
- phillc54
- Thank you received: 2100
I use a wireless one without issues.Ok, had to use a wired keyboard to access the grub menu. Never been a problem before
I don't know, I have two PC'c using WiFi but I don't have isolcpus.around 20000 latency
If only I still had a wifi card that worked.... would isolcpus break that?
Not sure how to debug that. Its always just worked before.
- Thank you received: 4149
So how to make the RT the default boot and I'll be good!
I think It would have been quicker to compile the kernel! thanks for your help!
- phillc54
I also need to get the grub menu defaulting to preempt_rt. I was able to install grub_customiser that tommy used in his Mint install but the tool he used to do the grub menu. But it was a manual install as the progrm he used does not exisr.
I did get QTplasmac opening from my earlier config and Gmocappy is operational. I still have a fair bit to do to get an operational qtplasmac config.
- phillc54
- snowgoer540
- Thank you received: 907
If we could get Tommy to come over from the dark side, maybe he could write a nice step by step to replace the Mint one
- phillc54
- snowgoer540
I would suspect that your notes are better than mine...I think I have some to, I was going to tidy them up and post them but ...
Honestly, I don't remember what mine even look like other than a few screen shots and I know I jotted down some stuff about the grub selector, setting things up for atom/git, etc. I'd have to have a looksee.
- phillc54
I am sure the RT kernels in all Debian based distros have similar name formats.
