wrong scale thc of the z axis during cutting on qtplasmac
12 Jul 2021 02:36 #214367 by sibista
I don't know which file do you need?
File Name: plasmacv1_...ions.hal
File Size:2 KB
File Name: plasmacv1.hal
File Size:4 KB
File Name: plasmacv1.ini
File Size:8 KB
12 Jul 2021 03:10 #214370 by phillc54
On the Parameters tab of QtPlasmaC there is a Backup button, attach the file created by that..
linuxcnc.org/docs/devel/html/plasma/qtpl...ml#qt_parameters-tab
12 Jul 2021 03:33 #214372 by sibista
File Name: qtplasmav1...9.tar.gz
File Size:10 KB
12 Jul 2021 19:23 #214462 by phillc54
I made a sim config using all your settings and parameters and it works as expected. I really don't understand why it would behave differently there. Can you post a gcode file that does not work correctly for you.
This is your config running as a sim:
12 Jul 2021 22:53 #214474 by sibista
hello, my test was to use shapes from the library. I turned on the thc proma 150 test mode then started the cycle. The plasmac raises and lowers the burner properly. The qtplasma doesn't do the same just in hundreds of millimeters. The test mode in thc proma 150 causes sending up and down signals, plasmac responds well to these signals and I use it on a daily basis to cut. I have no idea why qtplasma doesn't do the same.
12 Jul 2021 23:44 #214475 by phillc54
I know nothing about Proma 150 test mode, what does that do?
12 Jul 2021 23:53 #214477 by sibista
it's not my movie
12 Jul 2021 23:54 #214478 by sibista
12 Jul 2021 23:56 #214479 by sibista
13 Jul 2021 00:06 #214482 by phillc54
I don't know why Plasmac would act differently to QtPlasmac, they both share the plasmac component which controls the THC. As far as I was aware the proma couldn't move the Z axis until it was cutting while running a program.
Why would you use test mode when you are running a gcode program?
Can you post a video of the complete GUI while this problem is showing.
Time to create page: 0.105 seconds
