Why is Plasmac and QTplasmac pausing at the end of a cut for no reason?
- Thank you received: 4149
22 Jul 2021 00:43 #215540
Replied by rodw on topic Why is Plasmac and QTplasmac pausing at the end of a cut for no reason?
Well I fixed that and RIP is compiling but I managed to break halcompile in the DEB install.
grr
What folder do the component .so files live in with a deb install?
grr
- phillc54
- Thank you received: 2100
23 Jul 2021 08:00 #215652
by phillc54
Xfce desktop.
Replied by phillc54 on topic Why is Plasmac and QTplasmac pausing at the end of a cut for no reason?
FWIW my plasma table has 2Gb and all my virtual machines for testing have 2Gb as well. All running MX-Linux withMX is snappier and more responsive in use than Mint, especialy on PC's with 4GB of RAM.
For use with QtPlasmaC, 4GB is the bare minimum and even that will cause response delays when jogging the machine on Mint with Mate, pretty sure that will be non issue on MX with the same RAM.
Xfce desktop.
23 Jul 2021 10:38 #215662
Phill, thanks for that info. I found QTplasmac was pretty lethargic but I suspect that may have been because of errors in my broken config.
I did have a quick look at memory usage using top and memory seemed adequate. I am Running a J1900 CPU, same as I have ever used but its still sluggish...
- phillc54
23 Jul 2021 10:52 #215666
by phillc54
The table is a Pentium Dual-Core E5500 @ 2.80GHz with 2Gb RAM
I have a Gigabyte Brix Celeron Dual-Core 3205U @ 1.50GHz with 4Gb RAM that I play aound with as well, it is slower loading than the Pentium but it preforms around the same.
Time to create page: 1.329 seconds
