Why is Plasmac and QTplasmac pausing at the end of a cut for no reason?
20 Jul 2021 10:31 #215397 by snowgoer540
Similarly, everything worked out of the box for me as well.  Wifi driver, and the no-name wireless number pad "keyboard" I use as a "jog pendant".  Which reminds me, that needs a new battery...
20 Jul 2021 14:38 #215418 by snowgoer540
Attached are my notes.  It was fairly straight forward.
20 Jul 2021 15:01 #215420 by snowgoer540
I should note I usually do a RIP install, and I think the dependencies list was missing a few as I believe it assumed that you also had a package version installed first.
20 Jul 2021 18:50 #215431 by tommylight
Why are you discussing MX Linux here ???
It would be more usefull making a new topic about it.
I will try to add the howto to my "to do in this lifetime" list! :)
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
20 Jul 2021 18:54 #215433 by rodw
Thanks, Greg. Some very useful links there.
Like you, I usually do a RIP install but this time, I wanted to use the buildbot.
Your screen dump shows the words PREEMPT_RT and this format has changed and it is not searchable.
You need to know to search for linux-image
In Tommy's instructions forum.linuxcnc.org/9-installing-linuxcnc...installation?start=0
he uses
apt-add-repository
This  command uses Python 2.7 and its been deprecated and I could not get it to install so I had to set the repositories up in Synaptic. This is not documented on the buildbot anymore. I thought it used to be. Its been a long time since I used synaptic!
And due to changes in the linux security model, it refuses to allow us to use the use of our key server from the buildbot so this does not work
sudo apt-key adv --keyserver keys.openpgp.org --recv-key EF1B07FEE0EE663E
Fortunately, Phill came to the rescue earlier in this thread and this works
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-key EF1B07FEE0EE663E
So all in all, its not that straight forward
Finally, I was really surprised to see that the QT installation scripts spent ages installing Python 2.7 modules. I thought that was being removed from Master branch so does that mean that script needs to be reworked?
  • rodw
  • Platinum Member
  • Platinum Member
20 Jul 2021 18:58 #215434 by rodw
Well, it was here where it was first mentioned. I did not expect it was going to be so hard. I thought all I needed was the package to install in synaptic!
I think we will move it to a new thread once its nutted out.
  • rodw
  • Platinum Member
  • Platinum Member
20 Jul 2021 19:03 #215435 by rodw
oops now I see the buildbot still discusses synaptic.
20 Jul 2021 23:36 #215446 by phillc54
The Qt install script uses the default version of python that the distro has set. Master branch is still using 2.7 as well. If you want python3 then you have to set it up. You would need to set the default version to 3 using something like update-alternatives:
linuxconfig.org/how-to-change-from-defau...sion-on-debian-linux
You then need to configure master branch to build using python3:
./configure --with-realtime=uspace --with-python=python3 --with-boost-python=boost_python3-py37
Or you could use master-gtk3 branch which doesn't need the extra commands and is reasonably up to date as it had master branch merged into it recently.
  • rodw
  • Platinum Member
  • Platinum Member
21 Jul 2021 00:02 #215450 by rodw
Thanks, I was more interested in installing from the debs without building Linuxcnc.
I just assumed becasue the scripts took so long to execute that it may have been installing Python 2.7.
I've got both Python 3 and Python 2 installed now.
So what should a new user do?  Can he use Python 3 now?
What will happen on an upgrade for this new user once Python3 gets into master?
21 Jul 2021 00:09 #215452 by phillc54
AFAIK all debs are still python2.7.
You can build and run python3, I "think" Greg does now, I do the occasional python3 build just for testing but I won't fully move to python2 until the official change over.
Time to create page: 0.173 seconds
