Remora - ethernet NVEM cnc board
10 Sep 2022 21:03 #251646
by scotta
Replied by scotta on topic Remora - ethernet NVEM cnc board
The "old" versions of the NVEM and EC500 can still be supported to bug fixed. The boards are 99.9% working. Just attempts to get higher step rates will need to stopped.
10 Sep 2022 21:05 #251647
by scotta
There is a new EC300 which apparently has the same MCU as the new NVEM. I'll confirm when it arrives in a few weeks. The EC500 appears to be discontinued with no one shipping / cancelling orders.The newer EC500's will have this different MCU aswell I'd imagine.
10 Sep 2022 21:11 #251648
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM cnc board
I don't think it's canceled. They pulled the current stock. Iv emailed them and they said the model is getting "upgraded".
- Aanvragen0903
10 Sep 2022 21:34 - 10 Sep 2022 21:35 #251651
by Aanvragen0903
Replied by Aanvragen0903 on topic Remora - ethernet NVEM cnc board
Would it be wise to make a manual how to do things step by step for all versions because everything is now mixed
Last edit: 10 Sep 2022 21:35 by Aanvragen0903.
The following user(s) said Thank You: Domi
10 Sep 2022 21:40 #251653
by scotta
I really need to update the docs to include the ethernet versions.
remora-docs.readthedocs.io/en/latest/
10 Sep 2022 23:33 - 10 Sep 2022 23:34 #251659
by RogEnk
Replied by RogEnk on topic Remora - ethernet NVEM cnc board
Last edit: 10 Sep 2022 23:34 by RogEnk.
The following user(s) said Thank You: Bari
10 Sep 2022 23:41 #251660
by scotta
Thanks Rog, absolutely great!! I'll start to see if I can trace things. I've also ordered stencils and solder balls to reball the chip, just in case we need to lift the RT1052 to work out the circuit.
11 Sep 2022 00:32 #251661
by epineh
Replied by epineh on topic Remora - ethernet NVEM cnc board
What sort of bugs are we talking ? I understand dropping the higher step rates for these versions but as I have one making its way to me I could still use it on a more simple machine that doesn't need fast step rates.The "old" versions of the NVEM and EC500 can still be supported to bug fixed. The boards are 99.9% working. Just attempts to get higher step rates will need to stopped.
11 Sep 2022 00:44 #251662
by Bari
Replied by Bari on topic Remora - ethernet NVEM cnc board
11 Sep 2022 02:12 #251663
by scotta
None that I'm aware of, but you never know what people discover as they start to use the board.
Time to create page: 0.355 seconds
