Remora - ethernet NVEM cnc board
10 Sep 2022 05:32 #251602
by scotta
Replied by scotta on topic Remora - ethernet NVEM cnc board
To give an idea of what will help work out the IO. Using Rog's earlier photo's we get this the result below. A rule / scale in X and Y is the photo would also help scaling and stretching the images to get them to line up. This is going to be challenging... anyone remove solder mask of a board before? Being able to electrically trace this would also be beneficial.
10 Sep 2022 05:40 #251603
by Bari
Replied by Bari on topic Remora - ethernet NVEM cnc board
If it is a dry film solder mask then it's likely polyethylene . You can try soaking it in xylene. If that doesn't loosen it then it might be an epoxy that will require some abrasive for removal.
10 Sep 2022 16:49 #251622
by MX_Master
Replied by MX_Master on topic Remora - ethernet NVEM cnc board
We can just solder out the chip using soldering station and hot fan. Any repair shops can do that work. After all the tests chip can be soldered back with re-balling technique.
10 Sep 2022 17:56 #251626
by scotta
I borrowed a SMD rework station to remove the optos from the EC500. Not sure if I'm that ambitious to attempt it. All those caps on the back of the board... :-0
10 Sep 2022 20:21 #251636
by scotta
I've installed MCUEpreeso IDE and started to research what will be needed.
The NVEM/EC300 uses the same LAN8720A PHY as the earlier versions. The RT1050 examples use a MII example not RMII but I found this article:
community.nxp.com/t5/i-MX-RT-Knowledge-B...XRT1050/ta-p/1107482
I've only found one reference to a driver on an RT1020 site.
su.0v0.us/MoblinClub/imxrt1020-template/...rd/fsl_phylan8720a.c
10 Sep 2022 20:30 #251638
by Bari
Do you think that you should start a new thread here on the forums for the EC300 with Remora if the NVEM is now dead?
10 Sep 2022 20:33 #251639
by scotta
Probably a good idea as this thread is getting quite long. Shame all the earlier work is "wasted" because of the chip shortages. I've shelved all work on the DMA stepgen as well.
- Aanvragen0903
10 Sep 2022 20:38 - 10 Sep 2022 20:39 #251640
by Aanvragen0903
Replied by Aanvragen0903 on topic Remora - ethernet NVEM cnc board
Is it not better to first finisch the nvem and the ec500 before to move to newer versions? There are a lot of people who have the old versions.
Last edit: 10 Sep 2022 20:39 by Aanvragen0903.
10 Sep 2022 20:40 #251642
by Bari
Not a complete waste. The STM32's will be back and look all the experience gained developing LCNC code on microcontrollers. This also serves as a template for other micros as you can already see that the networking is similar, how to organize IO and stepgens, etc etc.
10 Sep 2022 21:01 #251645
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM cnc board
The newer EC500's will have this different MCU aswell I'd imagine.
Time to create page: 0.256 seconds
