wrong scale thc of the z axis during cutting on qtplasmac
06 Jul 2021 07:17 #213851 by sibista
Hello
Error in the scale of the z axis when cutting with thc.  The values ​​are very small at 0.001 mm.  In the example, the torch rises 0.024 mm. While cutting on plasmac the thc torch is operating normally.  Version of qtplasmac v1.0.48
greetings
thc proma 150
  • Moderator
  • Moderator
06 Jul 2021 19:19 #213921 by tommylight
You mean the probe and pierce height, right ?
07 Jul 2021 00:50 #213937 by sibista
no, while thc tells the torch to go up or down, the torch moves up and down but only in hundreds of millimeters, not even a millimeter will go up or down. sorry for english greetings
07 Jul 2021 00:52 #213938 by sibista
07 Jul 2021 00:57 - 07 Jul 2021 01:06 #213939 by phillc54
Have you tried increasing the THC Speed %
Edit: It also depends on MOTION Setup Speed in the PARAMETERS tab.
Last edit: 07 Jul 2021 01:06 by phillc54.
07 Jul 2021 02:13 #213942 by sibista
yes, even up to 1000, nothing was done
07 Jul 2021 02:17 #213943 by phillc54
What is the value of Setup Speed?
Can you post a backup of your config.
07 Jul 2021 02:32 #213945 by sibista
Yes, later, now I can't. When I am at the machine I will do it. Greetings
  • Moderator
  • Moderator
07 Jul 2021 06:06 #213959 by tommylight
Missing
Plasmac.thc.feed-rate ?
I have it posted here on the forum somewhere but am on the phone.
12 Jul 2021 02:32 #214366 by sibista
Hello
Where can i find it?
Time to create page: 0.385 seconds
