Rods "Spaceship" Scratch built Plasma Cutter build
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
13 Feb 2017 11:11 - 13 Feb 2017 11:12 #87903 by rodw
Well other than to pick up a box of M6 bolts to attach the linear rails and rack I have not done anything today.
I have spent a few hours redesigning the table frame. You see, initially I had designed it so that the linear rail mounts bolted to the legs of the table. After I ordered the laser cut components, I realised this was a really dumb idea as there was no chance the legs could be dead square. So I decided to wait until I had the parts before reworking the design.
Anyway, here is where I'm at:
I've now got a 65 x 35mm RHS rail extending the full length of the side rail that the linear rail mount will eventually bolt to. The downside is I need to space out the cable tray by 50mm. With a bit of luck I'll be able to round up some 50mm x 100mm RHS to do this. I think this will still work out nicely because the rails will be recessed 50mm under the top rails and I'll end up with a 3mm gap between the top rail and the gantry end. This will mean the slides will end up being very well protected.
I think the only decision left is to decide how high the table will be. I see a lot of small tables about 900mm high (bench height) but most commercial tales are a lot lower, maybe 700mm. Any ideas in this regard?
Also does anybody have any experience with the pros and cons of casters on a plasma table? Does the table wobble too much if you use them to wheel the thing around?
Last edit: 13 Feb 2017 11:12 by rodw.
  • rodw
  • Platinum Member
  • Platinum Member
19 Feb 2017 00:59 #88214 by rodw
A bits been happening. I had a visit from a CNC zone member who tracked me down through a mate to check out my progress.
I've purchased the steel for the table on Saturday morning. I borrowed the work ute to collect it and then cut it down before I bought it home.
Stacked up in a corner of the garage.
And I have one of the gantry axes running at last! Even if it is lying on its side.
I had a lot of trouble calibrating the travel accurately. When I did the last rack and pinion, I just calculated the steps per mm and plugged it in for it to work perfectly. This rack and pinion was sold as a 1.25 module set and the actual readings were quite a way out so I did some calibration against a 1.0 m steel rule. Anyway, I got it working in the end. I sent it up and down the gantry for 20 metres using relatives moves in gcode
And the error was 0.02 mm
I think that at 0.001 mm per metre, that is about as good as it gets. I did not use the dial indicator when I calibrated it, so I might look at it again based on the findings above.
I wasted hours this morning becasue of my inexperience with Linux. Norbert had fixed a Gmocappy bug that I found and reported earlier in this thread sop I wanted to pull it down and install it for testing. Anyway, things went wrong and cncnoob came to the rescue so after taking ownership of my linuxcnc-dev folder that root had somehow stolen, I did a "make clean" followed by a "make" and it was all back on track.
I'm quite keen to try dewey's development branches with axis offsets and a couple of other features on git hub becasue it is fixing some of the unforseen issues the developers missed that needed to be fixed following merging of the joint axis code into master.
I have a few things to round up before I can tackle the table and the next couple of weekends are pretty full so progress will slow somewhat for a while. I need to have everything here to mount some casters to it as once its welded together, I won't be able to move it without them. As I plan to build it right where my wife parks her car, I gotta be careful! Anyway, at least I am still chipping away.
  • rodw
  • Platinum Member
  • Platinum Member
19 Feb 2017 01:01 #88215 by rodw
I forgot. If anybody can help me with how to checkout a git branch, I'd appreciate the help!
19 Feb 2017 01:23 #88218 by Joco
It's normally just:
git checkout <branch/tag name>
  • rodw
  • Platinum Member
  • Platinum Member
19 Feb 2017 01:25 #88219 by rodw
It's normally just:
Thanks James, do I do that in a new folder or does it go into the linuxcnc-dev folder?
19 Feb 2017 01:46 #88220 by Joco
Rod - git does some magic so that you don't actually need to checkout different branches into different folders like you would do with svn.
However if you really wanted to have different folders then just clone the repo to another folder, cd to it and do a checkout to the branch you want.
git-scm.com/docs/git-checkout
  • rodw
  • Platinum Member
  • Platinum Member
19 Feb 2017 02:17 #88223 by rodw
OK, so I did that
plasma@plasma ~/linuxcnc-dev $ git checkout dgarr/external_offsets
M	bin/.gitignore
Branch dgarr/external_offsets set up to track remote branch dgarr/external_offsets from origin.
Switched to a new branch 'dgarr/external_offsets'
And then I thought the next step would be a git pull which failed
plasma@plasma ~/linuxcnc-dev $ git pull
remote: Counting objects: 179, done.
remote: Compressing objects: 100% (29/29), done.
remote: Total 29 (delta 28), reused 0 (delta 0)
Unpacking objects: 100% (29/29), done.
From git://git.linuxcnc.org/git/linuxcnc
 + c786d2d...3166ec6 dgarr/external_offsets -> origin/dgarr/external_offsets  (forced update)
Auto-merging src/emc/task/emctaskmain.cc
Auto-merging src/emc/rs274ngc/gcodemodule.cc
Auto-merging src/emc/motion/control.c
CONFLICT (content): Merge conflict in src/emc/motion/control.c
Auto-merging docs/src/motion/external-offsets.txt
CONFLICT (add/add): Merge conflict in docs/src/motion/external-offsets.txt
Automatic merge failed; fix conflicts and then commit the result.
So how do I get the branch source?
  • Moderator
  • Moderator
19 Feb 2017 02:26 #88224 by tommylight
Rod, your build is looking niceeeeeeeee!
I offloaded a plasma frame build to a friend, metal worker, still waiting for it and last i saw it he had to cut it and weld it again due to a lot of mistakes.
Regards,
Tom
  • rodw
  • Platinum Member
  • Platinum Member
19 Feb 2017 02:27 #88225 by rodw
Ahh, I think I get it now, I see the external_offsets sims in the linuxcnc-dev folders now so I guess its just a matter of running make again! Lets see what happens after it finishes building
  • rodw
  • Platinum Member
  • Platinum Member
19 Feb 2017 05:27 #88232 by rodw
Regards,
Tom
Thanks Tommy. I am a bit worried that might happen to me!
Anyway, I was able to install Dewey's external offsets code, but I don't really understand it yet.
Time to create page: 0.225 seconds
